Question about HP Compaq 175-Watt Power Supply
COMPAQ 272776-001 Power Supply 200W
COMPAQ 272776-001 200 W Power Supply - I cant get the power supply to start when pressing the power button on the computer. In the past, it would start after pushing the power button several times, or turning on and off the power strip. I want to know which leads trigger the start of the power supply. There are red, yellow, and black going to the motherboard. I was guessing the yellow was the trigger. I wanted to know if I can jump leads to make it work. Like the yellow and black, or is it something else I need to do?
  • moorebryan77 Mar 08, 2009
    thank you for your answer. My power supply came as part of the system. It has a push button on off cable instead of an on/off switch in the back. I beleive that the start button on all computers actives the power supply through the motherboard connection. I am trying to find out which leads going to the motherboard trigger the on/off for the power supply. I did try to push the power cord in. Because it did seem to be a problem. But it didnt solve it.
    thank you,
    Problem Solver:
  • 16 Answers
They all do, I believe, I installed a new one, into my computer system not long ago, are you sure your power supply is one that the computer can handle? You shouldn't have that much of a problem - I wouldn't go pulling apart the wires on the power supply, its made like that for a reason, what you could try is see if your power supply has seated properly, sometimes if your not working on a flat surface the power supply plug won't go in properly and will not be pushed in all of the way, try laying your computer on its side, and pushing in the plug also, each motherboard has a certain amount of plugs for example 20 and 24, some motherboards want it to be a 20 power plug and others want it to be 24 power plug, thats the plug thats connected to your motherboard, that I'm talking about. make sure you have the right number, and that the motherboard plug and the power supply plug match, basically have the same number of connectors, (I mean that little white plug at the end of the red,yellow,black, wires, I hope this helps. ps- I really had to push on the white plug to get my seated properly
Posted on Mar 06, 2009
Can I get wiring schematic for mitac X-200/12v power supply
Hi
If you copy the link below and paste it into the address bar of your browser, it will take you to a web page towards the bottom of which is a link showing "To download this file, click here". Upon doing so a pdf diagram is downloaded. This is a schematic which looks like the one you want.
http://www.eserviceinfo.com/download.php?fileid=39548
Cheers
Aug 10, 2014 | Mitac X-200/12v 200w Switching Power...
THE COMPUTER WILL NOT POWER UP AND THE FAN ON THE POWER SUPPLY IS NOT RUNNING. THE LED ON THE BACK OF THE POWER SUPPLY IS ON WHEN POWER IS APPLIED. DOES THE FACT THAT THE FAN IS NOT TURNING ON MEAN THAT IT...
It could be a software glitch that is preventing your motherboard from powering up: try to unplug the main power cord from the main AC source for about 5 minutes, replug and power Desktop again and see if it is back to normal.
Good luck! Hope it works for you!
May 15, 2011 | Hi-Pro Hipro 200W ATX Power Supply p/n...
2pin male connector of the motherboard (261671-001) purpose?
the switching power supplies are fun, by 2 pin plug is that from the AC side or computer side?
from AC side its easy enought to go buy another plug thought it should have come with one.
i cant remember any 2 pin plugs on the computer side and i have taken quite a few of these apart. there is a four pin plug...
wire colors,
yellow 12 volt
black ground
red 5 volt,
if the old supply was any of those colors you can desolder from the old supply and re solder it onto the new supply. if it was another color then i would suspect a random signal wire or cutout, keep you from frying yourself with the case open... try plugging up the new supply and turning on the computer if it runs why worry about it?
Jun 10, 2010 | Compaq (261671-001) Motherboard
My compaq presario laptop keeps getting an error: 0211 keyboard error it says press F1 to resume or F10 to setup but neither one of them does anything when I push them. Can this be fixed?
1. Turn off computer and unplug power cord.
2. Disconnect all external devices(open up the computer tower and then )
3. remove battery
4. press power button and hold for 10-15 seconds
5. plug power cord back into computer and press power button.
6. Check LED’s and listen for power supply fan.
7. If LED’s are on or power supply fan starts spinning, watch for boot screen
8. If coputer begins to turn on, turn it off.
9. Reconnect battery and external devices.
10. Press power button and make sure computer starts.
This should work....all the best
May 19, 2010 | Computers & Internet
NPS-200PB-73M
SPECIFICATIONS:
Dimensions 5.9"W (150mm) x 3.4"H (86mm) x 5.5"D (140mm)
Special Features Dell Proprietary Main ATX & 6 Pin Auxiliary Connectors
AC Input 100-120V/7A 60Hz 200-240V/3.5A 50Hz
DC Output Voltage 3.3V 5V12V
Total Output Max Load 200W
Regards.
Jul 20, 2009 | Dell - NPS-200PB-73M (NPS200PB73M) Power...
Loud Humming Noise from P/Supply
Yes, it is time to replace it. Open the case and make sure it is a standard size before you buy another one. Just measure length, width & height. You can put a higher wattage supply in there, it just won't have to work as hard to power your computer.
Apr 07, 2009 | HP and Compaq Pavilion Replacement 200w...
My SMPS burnt before 1 month.I want a new one.HP COMPAQ cabinet does not fit with ordinary SMPS.So plz help me
Please contact your nearest HP Service Centre or call HP helpline for a replacement as it would be under warranty.
Jan 19, 2009 | Hi-Pro Hipro 200W ATX Power Supply p/n...
Pc no start.........
You might have a bad power supply. If you have a voltmeter, check the voltage of the standby power supply. This voltage is present even if the system is off, plugged in. It powers a small portion of the logic circuit. It should measure within a couple of tenths of exactly +5 volts. If it is low, or high, this will prevent turn-on. The purple wire of the 24 pin connector is what carries this to the motherboard. The color coding layout is found at http://pinouts.ru/Power/atx_v2_pinout.shtml If by chance this voltage is OK, then check the full on voltages also. Repair of the defective supply is probably by replacement of one or more small electrolytic capacitors in the appropriate circuit, especially if you are technically savvy. Capacitors are available through several suppliers; Digi-Key supplyies Panasonic FC series which are suitable for switching power supplies. Or, you may just replace the whole unit.
Apr 24, 2007 | HP and Compaq Pavilion Replacement 200w...
HP Compaq 175-Watt Power Supply Logo
181 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
