Question about Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive
Hard disk is not detecting
I need to take backup of some data .but if connect to any other system for backup it won,t be detent.how can i take backup of my drive?
  • 92 Answers
Most of the time is becose you put the roung jumper configuration check on your hdd sticker you will si the good jumper configuration
bye and good lock
Posted on Mar 07, 2009
How to fix my external hard drive not detected?
If a replacement usb adapter doesn't fix it, your hard drive has failed and usually not recoverable.
Jul 11, 2017 | The Computers & Internet
Tip
How to back up window 7
<p>Back up your important files and programs absolutely necessity for time.<span> </span>Fortunately, Windows 7 has a built in your favor in the implementation of data backup and recovery procedure for your computer support. Use Backup and Restore Backup Windows 7 and all data stored on the hard disk. Although the Windows utility does not have many extra features such as third-party tools, is more suitable for the backup process and cost you a penny.<br /> <p> <br /> <p>1. Connect the USB cable from the external HD into a USB port on your computer. Connect the "Startup" window that opens.<br /> <p>2. Click Start, click Control Panel. Click "System and Maintenance, click Backup and Restore" button.<br /> <p><br /> <p>3. Click on "Configure backups to backup and restore window that opens. Click on" External Hard Drive "in the destination window and click Next. This means that the hard drive as the location of backup files.<br /> <p><br /> <p>4. Click the "Let me choose" option to a dialog to open files on your computer. Click to select Include system image units. "This option ensures that the backup is a copy of Windows 7 operating system, so belong to reformat or hard disk crash can be recovered.<br /> <p><br /> <p>5. Click "Next" and click "Save Settings and Run-up" on the confirmation window to start creating a backup of your operating system Windows 7. Do not get your hard disk to the process.<br />
on Jun 21, 2011 | Computers & Internet
My Dell Inspiron 6400 (Windows XP Home) won't reboot. It's giving me a "Loading PBR for descriptor 1 ... done" line on a black screen. What can I do to fix it. Can I salvage my content / files
Before you use the Recovery CD you need to backup your data because to restoring your laptop will wipe your data off the hard disk.
To backup your data when you cannot boot up your laptop, remove the hard drive and connect it to an USB hard drive adapter. Connect this hard drive/USB adapter into the USB port of a working computer. The computer will see it as an external storage device, you can then open the folders and backup your data.
You can then fit the hard drive back into the Dell laptop and boot up with the Dell recovery CD to reinstall Windows etc.
Mar 04, 2013 | Dell Inspiron 6400 Laptop Computer Core 2...
The system has detected a problem with one or more IDE/SATA hard disks
You have a hard drive problem.
If it won't boot because of this problem, then the hard drive with your operating system may have failed. If it offers several boot options, then choose safe mode and the use the scan disk programme (set out below for XP, other o/s slightly different) to try and resolve the problems.
Your hard drive is probably split into 2 partitions a large one for general use, a smaller one for backups and support data.
Try going to Start - All Programmes - Accessories - System tools - Scan Disk for both partitions
May 18, 2011 | Computers & Internet
My harddisk , seagates replica single PC unable to detect all of the sudden.... it shows that the window unable to install the driver.. hope to find a solution cause all my backup data inside..
Hi t_c_low2005 ,
First of all , please do not panic,
Nothing would happen to your data unless you deleted it intentionally or your hard disk has suffered a hardware damage.
I would recommend you to check if you have an extension wires for USB connected , if yes then remove them and connect the hard disk directly to the USB slots on your motherboard.
This should work fine...:) Hope it helps.
May 09, 2011 | Seagate Replica 250 GB USB 2.0 Complete...
Seagate external hard disk is not getting detected in windows 7 previously it was detecting. i tried to change usb cable, tried on different system but nothing worked. i want to take backup of data also....
This is my suggestion for you to possibly recover the back up file in your external hard disk.
Remove the enclosure cover of the external hard disk. Detach the hard disk from the ide connection.
Change the jumper setting of the hard disk to slave. See the sticker in the hard disk to see how to set up the jumper to slave. Connect the hard disk to the ide cable inside your pc. If your computer is equipped with sata cable, just find some ide cable and connect it the the ide slot in your motherboard.
Restart your system and you will find your hard disk as drive (d:) in your system. If this was successful then problem can be cause by loose terminal solder in the usb/ide connector of the enclosure, or possible voltage drop of the power supply of the enclosure. USB driver issue or problem with the usb slot in your computer can also cause this issue.
Jan 26, 2011 | Seagate FreeAgent Go 320 GB USB 20 Hard...
I have 3 2TB lacie bigger disk triple interface. I use them to backup my data. Unfortunely I lost 2 power supply so I used one for all. Yesterday I backup up all my data on one disk, I unplug this and...
If the power supply doesn't delivers the correct current the hard disks can't spin fast enough and this is detected as a failure by the pc, which cuts the connection. Hopefully by replacing the source all will go back to normal. Otherwise you will have to crack open the cases, remove the disks and install them directly in a desktop to try to access the data on them.
Dec 14, 2010 | LaCie Bigger Disk Extreme 2000 GB Hard...
I am having seaget 320GB Harddisk, which is not detected in BIOS, but when checked it disk is moving. I am having critical data in Hard disk which I need to recovery. Please help.
If the BIOS does not detect the hard disk then the hard disk could be faulty.
Retrieving data from damaged hard disk is possible. There are companies that can remove the disk platters from the damaged hard drive and with special equipment may be able to recover your data, but it will cost you an arm and a leg for their services. The reason for this high cost, they dismantle and remove the platters in the hard drive in a clean room environment and set up the platters up in jig/drive to retrieve/copy the data.
First thing I would try is to remove the damaged hard drive and connect it to an USB hard drive adapter and then plug this adapter into a working computer's USB port. If this computer sees this hard drive as an external hard drive and you can open the various folders and files, then I would backup your data.
If the hard drive is not detected then the hard drive is dead and data cannot be retrieved with this method.
Sep 08, 2010 | Computers & Internet
Hard disk not detected - Need to retrieve data
If it is your system drive (C:)
You can remove it and try connect to another computer (internal or in an external caddy).
Usually you can get the information you need like this.
Jul 23, 2010 | Samsung (SP0411N) 40 GB Hard Drive
SMART HARD DISK ERROR BACK
hi
SMART Hard Drive detects imminent failure. Your hard disk drive is detecting an imminent failure. To ensure no data loss, backup contents and replace this hard disk
Jyo
Jun 19, 2008 | Computers & Internet
Quantum Fireball Lct15 (QML20000LC-A) 20 GB Hard Drive Logo
241 people viewed this question
Top Quantum Computers & Internet Experts
Tape-Techie
SirEbrum
terminalcon
Are you a Quantum Computer and Internet Expert? Answer questions, earn points and help others
