Question about Zanussi ZBM799X Electric Single Oven
My electric cooker rings trip the electric board
    Problem Solver:
  • 28 Answers
Over current protection or circuit breaker is being overloaded therefore tripping. so you need to first find out how many amps this appliance is consuming than use recommended outlet type. say its a 40 amp,240 volt , look on fuse panel to see what size cicuit breaker that is being used.
Posted on Aug 08, 2009
Every time I switch the rings on my creda starlight cooker they start smoking and trip the electric ?
they are shorting out through the ceramic insulation
get and install new rings
Dec 31, 2016 | Creda Ovens
Can I fit a plug to new world vision 50 ecwlm cooker instead of electric box? Tried to find out if over 2.9kw but 2nd hand and no manual details
I have heard of people doing that and getting away with it - such is the capacity of the modern domestic ring circuit. Certainly no one should be doing it and no one with electrical knowledge would condone or recommend such a thing as if you didn't get away with it, it could burn your house down without blowing a fuse or tripping any safety devices.
The cables carrying the current to the sockets and light fittings traverse many flammable things between the power outlet and the electricity meter...
In an emergency you could fit a plug and use the cooker but never, ever more than one boiling ring and one simmer ring OR the grill OR perhaps even the oven if it is a conventional oven.
If you do decide to take the chance I advise you most strongly never to trust anyone else to operate the cooker and never to leave it unattended...
A large boiling ring is typically 1500/2000 watts and a small simmering ring is typically 800/1000 watts. I can't tell you what the consumption of the other equipment might be but it should be easy to discover as the manufacturer might have a downloadable manual on the website or you could try googling replacement heating elements.
You should have a cooker outlet installed as soon as possible.
Oct 01, 2016 | New World Ovens
Flavel milano e60 electric cooker
Element or switch is done. Try switching elements first to see if that is it....if not then the switch is gonzo. The switch works as a potentiometer allowing more or less electricity (current) through the element.
Dec 02, 2013 | Ovens
I have a stoves cooker which was working fine until we upgraded to the seventeeth edition consumer unit and rcds. Now I have a negative earth fault.Rcd trips out, circuit is fine up to the cooker. Any...
The clue will be when the rcd trips out. If everything is switched off on the cooker with the exception of the clock when you power it up and then it trips out, it could be in the wiring to the oven from the control switch and or the wiring in the oven. The only way you are going to find this is to take the oven out of the housing and test the wiring, isolating components until you find the problem.
Jul 31, 2011 | Stoves 720EF Electric Double Oven
I have a Smeg SE 336SS-5 Electric oven, I have recently had problems with the fan motor not working and the electrics tripping out when the cooker has been on for a while. I have replaced the fan motor...
This tutorial will show you how to check your Smeg element and how to replace your Smeg cooker element.
Here are the 3 main faults to look for in your oven or cooker that is not heating
  1. Your oven will not work until the clock/timer has been re-set after replacing an oven element or tripping the electrical supply. Consult your Smeg manual.
  2. If your Oven is not getting hot or heating up it could be a faulty element, if the fan in the oven is running and the thermostat light is on, this will lead us to believe that the element has gone faulty. With grills the thermostat light should come on there should be heat, if not then this could be the grill element or the thermostat.
  3. When you turn the oven on, the household electrical supply trips on the Rcd (this is the earth trip in the fuse board sometimes called the breaker tripping) your fan oven element has gone to earth and needs replacing.
If this helped you why not get me a beer? Paul is from the Naturally he would appreciate beer How to Repair Home...
Jul 07, 2011 | Smeg Ovens
Circuit board failure
Mar 24, 2011 | Smeg F170 Pyrolytic Stainless Steel...
Beko dvc 62 ,all electrics tripped out ,put cooker
The element has blown. It will cost you around
May 16, 2010 | Ovens
Tricity bendix se211 electric cooker trips all my electrics
The symptoms you describe are a classic example of an oven element heating up, and as it gets hotter, the insulation is breaking down, thereby causing the earth leakage trip to operate.
To confirm this , switch on the oven, and turn all 4 rings on the top to full heat, 2 at a time, let them stay on for at least 10-15 mins, and if it does not trip, then you can be pretty sure it is the oven element(s) that is the problem
It is not likely to be the wall switch, as if it were faulty, i would expect the trip to go right away.
If you want to check further, then turn on the oven again and see if it trips, if it does ,then it is definately the oven element(s) that is the problem.
If it is a fan assisted oven , the element is at the rear of the oven, and possibly one under the base ot the oven. If it is a conventional convection oven, then there is an element at each side of the oven, even if one is faulty, replace both.
Plz rate my solution.
Thanks.
Jan 07, 2009 | Ovens
My tricity bendix electric cooker/oven trips all electrics
H iyou can get the electrics cheched that will rule that out but it sounds like a short on the oven it could well be the element in the oven which you should be able to replace as its only 3 years old
Jan 07, 2009 | Bosch HBN 452 / HBN 456 Electric Double...
Zanussi ZBM799X Electric Single Oven Logo
285 people viewed this question
Top Zanussi Ovens Experts
ashburton
Charles T Nevin
Charles T Nevin
Are you a Zanussi Oven Expert? Answer questions, earn points and help others
