Question about HP Photosmart C3180 All-In-One InkJet Printer
I have filled both my cartridges but printer wont print.
Is it easy to clean? And is there directions. To do this? please.
  • jameskoll Mar 11, 2009
    our HP Photosmart C3100 All-in-One printer does not print even though we put new ink jets in it. We took it to best buy and they said it is pretty much shot. Is there anything else to try?
    Sergeant:
  • 199 Answers
Replace cartridge
Posted on Mar 05, 2009
HP Printing, copying, faxing, scanning black pages
change the ink cartridge & get your printer serviced
Jul 18, 2010 | Office Equipment & Supplies
Trying to use a re-filled ink cartridge HPf4280
I seem to recall that these cartridges are chipped and you need to get a chip resetter. Look on the base to see if a small circuit board is present. If so then you have to get it reset or buy a new cartridge.
Please rate my help++++Thanks for using FIXYA
May 18, 2010 | HP LaserJet 4200 Printer
Wont print black ran clean many times
I have to ask this question of you, just to make sure this is not an issue. Are you using a factory new ink cartridge?
Please consider the following:
If you are using a refilled or third party cartridge that may well be your problem. Most manufacturers build logic into their products to prevent the use of “Other Equipment Manufactured” cartridges as well as re-filled cartridges.
They do this to prevent problems from contaminated inks causing problems with print quality or damaging the physical printhead.
If you are using factory new cartridges, then please call the manufacturers Technical Support for assistance with the warranty on the cartridges
Don
Feb 10, 2010 | Brother MFC-5840CN All-In-One InkJet...
Ink cartridge stops at the middle of my printer.
Problem : An error occurred while communicating
Afteryou install a print cartridge, the attention light begins to flash red.The printer will not print. One of the following messages may appear onthe control panel:
or the Printer stops Printing in the middle .
Cleaning the Still Rode on which the Cartridge Move, may solve your Problem
Check this Video - This may help you a Lot VIDEO
Check the following steps as well for connection steps .. and also the process of refilling the Ink to the Cartridge
* Color or Right Print Cartridge is not compatible
* Incorrect Print Cartridge(s)
* Print Cartridge Problem
* Incorrectly Installed Cartridge(s)
* Black or Color Cartridge(s) Failed
Solution :
Tosolve the problems related to Cartridge Errors we can do the following4 steps. Which could help us to get the issue resolved
Step 1: Remove, inspect, and reseat the problem cartridge
Step 2: Clean the problem cartridge contacts
Step 3: Repeat reseating and cleaning steps
Step 4. CONTACT TO HP SUPPORT
Step 1: Remove, inspect, and reseat the problem cartridge and Clean the problem cartridge contacts..
a) Make sure the printer is on. Press the Power button if it is not lit.
b) Open the printer cover, then wait until the print cartridge carriage is idle and silent
c) Press down lightly on the end of the problem cartridge to release it.
d) Slide the cartridge out and inspect it:
* Check the Copper electrical contacts (the Copper Part which touch the Connector inside)
* Clean it with the pirit or wet cotton)
* Check the Nozzles - Clean it with the worm wet cotton
* Wait for 2 to 5 min befour you connect them back
* Clean the contacts in the carriage, inside the product (Printer)
* Reinstall the cartridge.
* Reconnect the product to the electrical outlet.
* Close the product cover.
NOTE: you can also check the print cartridge label and make sure it iscompatible with your printer. Compatible print cartridges are listed inthe Printer Reference Guide supplied with your printer.
Note : If the cartridge is compatible, reinstall it in the printer:
* Cartridges marked with a triangle go into the left carriage slot.
* Cartridges marked with a square or pentagon go into the right carriage slot.
If issue not resolves Repeat repeating and cleaning steps
How do i refill my INK Cartridge ?
There are 2 distinct method
1) Black has a bladder
2) Color contains sponges - we need 3 sirenges with needle
to fill the Color cartridge with sponges - simply punch
COLOR CARTRIDGE
1. If you see the Cartridge turn it round and locate the filler holes by removing the plastic top cover of the cartridge.
You may need to pry plastic top or hole cover off using a thin metal blade.
please make sure that you do not damage the sensors on the back of the cartridge whilst doing this.
2.Using the picture(on the cartridge which shows you the 3 differedcolored spots), fill syringe with the corresponding color ink.
3. Insert the syringe into the correct hole of the color being filled and push all the way down.
Notes : You will feel resistance as there is a sponge inside.
So Slowly inject approximately 8ml of ink until you can just see the ink surface on the top of the sponge, any more and it is over-filled.
If this happens simply draw back on the syringe a little.
4. Rinse the syringe and needle thoroughly before proceeding then repeat the process for the other colors.
8. Re-attach the cover securely with adhesive tape and continue using the cartridge.
BLACK CARTRIDGE
1. Fill the syringe with approximately 20ml of black ink.
2.Push the syringe all the way into the filling hole and SLOWLY injectall the ink into the cartridge or until the reservoir is full.
3. Replace the cartridge and run 1 - 3 cleaning cycles as per printer instructions.
4. If necessary leave cartridge in printer for up to 24 hours. (This allows ink to flow to the print head).
Jan 04, 2010 | Dell V305w All-In-One R840635AU InkJet...
Magenta and yellow wont print ,new cartridges,cleaned print head still wont print .black and cyan work fine
Forgive me for asking this, but roughly speaking about 80 to 95% of problems involving ink or toner are resolved by the following:
Are you using a factory new ink cartridge supplied by the manufacturer of the printer?
If you are using the manufacturer’s new ink cartridges, then please contact their technical support group. Factory new cartridges usually have warranties on them.
Don
Dec 12, 2009 | Epson Stylus CX5800F All-In-One InkJet...
Black wont print. Changed to new cartridge, nothing
Don
Nov 19, 2009 | Office Equipment & Supplies
Kodak esp7 wont print black
Click on menu on the printer,scroll down and choose clean printhead or go to maintenance and then click on clean printhead .After that try to print. If issue persists,call kodak @ 1800 421 6699 and they will replace the printhead for you free of cost.Printhead is the part which holds the cartridges and has 4000 nozzles which sucks ink from cartridges.It Might have gone bad
Sep 28, 2009 | Kodak ESP 5 Printer
Print spooler doesnt work wont print, on windows vista, lexmark x4530 printer
# Hold the cartridge upside down, with the bar-code label facing you and take a damp paper towel.
# Use the towel to wipe the printhead of the cartridge on the bottom (where the ink comes out). Wipe the printhead horizontally in one direction only (left to right).
# Continue doing this until it looks clean.
# Then dab the cartridge on the towel to make sure the ink is flowing.
# Next, look inside the printer and locate the carrier that holds ink cartridges. Caution: Make sure the cartridges are not installed at this point.
1. Look for a shiny piece of metal underneath the contacts at the back of the carrier.
2. Take a damp cotton swab (use water only!) and wipe along the bottom of the shiny metal piece. Note: You may need more than one swab.
# Reinstall the cartridges, making sure you snap them correctly into the printer.
Hope this help. Please Rate My Response! Thanks!
PREM
May 26, 2009 | Lexmark X2500 All-In-One Printer
Not printing
Epson requires that you replace empty cartridges with their branded replacements.
Otherwise your printer wont function.
Aug 02, 2008 | Epson Stylus CX6600 All-In-One InkJet...
BJC-80 - Wont' print
Look on eBay for printhead or cartridge cleaning solution. The cartridge is clogged with dried ink. Take an empty ink tank, and drip cleaning solution onto the sponge, filling the cartridge part way. Install the cleaning cartridge in the printer, and leave it over night. Run cleaning cycle the next day, and print with the same cartridge. It should start printing. Install new ink cartridge.
With the BJCs, if the cartridge is defective electrically, the printer will have an error and usually 3 beeps, it will not try to print.
Apr 23, 2008 | Canon BJC 80 InkJet Printer
HP Photosmart C3180 All-In-One InkJet Printer Logo
51 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
