Question about Adobe Computers & Internet
"an error has occurred that may be fixed by installing the latest
I am saving to pdf from Coreldraw it give me the error "an error has occurred that may be fixed by installing the latest version of the Simplified Chinese Language Support package" Please help
3 Suggested Answers
SOURCE: The Japanese Language Support Package is required
The PDF document contains data in Japanese and needs the support package to display the correct Japanese characters. This is common with files on websites of Japanese companies even thought the document may contain English language also. You can simply cancel and then view the document English text but the Japanese text will not be displayed and you will see various garbage and blank spaces instead. Alternatively, you could simply install the support package. This will then enable Acrobat reader to correctly display Japanese characters. Note: you can also get a similar message if you access a document in Chinese which will then prompt you to install the Chinese support package!
Posted on Jul 31, 2009
zhuismile
  • 77 Answers
SOURCE: Links do not work in Pdf saved file
Don't panic,many people face this problem.You can use a third-party tool,such as advanced word to pdf 5.0,It is good in preserving the formatting.
source:http://www.advancedpdfconverter.com/products/wordtopdf.html
Posted on Apr 30, 2010
How do i fix the problem with corel files damaged by virus?
if your problum is still pleas use this latest matlab 2016 with key tool Matlab r2015a Serial Key Keygen Cracks are Free Download LATEST VERSION
t
if you want use your software so pleas install avast antivirus
avast secureline vpn license key
Mar 16, 2016 | CorelDRAW Graphics Suite X4 for PC...
How to cdr repair corrupted image?
If you are using windows 7 or later, you can try opening the folder in windows explorer, right click on the CDR, go to properties and then the previous versions tab. It may have kept an older version.
I can't remember if XP also kept previous versions and it also depends on your configuration, so it is not definite that you will have them.
Another, small, possibility is to look in the same folder and see if you have a file which begins backup_of_... and your filename. But this keeps only one previous copy so if you have saved the file more than once since Wednesday your backup will be too new.
And:
CDR Repair Kit. A must-have CorelDraw CDR repair tool for all categories of users seeking a reliable method of restoring their CorelDraw images after data corruption accidents of various types.
For more information: http://www.cdr.repair/
And here: http://www.filerepairforum.com/forum/cad-tools/cad-tools-aa/coreldraw/442-error-reading-problem-in-x3
Nov 06, 2014 | CorelDRAW Graphics Suite X4 for PC...
How to Fix error code Ce-34878-0 on PS4
If you are experiencing this ce-34878-0 error code, please close the application and then install the latest system software and game patch. If the error occurs again, initialise the PS4 system after back-up of the save data and please also submit any crash reports after re-booting your console when the error occurs. Sure the "solution" isn't exactly helpful for those that have already lost their save file, but it's good to have something to refer to when the error hits. Until Sony patches the PS4 for this error, this is probably as close to a fix as we'll get.
Apr 04, 2014 | Washing Machines
Error code 0x00000002
STOP 0x2 DEVICE_QUEUE_NOT_BUSY error code has a value that is 0x00000002. This is a fatal error typically known as STOP message or Blue Screen of Death (BSOD).
This error generally occurs in Windows XP but may also occur in latest version of Windows such as Windows Vista or windows 7. The computer may stop responding without warning. Moreover, your computer may give error messages like STOP 0x00000002 error or related errors and if blue screen appeared then you may have to restart the system in the mean time of your work due to which unsaved work will be lost.
Cause of Error:
  • You may be using corrupted profile in your system which raised this problem
  • The device driver of your system is not updated
  • Malfunction of hardware usually is the cause of error such as STOP 0x2 DEVICE_QUEUE_NOT_BUSY or similar error
  • Registry database of your system may have corrupted or modified erroneously by invalid application
  • You have installed new hardware unsystematic or installed unknown application
  • Spyware has infected the PC
  • Antivirus software is not working
  • The operating system or application might have run out of usable memory.
This is one of the serious problem in computer if it is not resolved instantly then it might create some more unexpected error. STOP 0x00000002 error and its related error will disturb you all the time and you may have to bear loss of data. When blue screen of death appear on your monitor screen then you need to restart directly whether you have saved your work or not. Therefore, you are suggested to fix STOP 0x00000002 error as earliest possible.
How to Fix:
To fix STOP 0x00000002 error you need to follow the following methods.
  • If this error occurs in your pc then you will have to restart the PC and then press F8 key before appearing Windows. You will see a black screen with white text giving many options. Select the option "Last Known Good Configuration" and press Enter. If you have configured the computer improperly then it may fix the error.
  • If you have installed any hardware in your system then the chances is more that the device driver is not updated and thus errors of type STOP are given at the time of operation. You must download latest drivers.
  • If your system does not become stable then you need to try scanning of registry with this tool. Since, registry keeps all configurations of your system if it gets impaired then you must download registry repairing softwareand repair it .
Mostly, spyware has been the reason of various errors in computer system. Spyware damages files in the computer system and if once damaged then it is no longer used and it also corrupt registry database. The file which is infected by virus may be a program file, system file etc. If STOP 0x00000002 error occur in spite of antivirus then download anti spyware to scan your computer.
Hope this information will help.
Your response is very much appreciated. Thank you for using Fixya...
Sep 28, 2011 | Microsoft Computers & Internet
I am using Epson TM T81 thermal printer and it is showing status USER INTERVENTION REQUIRED , printer is not printing document. I uninstall drivers and install it again it works but whenever I restart the...
Sir/Madam
i suggest You download Epson Printer Driver From official Epson Printer Website and Perform Below Following Step Mention On Epson website on Below, i hope You Fix Your Epson Printer problem,
1. About this software This package includes the following two software programs to use with an EPSON TM-T81 printer. 1) Windows Printer Driver This driver is a Windows Printer Driver for the TM-T81 printer. This driver makes it possible to print from a Windows application.
2) StatusAPI StatusAPI is a program that works in conjunction with the TM-T81 printer driver. It offers an Application Program Interface for obtaining the printer status whether or not the printer is printing. This API makes integrating printer status handling functions with applications more simple. For detailed information, please see each reference manual. The driver operation has been verified with the following operating systems. Windows 7 Ultimate SP1 32/64bit Windows Vista Ultimate SP2 Simplified Chinese 32/64bit Windows XP Professional SP3 Simplified Chinese 32bit Windows Server 2008 R2 Enterprise SP1 64bit Windows Server 2008 Standard/DataCenter SP2 Simplified Chinese 32bit Windows Server 2008 Standard SP2 Simplified Chinese 64bit Windows Server 2003 R2 Enterprise SP2 Simplified Chinese 32bit Windows Server 2003 R2 Standard SP2 Simplified Chinese 64bit Windows XP Embedded 32bit SP2 Windows Embedded Standerd 2009 32bit Windows Embedded POSReady 2009 32bit This driver is not supported by Windows 95/98/NT/2000 and Windows XP 64bit. EPSON IM series PC or IBM compatible PC Supported Printers EPSON TM-T81 The printer driver operates regardless of the pritner firmware version. 2. Supplied Files APD_415bSC_T81.zip : Printer Driver,StatusAPI installer with manuals Refer to the installation manual APD4_T81_Install_SC_RevE.pdf. 3. Remarks - For detailed information, please read each manual that is created by the installation. -When an error message is displayed during installation, the following procedure may enable to recover from the error. 1) Specify the uninstall option, and execute the installer "APD_415bSC_T81.exe /uninstall". 2) Remove the error factor.
3) Execute the installer "APD_415bSC_T81.exe". -Characters may not be printed correctly when using Easy Print of Windows Server 2008. For detailed information of this problem arising from the operating system, see the following web page provided by Microsoft Corporation.download epson biz com
Or If You Still Need Epson Printer Help Then Follow Us On:
Epson Printer Support
May 11, 2011 | Epson POS TMT88IV Thermal Receipt Printer...
I cannot save a calendar as a pdf file. I get the
When your want to save your file as .pdf extension, you have to select a "virtual printer" from your "Printers & Faxes" when you install the software you are using to save as pdf file.
If you select your physical printer install on your PC, the error message you mention will appear.
Hope it helps.
Jul 21, 2010 | Broderbund American Greetings Creatacard...
I am using Corel X3 version and would like to open a file that was created with the X4 version. What can I do?
Step 1 Launch CorelDRAW Graphics Suite X4. If you don't own the software, download and install a free 30-day trial from Corel.
  • Step 2 Go to "File" "Open" and open the X4 file you want to convert into a backward-compatible X3 file.
  • Step 3 Go to "File" "Save As" and choose "CorelDRAW X3-compatible" from the "Save as Type" drop-down menu. Click "Save."
  • Feb 11, 2010 | CorelDRAW┬« Graphics Suite X3 Upgrade...
    I have acrobat 5.0 and acrobat 7.0 on my computer. Most of the time they fail to read acrobat files with an error message ''An internal error has occurred'' appearing on screen. Any suggestions?
    uninstall all your versions, run "ccleaner" and do the registry scan and fix all, do this 3 times to fix everything
    restart the puter and install the latest version
    Nov 13, 2009 | Adobe Acrobat 7.0 for PC
    Error 7 keeps coming up when oppening itunes
    A number of users have experienced problems updating to the newlyreleased iTunes 8.1.1. Generally, when this issue occurs, installationappears to proceed normally but then delivers the error message “Theinstaller encounted errors before iTunes could be configured. Yoursystem has not been modified. To retry these operations at a later timeplease return to the installer again. Click Finish to exit installer.”Fix
    This problem can often be fixed by reinstalling the latest version of QuickTime via the following steps:
    1. Download the latest edition of QuickTime for Windows (make sure to pick the option without iTunes)
    2. Choose to save the file to your disk, then double-click the .exe file and install QuickTime
    3. After QuickTime is successfully installed, download iTunes again, choosing to save the file. Double-click the iTunes installer .exe and proceed with installation.
    Other potential fixes for this issue include:
    Run a disk check Disk errors, particularly in Windows XP, can prevent proper iTunes installation. See this Microsoft Knowledge Base article for instructions on performing a disk check/repair.
    Use Windows Installer Cleanup Use the Windows Installer Cleanup toolto remove any references to Apple-related installation files(QuickTime, iTunes, etc.), then re-try using the aforementionedtwo-step method to reinstall QuickTime and iTunes
    Oct 22, 2009 | Apple iTunes
    I am using Corel 14 version but all function like save, save as , print, export, print, coverting to PDF got blocked, please solve this
    Maybe you use a cracked version and they got you and they downgraded your software back to the trial/commercial version.In those type of software try buying the original licence....
    Jun 23, 2009 | CorelDRAW® Graphics Suite X3 Upgrade...
    Open Questions:
    Computers & Internet Logo
    1,422 people viewed this question
    Top Adobe Computers & Internet Experts
    lemesee
    Are you an Adobe Computer and Internet Expert? Answer questions, earn points and help others
