Question about Dell Inspiron 1525 (dndwpa3_6) Intel Core 2 Duo T5450 (1.66GHz/667Mhz FSB/2MB cache) 250GB/3000MB PC Notebook
Dell 1525 it picks up hard drive but dosent read it
    President:
  • 1,223 Answers
That means that it shows in bios but unable to load OS is that so then ur hardrive has crashed kindly change it everything will b ok
pls rate me fixya if i solved ur problem
Posted on Mar 05, 2009
I have Dell inspiron 1525 window vista recovery reports 5 error are detected in hard drive and memory errors detected on my laptop 1. hard drive doesnt respond to system commands-critical error 2.boot...
your HDD may be corrupted, re-installing windows vista is one option. Your best bet is if you have/ can obtain a copy of windows vista run setup and try the repair wizard in the windows vista setup, the wizard automatically finds errors and missing files and replaces them therefore solving any errors in your HDD. you can also try to use the recovery wizard from your recovery disc. best of luck
May 17, 2011 | Dell Inspiron 1525 Notebook
I did a diagnostic test on a dell inspiron 1525 and everything passed except the hard drive with error code 0142, what does this mean and can it be fixed, thanks.
Based on
Dell Pre-Boot System Assessment (PSA) Diagnostics and Error Codes For Dell Computers - KB Article - 30042,
it is a Hard Drive failure, and you need to replace the Hard Drive.
I suggest to try reinstall windows first before you replace the Hard Drive.
Hope it helps you.
Apr 17, 2011 | Dell Inspiron 1525 Laptop
Laptop dell 1525 : power on but no hard drive activity,then later turns on normally (window vista ,normal)and then frozen and after restart no hard activity again but power is on???
You can try running the DELL diagnostics which came with the computer or you can download them off another computer from the dell support website.
Once you get in the diagnostics package. Check the Hard drive, there will be a few testing parameters for the disk check them all.
If the hard drive fails in even 1 test, note down the error code and provide it to dell support who will replace the hard disk if it is still under warranty.
If you dont have warranty then you may need to buy a hard-drive yourself and have it fixed.
Feb 23, 2011 | Dell Inspiron 1525 Notebook
My dell inspiron 1525 has a memory write / read failure and i tried to reseat the memory and that did not work. Please help me
This could also be a problem with the hard disk. Part of the hard disk is usually used as a virtual memory. If the hard drive is defective, you could experience this kind of failure.
Check your hard disk drive using CHKDSK C: from a command line prompt. Check the outcome of this command. If you find any errors, run the command CHKDSK C: /F to fix the errors. Beware that the second command will prompt you to reboot your computer.
Nov 29, 2009 | Dell Inspiron 1525 Laptop Jet Black
Error 0141 msg:error code 2000-0141
The hard drive has failed. If you're in warranty, contact Dell for a warranty replacement of the drive - it's a customer-replaceable part.
If you're out of warranty, look on ebay for a good deal on a brand new hard drive for your Dell Inspiron 1525
Nov 09, 2009 | Dell Inspiron 1525 Notebook
When I turn on my dell 1525 it says internal no bootable devices
The BIOS is not reading your hard drive. Take the drive out and reboot into BIOS. Make sure the SATA port is enabled. Turn the laptop off and reinstall the hard drive, make sure it seats all the way and is secure in its caddy. Reboot and see if it reads the drive.
Sep 25, 2009 | Dell Inspiron 1525 Laptop
Dell 1525 can read CD but does not read DVD
Hi, If your Dell 1525 has got a CDROM drive or CD Burner/Writer then you can only Read and Write the CD's
But if you got a DVD optical Drive then you can Read CD and DVD too...
If you need more clarifications on the same, pls send me the Service Tag of your computer. ( you can find it underneath the laptop)
Jan 22, 2009 | Dell Inspiron 1525 Notebook
Dell Inspiron 1525 (dndwpa3_6) Intel Core 2 Duo T5450 (1.66GHz/667Mhz FSB/2MB cache) 250GB/3000MB PC Notebook Logo
49 people viewed this question
Alun Cox
