Question about Samsung SyncMaster 753S 17" CRT Monitor
Cable color codes for samsung syncmaster 753s
The VGA cable is cut off, can someone tell me the color codes, so I can solder the connector?
  • Usher
    Usher Mar 05, 2009
    I know the pinout for the D-SUB 15, I've got it from the hardware book; but I don't know the color codes for the wires in the VGA cable, e.g. what is the the wire color for vsync.
  • mark
    mark May 11, 2010
    take look at this diagram picture on this website
    http://www.tkk.fi/Misc/Electronics/faq/v...
    hope its ok if not just get back to me and ill have another look for something better for your need
I want to fix new vga connnector on my smsung syncmaster 753s monitor and i am confused with colour coding please help me
Posted on Feb 14, 2010
  • 127 Answers
Hi not to sure if this is going to be any good to you
http://myhometheater.homestead.com/vgacable.html
take a look at this site it might be of some use its an area ive done much with done much with vga cables
Posted on Mar 05, 2009
Compaq 5500 vga 15 pin color code
The only reason you would need the color code is because you cut off the VGA connector and lost it. The reality is that you would need a monitor that was the same make and model and manufacturing plant to see the color code. Here is a link to the VGA pin-out. You would need to find a service manual that would define the connector inside the monitor. Opening CRT monitors is very dangerous. I would recommend against it. I have looked at a cable I have that had a removable shell and the Red pin was red the Blue was blue and Green was green. all the rest where other colors or multicolor
Jul 15, 2014 | HP Computers & Internet
Tip
IPod Shuffle 2nd & 3rd gen Sync cable
save up to $50, make a sync cable for ipod shuffle 2nd gen and 3rd gen on your own,
all you need is a 4 poles 3.5 mm jack, and USB plug. you get this on an old USB connectors ,
the color coding of USB cables is in standard so all you have to do is to solder the color coded wire to the 3.5 mm jack
here are the links of pictures of wire color coding that tells where the wire shouuld be solder http://i863.photobucket.com/albums/ab192/matrix_jc2001/Untitled-1.jpg
on Dec 31, 2009 | Audio Players & Recorders
The Envision H170L Monitor VGA cable.
the Envision H170L Monitor uses an interface 1.0x VGA - 15 pin HD D-Sub (HD-15). The same VGA cable wildly use in different computer brands..I was wondering why you have not found a replace for that cable. It can be purchase from any computer store.
If you are planning on cutting the wires and solder it together that would be easy if you have the diagrams of the pin numbering for male VGA connector and the female VGA connector. Check first this diagrams and follow strictly the coding of the wire so that it would be successful when connecting it together.
It is also better if after you solder the wire, you will use an shrinkable tube on the connection. Cover the whole sections of interconnected wires with shrinkable tube before you use the vga cable.
Jun 03, 2010 | Envision H170L Monitor
My Hyundai B70A Flat screen monitor all of a sudden has a green tint as I was reading info online. Can you tell me why and how to fix it? I tried the color adjustments thru the computer and thru the...
replace the signal cable user can also replace it that cable is detachable and attachable if persists then there is a dry solder inside the monitor. one possibility is that vga connector of motherboard may loose or faulty.resolder the connector
Mar 20, 2010 | Hyundai ImageQuest B70A 17" LCD Monitor
NEED TO PUT A NEW END ON THE CABLE THAT ATTATCHES TO MY DESKTOP
Don't attempt this unless you're comfortable with soldering. Be very careful, because hooking the pins up wrong could damage your monitor, your computer or both. You'll need a male VGA connector and a shell for it. Cut off the old connector and strip away the outer insulation on the cable so you can see what color cables go to which pins, then just make the same connections to the new VGA plug. Double-check everything--you may only get one shot at this.
Mar 14, 2010 | KDS Computers & Internet
My VGA plug is missing on my monitor
If the cable does not disconnect from the monitor, then go ahead and buy a new connector http://www.startech.com/item/C15HPSM-High-Density-DB15-Male-VGA-Solder-Connector.aspx
I recomend this over buying a generic VGA cable and splicing wires, for better connectivity and less 'noise'.
Aug 06, 2009 | Neovo F-417 17" LCD Monitor
How do I find and replace the vga cable? (It is hardwired to the back of the monitor.)
I got hold of an old vga cable (15 pin), cut off the male end. I then cut the existing cable comming out of the monitor. After soldering the wires together and lots of electrical tape wala - it works.
Now the problems I incured - Don't solder wires together based on color, they probably will not match. Peel back the ends of the cut off connectors and find each pin with a Multimeter. Once you find each wires match solder them carefully and tape. When done test and if good place a short splint on the spliced area and tape. This will keep the wires from breaking from movement. Good luck.
May 24, 2009 | Sylvania SF150 15" Flat Panel LCD Monitor
Packard bel slimview 517, twisted vga cable
yes if you can solder then cut the cable and solder the 15 pin vga connecter first test the continuty between the connecter and opposite end write it on paper then according to that solder all wires but better to buy new cable for long time
Oct 28, 2008 | Computers & Internet
15 pin VGA connector damaged.
i want to know that what is the color combination of vaga cable connector
Aug 28, 2006 | SAMTRON 55V 15" CRT Monitor
Samsung SyncMaster 753S 17" CRT Monitor Logo
1,783 people viewed this question
Top Samsung Computers & Internet Experts
Computer Repairing
Computer Repairing
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
