Question about Candy CDC266 Dryer
CD ROM not working
My CD ROM is not reading the data from CD.
  • Candy Master
  • 19,396 Answers
When the CD does not read any disk, that is usually because of a problem with the optical laser lens that is dirty, faulty or opaque, and will start operating on certain disks better than others.
In that case you will hear disk spinning, whirring and clicking, but the TOC (table of content track at start of CD will not be read, therefore the error.
When this problem is beginning you may be able to read only CD, DVD or Blue ray, or for example only DVD-R and not +R , or only to read and not to write and so on. After more prolonged usage , often the unit goes losing the rest of functions, and ends up not reading anything at all.
If instead there is no noise, and disk does not spin at all , then there is a faulty motor, or the motor micro-switch is bad. This situation is far less common than the lens problem.
Try first using a CD lens cleaner disk to clean the lens. If that does not work you will need to disassemble the drive , and clean lens directly with cotton tips and isopropyl alcohol, or to replace the CD drive unit.
Posted on Apr 21, 2009
Problem when downloading file says installer integrity check has failed. common causes include incomplete download and damaged media. cannot install files.
If you're reading the file from a CD-ROM, then either:
* the CD-ROM drive is reading incorrectly,
* the CD-ROM is scratched, and thus cannot be read 100% correctly,
* bad RAM in your computer, that "corrupts" the data being read from the disk into the RAM.
Replace the CD-ROM.
Replace the CD disk.
Download "MEMTEST86+", and run it, to test the RAM; replace, if necessary.
Mar 26, 2010 | Computers & Internet
Will not read Data Disc
The CD Rom Lens has got spoil you can get another CD or give it to technician to help you change the lens of the CD
Mar 05, 2010 | Computers & Internet
Drive not spinning properly When I insert a CD, the drive can't spinning properly. So, the data can't read.
If your CD is no longer working properly, then it only mean that it has to be replaced. It is already defective.
It is cheaper to get a replacement, than get it repaired.
Nov 29, 2009 | Computers & Internet
Programs not reading the burner
you mean CD/DVD rom is not being found by ur system.
Well check out in my computer whether CD rom is displayed or not. and if not, then i guess u've to open ur cd rom. Dont worry, m not sayin u to open it completely, unscrew few screw from behind, u'll find a power cord from cd rom. adjust that. and also adjust the data cable connected. This might be a problem due to loose connections of power cord or data cord.
If still it doesn't works, then it might be ur system problem. try to restore it using System Restore in Accessories-System Tools to the date when u last used it...
hope it fixes u up....
Aug 27, 2009 | HP Pavilion DV6700Z Notebook
E: drive, cd rom drive will read a cd with data, but not a new cd
CD Driver or CD Writer encounter such problems are a normal reading in data. Sometimes it does or not. To identify the real situation on your CD/CDWriter drive is very difficult to you.
Here is the answer to your problem.
# You use your CD/CDwriter drive for how many long years and now got a problem.
# The speedometer of your CD/CDWriter (lens eye) can no longer read any available CD or have data's also or even BLANK DISC.
# Use any CD CLEANER to clean up your CD/CDWriter Drive to remove the dust inside.
Aug 07, 2009 | E-Machines emachines (emachinees) CD-ROM...
DVD/CD -ROM DRIVER
the same problem of mine is my drive cannot able to read DVD then i make the solution
if you have CD RAM/ROM + DVD ROM then change it to CD/DVD RAM because in case of CD RAM and DVD ROM it may read CD but not DVD but sometimes it can read DVD also but when we copy data to computer it may freeze or give us error so i give you one suggest to buy a new CD/DVD RAM
Jun 09, 2009 | Toshiba Satellite A205-S5804 Notebook
My dvd-rom won't play or read. it spin once and stop
You Know i had also this type of problem but i solve it i buy a new CD/DVD RAM
if you have CD RAM and DVD ROM then change it to CD/DVD ram because in case of CD RAM and
Apr 26, 2009 | Computers & Internet
Dvd fault
your laser is faulty and is only able to read cd tracks, the reason being that dvd's data is packed closer together than a cd, and when the laser is failing it can only read wider burned data tracks on cd's.
You will have to replace the drive
Sep 05, 2008 | Computers & Internet
Recovery
this is a READ error known as a CYCLIC REDUNDANCY READ ERROR.
If the CD ROM is not able to read from the disc .. it gives u this error
This can come due to many reasons
1. OLD CD ROM - not able to read data properly
2. CD with lot of scratches
3. CD not written properly: Data not burn properly on CD at the time of its make.
Solution: Try to insert a new CD in it and then check whether it works or not
or get a CD LENS CLEANER DISC which will remove any kind of small debris on the lens on the CD ROM and then it will work.
This would surely help
Feb 19, 2008 | Computers & Internet
Candy CDC266 Dryer Logo
44 people viewed this question
Top Candy Dryers Experts
Gerry Harvey
Gerry Harvey
Billy Detlefsen
Eddie Dalton
Eddie Dalton
Are you a Candy Dryer Expert? Answer questions, earn points and help others
