Question about Compaq (158272-001) Motherboard
My keyboard keep blinking
I have a computer that cannot boot.
the problem is when i turn on the computer lamp on keyboard blinking constantly and monitor got blank...
anyone can help me..... please....
  • kbg28 May 02, 2009
    my pc will not boot i get to the part where i enter my password or sign in as a guest but my key board will not work it just blinks.. i tryed a new keyboard but that didnt help!! ugh some one help me!! please!
  • 530 Answers
Hi im josh in cebu phils.may i help you friend? just try this solutions o mine this will help you.
ry re-seating the video cable. Try another monitor on this computer if you have one available. Try this monitor on another computer. That will narrow down where the problem lies. It's either the video card or the monitor which is bad. Of course if either is under warranty you may get a replacement, if not get your credit card ready :-)
I would also look at the cable connection and see if there are any bent pins. This has caused issues for me in the past. Just be careful rebending the pins if any are bent. They are fragile and may snap off. good luck friend
Posted on Mar 05, 2009
My hp xw4600 workstation beeps red light blinks on off
read the code the blink codes tell the story,
red lights where,
1: power button LED green? (can be red) and beeps
2: Monitor LED lamps?
3: caps lock on keyboard blink.
4: is the COIN cell dead? 2.9v to 3.3vdc good, lower volts is bad , as most are this old !!!
the service manual covers all this! ever heard of HP and there REAL pages,,???
why not read that?
(do the fans all spin, if not PSU is dead.
PSU fan is first. does it.
CPU fan , huge fan on heatsink must spin.
the stock GPU card has no fan (ASUSc card but mine does. at ATI fan right on the express 16 card.
does the DVD drive eject work.
if any of the above fail the PSU is bad.
but we strip off all loads from the MOBO
to prove its not some part shorted. first.
the front LED on this PC has flash codes
mine flashes in sleep mode, or w10 power off.
w10 never turns power fully off, it uses hibernate to turn off, (unless i cure that, ask)
the factory manual starting on page 111 cover this.
i own this beast so .....
code 2 red is overheated.clean the PC and all fans.
code 3 red, processor errors CPU.
code 4 PSU dead or shorts on load buses of same.
we call them power rails, we bench test the PSU
or read page 111 , how.
code 5 = GPU RAM failure, this PC has on board, GPU chip only X16 slot card, replace it. or the DDR2 rams are bad.
code 6 = GPU card bad.
code 7= BIOS ROM, put in a new coin cell first.!!!
Code 8= BIOS, always do nee COIN cell first.
code 9 = cant boot hdd, hdd bad or software gone, or corrputed, PC can now boot to a linux live CD or USB stick proving now PC is ok,
only hdd and OS suspected now. code 9
page 111 is here, 24/7 !
Sep 01, 2017 | HP Computers & Internet
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
Trying to replace lamp in HDTV and having trouble. Does not function correctly after putting in new bulb. Boots up and then visuals go black and the green power light keeps flashing. Help?
Panasonic DLP TV Bulbs
Make sure its an original Osram or Philips bulb inside the housing. If its a cheap lamp it will act this way. If it is an original lamp, then you may have a power supply issue. It shouldn't affect your TV but you may want to try resetting the lamp timer by following the instructions that came with the lamp.
TY-LA1001 Timer reset
While pressing the VOL- button on the projection display, hold down the number 0 button on the remote control at the same time for more than 5 seconds.
Aug 15, 2015 | Panasonic Pt-52lcx16 Projection Television
What does the yellow blinking light mean on Mitsubishi WD65837
Here is a whole list for you :
Mitsubishi Blinking Codes :
Constant Green - TV is Powered On
Constant Red - Lamp Failure
Constant Yellow - DMD temp is very high
Blinking Yellow - Lamp cover is open
1 Red Blink, 6 Yellow Blinks - Color Wheel Failure
3 Red Blinks, 4 Yellow Blinks - Lamp Failure
3 Red Blinks, 6 Yellow Blinks - Exhaust Fan Not Working
3 Red Blinks, 7 Yellow Blinks - DMD Fan is not rotating
5 Red Blinks, 7 Yellow Blinks - Ballast Problem
6 Red Blinks, 6 Yellow Blinks - Lamp Missing, Bad Cable between lamp and ballast
And the Lamp cover must be here somewhere in your TV :
For more you can refer to the below link :
Mitsubishi DLP TV Blinking Code Errors Explained Overview of Each...
Jul 07, 2014 | Mitsubishi WD 65837 65 in. HDTV
How to repair start-up on my computer
How long is shortly? If it runs and brings up the Windows Desktop and you are allowed to work for 10 minutes or longer then it shuts down, most likely the laptop is overheating. One way to tell if it is overheating is to immediately try to turn it back on after it shuts off. If it will not boot back up, it's overheating. If you let it sit and cool off for a while, then try to boot it back up and it does it successfully, it's overheating.Causes of Overheating:1) Dust all inside the computer. Fans clogged with dust, dust around the vents.2) Fan not working 3) The Thermal Past around the CPU has dried up or is too thin the keep the unit cool.When you plug in the power cord is there any lightswhatsoever on the laptop, where the plug goes in or on the AC Adapter of thepower cord?
When you press the power button do you hear fans running, hard drive spinning,lights on the computer, hear any beeps or lights constantly blinking, hear theDvD/CD drive click and the light on the drawer of the DvD/CD turn on for asecond or two? If so the laptop is trying to boot or may have booted, butthe screen is not showing for some reason.
Beep tones and blinking lights tells the technicians what is going on with thelaptop and why it is not booting. Most times it's a motherboard issuewhen you hear beeps or blinking lights continuous.
Mar 31, 2012 | Gateway Computers & Internet
Fan just work for seconds
Replace the fan or your computer will run hot and keep turning off.
Or are you saying this is what happens when you power on the computer? if so: When you press the power button do you hear fansrunning, hard drive spinning, lights on the computer, hear any beeps or lightsconstantly blinking, hear the DvD/CD drive click and the light on the drawer ofthe DvD/CD turn on for a second or two? If so the laptop is trying toboot or may have booted, but the screen is not showing for some reason.
Mar 28, 2012 | Computers & Internet
Power light keeps blinking Red and TV will not turn on
Is the light blinking constantly or is there a long pause then more blinking. If constant check the lamp door switch . Usually it is broken or jammed. If you jumper it and the set comes on that it. 4 blinks is bad fan.
Mar 24, 2010 | Sony Grand WEGA KF-42SX300 42" LCD TV
I cannot use my keyboard and mouse. Something is wrong with my devices
Make sure the keyboard is working in bios. When you boot the computer hit f2 or Del. key to make sure the keyboard is working. Also make a note that the keyboards light blink while turning on the pc.
If you are able to go to BIOS that means the keyboard is working fine.
Boot your computer in safe mode by tapping F8 key while the computer is booting. Select safe mode and check if the keyboard and mouse is working in safe mode.
If it is working in safe mode. Do a system restore to a date where everthing was working fine.
Please revert with the result of above .
Sep 01, 2009 | HP Computers & Internet
Computer won't start up and has a constant tone.
If the noise is constant then it means the problem is either:
1: a Power supply issue
2: a motherboard issue
3: a keyboard problem
the latter of the three being the easiest to fix, try booting with your keyboard unplugged or even better if you have another keyboard try using it to see if that corrects the problem.
If the above does not work then you have a problem with 1 or 2, and in order to find out for certain you will need to test it, you can goto your local computer diagnostic store to see if they can check which it is.
and hope its not a problem with the motherboard.
Hope this helps, and Good Luck
Apr 13, 2009 | Computers & Internet
Compaq (158272-001) Motherboard Logo
655 people viewed this question
Top Compaq Computers & Internet Experts
Alun Cox
Lee Durbin
Lee Durbin
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
