Question about Intel Motherboard
No disply my m/b is 845gvsr in prob no disply
  • 530 Answers
Hi im josh in cenu phils.may i help you friend? just try my solutions this will help you.]
All this video card and monitor business sounds fairly complicated although, if it's all running right, it's no big deal. Only when something goes wrong in the process do you need to get involved.
So what can go wrong? Here's a short list:
  • Your cables might be disconnected. If the cable from the video card to your monitor isn't firmly connected, all sorts of strange images can show up onscreen. Or, sometimes, absolutely nothing at all shows up. Cable problems are like that. So if you have a video problem, you should always check your connections, including the power cable. And while you're at it, make sure that you don't have any bent pins on your cable plugs.
  • Your monitor might need adjusting. Most monitors have the same type of picture controls as your TV set—contrast, brightness, and even vertical and horizontal hold on some models. Some monitors let you adjust the size and position of the display image itself. If your display doesn't look right, adjust it.
    tip
    no disply - tip_icon.gif To keep your monitor in tip-top shape, avoid dusty areas and strong magnetic fields. You should also use a soft, static-free cloth (or special "screen cleaner" wet pads) to clean your monitor screen at least once a week.
  • You might have a bad monitor/card combination. Believe it or not, some newer video cards don't work with some older monitors. In particular, you can't use a higher-resolution card with a lower-resolution monitor. Check with your dealer to make sure that you have the right monitor/card combination.
  • Your video card might be inserted improperly. The video card is just like any other expansion card in your computer. If the video card isn't seated in its slot properly, it won't work right.
  • Your video card might be set up incorrectly. Some video cards use either separate software programs or switches on the card itself to adapt to a particular monitor and system. If the card's switches are set wrong, the display might not work at all. Check your card's switch settings against those recommended in the card's documentation.
  • Your drivers might be set up incorrectly. If you've loaded the wrong video driver for your video card, you could get gibberish on your screen. If Windows doesn't recognize your video card, it will run a generic video driver—which will display the lowest possible resolution. It's also possible that Windows will recognize the wrong video card, mistaking your card for another card and causing all sorts of havoc. As is the case when installing any new device, you should always double-check your driver setup.
  • You might need a new video driver. Check with the manufacturer of your video card to make sure that you have the latest version of their video driver. Older drivers might not work with newer versions of Windows.
  • Your monitor might be on the fritz. If your TV can go on the fritz, your PC monitor can go on the fritz, too. If you get lots of lines onscreen, or smoke out the back of the monitor, or if nothing at all happens, suspect the worst.
  • Your video card might be bad. Enough said.thats all for now Good luck.
Posted on Mar 05, 2009
No display on my 845gvsr motherboard. when i am removing the ram from slot RAM beep is there. but after inserting RAM no sound nothing. is this the prob of IC beside the ram slot?? pls help
It could be one of two things.
your video chip is fried OR The software is missing. You will have to go online and find a bios upgrade for that Motherboard.
You'll need an video card fist to see what you are loading and then after reboot using motherboard video VGA
Jul 29, 2010 | Intel D845GVSR Motherboard
My v3000au compaq laptop i shut down then i try to on i"ts can"t on but the system was running no disply please help me
it must have caused some hardware probs...because many compaq has this similar prob and they were being serviced by the company by replacing the screen. better go to compaq service
Jul 13, 2010 | HP Compaq Presario v3000z Notebook
My 845gvsr motherboad showed no display problem,in...
If your keyboard linked three lights thats mean its not a problem of motherboard check your RAM or Connection of HDD.
Regards.
Andy
May 21, 2010 | Intel Motherboard
Intel 845GVSR Motherboard no display Problem
no diplay in this board give me sme notes to chag ic.what ic i did change
Jan 23, 2009 | Intel Motherboard
Power on lewd continuosly switching
remove your ram and clean it's print ande the ram ports of your computer . then inser ram again
Jan 21, 2009 | LG Studioworks 700S 17" CRT Monitor
Compatible processor 3.0 HT with 845gvsr board
if the processor you have is a pin type one or rather socket 478, yes it will be o.k
Jan 21, 2009 | Intel Motherboard
Cost of 1 gb for Intel 845GVSR drivers
i have intel 946 motherboard but its disply is intermediate
Dec 17, 2008 | Intel D845GVSR Motherboard
Booting problem
So i guess your problem that its taking long time On POST before switch to windows.
best possibility can be the disk drive connections, after checking processor ram and stuff its searching for drivers if you have any conflict on drives such as master slave configuration it will take bit time. take a look at drive setting hope this will help you.
Dec 18, 2007 | ASUS P4VP-MX Motherboard
Intel Motherboard Logo
122 people viewed this question
Top Intel Computers & Internet Experts
Tony
Alun Cox
David
David
Are you an Intel Computer and Internet Expert? Answer questions, earn points and help others
