Question about HP Presario C700T Notebook
I want to change bios in compaq per. v2000 dou have circuit guid
Hi frnd i have a compaq presario v 2000 laptop nd its creating a bios pro. and i want to change bios chip but i can't find exactly wich is the bios chip.
I was able to connect to my HP Compaq Presario V2000 Laptop to my WiFi Network using NetGear. When I reconfigured the network I could connect to all other network like Dell Lptop , Nokia Smart Phone and HP...
Hi!
Your Compaq V2000 has an Intel Pro Wireless 2200 BG wireles adapter. (doesn't support N, but that's not the point I think)
If your new network configuration is based on WPA/WPA2 encyption, this adapter has some known problems to establish a connection. It works great with WEP, but not so well with WPA.
Sometimes the issue can be solved by installing the latest versions of drivers and software for the wireless adapter.
If it still doesn't work, a known workaround is to disable via device manager all other network adapters in the computer (ethernet adapter), leaving active only the Intel Pro 2200 wireless adapter.
Hope it helped,
Bogdan
Sep 25, 2011 | HP Compaq Presario V2000 Notebook
When i switch on my compaq presario V2000 laptop it beeps three times and then freezes giving me the option to press f1 or f10 but when i press f1 or f10 it still doesn't work and is still frozen
Hi....
Actually beep sound indicates hardware error or BIOS error.
Don't press F10 while starting.
Let your laptop to start wait for 10min....
If it will not starts..........
Press F1(BIOS Settings for some pc F2 is Bois Setting)
If it will load BIOS.......... then your BIOS is OK
Then you need to change hard disk...
If not you need to change BIOS hardware(IF you i will tell you the way restore BIOS but it's very difficult task.It needs a trained person.)
Thank you have a nice day............
Feb 06, 2011 | HP Compaq Presario V2000 Notebook
Drivers for windows 7 for presario V2000
Compaq Presario V2000 Notebook PC has only drivers available for windows XP and 2000. HP has no driver download for Windows 7 for this model.
Please click here for reference
Regards
Riztech
Jan 13, 2011 | HP Compaq Presario V2000 Notebook
Compaq Presario V2000 laptop stuck on compaq logo screen
when turning on the system go into the BIOS and reset back the seeting s to factory defaults and reboot the system .. If this fails then reseat the Hard drive may have come loose or ?
did you recently add new software ? drivers ? hardware?
Oct 14, 2009 | HP Compaq Presario V2000 Notebook
Compaq presario v2000 is dead!!!
Well oviously when you dropped it, it had done alot of damage. There is defenently something in there that needs replacement. I can't acctually see the inside of your laptop so i don't know what. Go see a computer pro.
Jun 09, 2009 | HP Compaq Presario V2000 Notebook
Presario v2000 driver's needed
first instal the belarc advisor from this link  this will be detect your motherboard drivers, board no. etc. etc... after install u see the "main circuit board" details. u give me tht details it will be better to find the suitable drivers.
thanks good luck
Feb 22, 2009 | HP Compaq Presario V2000 Notebook
Hi, I need to Format my Presario V2000 notebook but i'm not sure how to perform this action, can anyone please be able to help me ? Thanks Dan
Hi Dan,
O.k. You will need to use the recovery or operating system disc. At start up you will ned to boot from the CD, do this by either entering the boot menu and selecting the CD drive, or entering the bios/set up and changing the boot order to where the CD drive boots before the hard drive. Both of these actions are done at start up, there is an initial screen that prompts you to press a key in order to enter the boot menu or bios/set up. Once you have booted from the CD, you will follow the steps and it will guide you through the process.
Jul 18, 2008 | HP Compaq Presario V2000 Notebook
Laptop just cuts out
update your laptop bios go hp.com see your proper model number of your laptop download new update bios and install it.
Mar 17, 2008 | HP Compaq Presario V2000 Notebook
HP Presario C700T Notebook Logo
89 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
