Question about Sony Ericsson w580i Cellular Phone
Imissed the data disk & cable now the batery
Imissed the data disk & cable now the batery so weak tell me sujastion
I bought my phone and it came with the data cable... i didnt need any PC suite or anything... when i connnect to the laptop, my phone asks if normal mode, transfer mode or print... i chose transfer mode and i was straightly connected... i had no need to use any PC suite or anything...
Posted on Mar 27, 2009
  • 53 Answers
If u hav missed the data cable u may hav to buy a new one
 the griver pc suit disk can be downloaded from internet in sonyericsson.com
Posted on Mar 05, 2009
Different hard drive
Turn the computer off.
Disconnect the power-cord.
Open the side-panel on the computer's case, to reveal the insides.
Disconnect both the "data" and "power" cables from the disk-drive.
Remove the disk drive.
Take the disk drive to a computer store, and tell them that you want to replace it with one that is the same PHYSICAL size -- you may get one that stores many more GB of data.
Insert the disk drive.
Reconnect the cables.
Close the cover.
Reconnect the power cable.
Turn it on.
Reinstall Windows.
Jun 16, 2014 | Dell Vostro Computers & Internet
Tip
BIOS error, System Failure, Boot failure? ? Lets FIX it.
I guess everyone working on a computer is familiar with the word BIOS and what exactly it is? Still let me tell that BIOS is intelligent software that enables the system to start. I need not to mention that system here refers to computer. Bios facilitate the booting of a system without human intervention. BIOS is a program that is installed in a hardware chip known as ROM chip.
This single word matters a lot to most of the users who face various problems when their system failed to start normally or make some unusual activities. Each time I visit any technical forum I see a lot many users posting their problem regarding BIOS. I researched on internet about BIOS errors and from my knowledge and experience I am posting this piece of help for those who find themselves helpless in getting a solution to BIOS problems.
Sometimes BIOS itself provide a troubleshooting to most of the problems. When you power ON your system it give beep sound. Checkout some beep codes
1 short Beep indicates System is OK (Acceptance Beep)
Continue long Beep tells RAM Problem
1Long 3 Short Beep confirms RAM Problem
2/3/4 short Beep --its time to Check the RAM & Video Card
By now most of you have found some clue about the problems you are facing. Now learn about POST faults
1) K/B Error/ NO Keyboard present
· Check the loose cable connector
· Cable may be bad (Keyboard)
· K/B itself may be bad
· Check the physical condition of K/B connector on M/B
· If all these are ok & problem is still processed
· Than replace the keyboard port
2) Floppy disk drive Fail
· loose data & power connector of FDD
· Data cable may be bad (FDD)
· Load the CMOS defaults
· Floppy disk drive itself may be bad
3) CMOS Checksum error
· CMOS battery has gone bad replace it. (Weak)
· Check the CMOS jumper it may set on clear
· If the entire ok than check the CMOS battery jack, it may be bad
4) Invalid System Disk, Insert System Disk & Press enter when ready/ NTLDR is Missing
· Check the root directory; it may be formatted or missing bootable files.
· Repair the Windows or Reinstall the operating system.
5) Disk Boot failure, Insert System Disk & Press enter when ready
· Hard Disk check in POST Detected or not
· If not Detected Check the power cable
· Check the Master/Slave jumper setting.
· Also check BIOS setting
6) Computer gives message: Your computer has a serious problem
Back up your data & replace your Hard Disk
This error message is displayed due to the SMART option. This scans the HDD for errors, if it detect the errors than it show the above message. Follow the error message & back up your data on to another drive.
I tried to explain most of the problems along with their solutions. There could be a lot more solutions for the problems. Make your own search and try to fix BIOS problems at your own home.
Forward this to all those who need help!!
SOVI
on Feb 09, 2011 | Computers & Internet
Very weak starting power. even with good batery and new engine starter
Assuming the engine is ok, your next possible cause would be a problem with one of the main battery cables or a ground connection.
The cable could be corroded inside.
Apr 15, 2013 | 1987 Chevrolet Corvette
My pc is not work properly show disk error........and press ctrl+alt+delete
Tell me in Details for getting better result 1) This problem occurs when window corrupted and 2) hard disk not responding. 3) Data cable not plugged. 4) Power cable not plugged.
Apr 26, 2011 | Computers & Internet
My aspire l310 won't boot. It keeps telling me media cable test failure and disk boot failure. Help daniel
sounds like hard disk related. turn it off and disconnect the power cord, remove and reconnect both the power and data cables to the hard disk, disconnect any external USB storage and remove any floppy disk, if any. If you get the same result, try to connect the har disk using different power & data cables (IDE/SATA), and test it on another SATA channel if available. If same error, you may need to reformat the hard disk and reinstall WIndows, or you may have to get a new Hard Disk if it fails even when tried on another computer.
Aug 31, 2010 | Computers & Internet
Honda cbr 929 headlight and turn signals dont work and fuses are good
headlight and turn don't come on all fuses are fine power to all connectors no short,how are these lights grounded or cdi trouble tell me what imissed thanks
May 22, 2010 | 2000 Honda CBR 929 RR Fireblade
When switching the machine, it takes long and
1. There is no electrical power to the disk-drive, i.e., a loose cable has become disconnected.
2. There is no data-cable to the disk-drive, i.e., loose cable.
3. The disk-drive's built-in electronics has failed.
4. The disk-drive's motor (that spins the hard-drive) has failed.
5. The read/write "heads" that move over the recording-surface of the disk-drive are "stuck" -- not moving when being commanded to.
6. Those "heads" have scratched a recording-surface, namely the part that contains the "boot" information part of MS Windows.
Those are the problems you could be encountering.
Now, the best "solution" is to take the computer to a qualified technician, for trouble-shooting, which may involve extracting the
disk-drive, and shipping it to a (expensive!) "Data Recovery Service",
who can repair your disk-drive just long enough to copy all your data-files to CD/DVD disks (or to a new disk-drive).
Jan 04, 2010 | E-Machines eMachines M5305DP Notebook
Handset is fully charged but phone goes blank after a few seconds
Try to replace you batery. It is not meant that a batery is still good when you gonna perform a charge.Because even it has the ability to accept power on it,it it will fast draining the stored power when a batery is weak due to the what we call low amperes .,the amperes of a batery is too small than the given specification when it is still new thats why it is so fast to drain its power.
Nov 05, 2009 | Computers & Internet
Can any 1 give me some tips????...............
i think u r not using a data cable for the file transfer.... u r using thatcardreader right... these card reader dont work with the micro sd cards... use a data cable it costs 140 bucks....
Nov 02, 2008 | Nokia 3110 Cellular Phone
System not detecting hard disk
is that a sata drive or ata?...if ata, try to change the IDE Cable that connected to your Hard drive?..
Feb 26, 2008 | Quantum Fireball Lct15 (QML20000LC-A) 20...
Sony Ericsson w580i Cellular Phone Logo
93 people viewed this question
Top Sony Ericsson Cell Phones Experts
Computer Repairing
Computer Repairing
Are you a Sony Ericsson Cell Phone Expert? Answer questions, earn points and help others
