Question about Kenmore 24032\24036 Top Load Washer
Kenmore top washer just filled with water and nothing else. no noise when I move the dial.
    Genius:
  • 1,122 Answers
Try putting it in spin,if nothing happens i like its your lid switch-mike
Posted on Mar 05, 2009
Stopped operating after filled with water for rinse
Have you tried moving the timer dial to other settings? will it work then? if not I would suspect a bad timer. If you are hearing the motor try and run but nothing else is happining you might want to have the couling to the motor and transmission checked out, these are common problems with these washers. Can you move the drum around freely? If you were hearing a grinding noise before this happened I would suspect the coupling, if not I would start with the timer.
Nov 13, 2010 | Kenmore 24032\24036 Top Load Washer
Will agitate; but won't go into rinse or spin - even if place the
If it will not spin/drain/advance timer or make any noise when you set it to do these options your problem is the lid switch. Your washer thinks the lid is up so it wont run as a saftey measure. You can order and install this item and its pretty easy and very common.
Dec 30, 2008 | Kenmore 24032\24036 Top Load Washer
Kenmore series 80 washing machine
This is usally a timer problem that is shorted
Oct 20, 2008 | Kenmore 22422 Top Load Washer
Won't fill
check to see if the water is turned on? do you hear a light buzzing or humm noise?
Jul 26, 2008 | Kenmore 98702 Stacked Washer/Dryer
Kenmore washer
ckd wires to motor ..next timer slim chance could be water level switch most likely motor wire
Jul 21, 2008 | Kenmore 24032\24036 Top Load Washer
Washer filled with water & then stopped & will not work in any cycle.
could be a bad pressure switch did it fill all the way is it a top loader or front loader any noise or nothing
Dec 31, 2007 | Kenmore 24622 Top Load Washer
Kenmore 24032\24036 Top Load Washer Logo
52 people viewed this question
Sal De
fordexpert
Robert Rankin
