Dirt patches sticking onto washing
Please help.. After wasing a load, scraps of dirt stick to the clothes.
  • Anonymous Mar 05, 2009
    same
  • 15,935 Answers
For low water volume - or "Trickling" effect...
1. Turn off the water supply to both hoses.
2. Remove hoses (one at a time so you don't get them confused)
3. On the washer side - look for a removeable screen inside wher you just removed the hose.
4. Using a small screwdriver - pop out the screen and reverse-flush it/clean it. It will likely be full of sediment and calcium deposits from your pipes.
5. Replace the inlet screens.
6. Re-fit the hose to the machine.
7. Turn on water supply valves.
8. re-try.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Posted on Sep 14, 2010
    Genius:
  • 1,550 Answers
You should use a warm water wash for dirty clothes with a warm rinse. Cold water causes more soap scum because it doesn't totally dissolve in cold water.
Posted on Mar 05, 2009
My Tromm washer is leaving residue on my clothes
Make sure you are using the correct soap. (Front load soap powder) Also use a bit less than suggested on the packet. If you are often using cold or low temp wash cycles, dirt and build-up in the machine will be common and come off on your clothes. Use a very hot wash at least once a month to clean it out and stop using fabric softener. It sticks to everything and any dirt in the water gets stuck on and then comes off in later wash cycles.
Sep 25, 2014 | LG WM2688HWM TROMM SteamWasher
The spin/drain cycle are leaving the clothes wet after wasing almost all the time.
Hi kerry_coorner,
Drain pump may be clogged. Please follow my below tip on the fix:
ACCESS, DRAIN & CLEAN THE DRAIN PUMP FILTER...
If this does not help, the drain pump may be faulty.
Kind Regards
JEDEMEYER1
* If this solution helped you, please rate it
Sep 11, 2011 | Whirlpool Duet GHW9150P Front Load Washer
The plastic part of the top of the raditor has crack do i need to replace the whole radiator or can the plastic be replaced ?
buy a fiberglass repair kit and patch the crack. The kit will come with cloth,resin.stick and sandpaper. Sand area,cut cloth,mix resin,use stick and apply to cloth. Hope this helps Tim
Aug 28, 2010 | 2001 Suzuki Grand Vitara
Washer sticks on wash cycle; runs continuosly on spin cycle
That sounds like you have one of them fancy water saving outfits with a diverter valve that dumps the pump water continuosly over the clothes. Weirdest washer I ever saw. Could be the solenoid that opens the drain pump has failed. Don't know too much about em but I do have the service manual. Post your model number for a more precise answer. Whirlpool Catalyst washer manual
Apr 24, 2010 | Kenmore 24032\24036 Top Load Washer
My washing machine is leaving small bits of black
FIXYA has no way of knowing what they are or where they come from .we have no field techs . suggest you call a repair service
Oct 26, 2017 | GE Profile WPRE6100G Top Load Washer
The dirt that comes off the dishes does not wash away
Is the filter screen over the drain at the bottom of the dishwasher clogged? Maybe the drain hose is kinked or clogged. If not, check the fitting where the hose connects to see if it maybe clogged. Please rate this advice. Thanks!
Aug 21, 2009 | Dishwashers
Dirt around the rubber insert!!
Your washing machine probably just has a build up of dirt in the basket. When you look inside the basket you see all those holes that are all over it. Dirt will stick inside there and after time will start coming out during washes. A simple thing that you can do to fix this is run some vinegar through the wash. Pour it in the basket, the soap, fabric softener, and bleach dispensers. Wash on hot and extra large load. Make sure no clothes are in it of course. This is something you can do every few months or so. Not only will it clean out the machine but it will clean out all the hoses and any hard water deposits. Your clothes will start smelling better and looking cleaner. Give that a try though. If your machine is 8 years old chances are this is the problem. Let me know if you have any other questions and let me know if this is helpful to you. Good luck and I am always happy to help out.
Jan 22, 2009 | Frigidaire ATF6000ES Front Load Washer
Need a diagram of where suspension springs attach ? Thanks
my whirlpool top load washing machine is overflowing when i try it on th start washind
Jul 26, 2008 | Washing Machines
LINT STICKS TO MY CLOTHES IN WASHER
linting is caused by a few things
firstly what sort of soap poweder do you use
i recomend good quality powder
do not wash clothes too long as what you are doing is rubbing all the fibres out of them
good quality washing powder only last about 6 minets in water and after that it looses its qualiteseg
the PH changes in the water
you may be using too little soap powder and this also depends on water quality eg too hard or soft water
is the water levels set corectly
do not mix washing
eg towels with jeans as the lint will come off onto jeans
try using delicate wash on different fabric as the adgitation is different on different cycles
try using warm wash and not cold machine is probable ok but wah times are important
good luck
Nov 27, 2007 | Crosley CAWC529JQ Top Load Washer
Black particles in clothes after using a top loading samsung fully automatic washing machine
You said these particles stick to the clothes, do they come off and then leave a stain? It may be grease or oil coming from a leaking drum bearing seal.
If it is, This is a major repair and not one for DIY.
Sep 28, 2007 | Washing Machines
Washing Machines Logo
44 people viewed this question
Top Washing Machines Experts
