Question about Acer Aspire 4720 Notebook
White blank screen
I start my laptop and after a few minutes the screen goes completely white and blank. cannot get anything to work on it. i have to manually shut it off, and when i start it again the same problems happens. little box appears on desktop bar saying blank screen windows
  • eshmel Mar 13, 2009
    have similar problem. Just blank white screen on startup. Happens randomly bore frequently of late
  • hobbatonz May 11, 2010
    hmmm, shot in the dark but. try and hook up a seperate monitor to your computer and start it up. oh and quick question does it atleast show load up screen where you can access bios?
    President:
  • 1,223 Answers
I think it is a some kind of virus in ur system try going in safe mode and let me know if still problem is there otherwise u have to reset ur OS to get rid of that and do protect ur system with good internet security like pc cillin or norton
restore OS simple procedure pls backup ur data first
When you first turn on the laptop and see the Acer logo screen, hold the ALT key and press the F10 key (you need to do this before the Acer logo disappears).
if there is a window showing in the taskbar blank
Posted on Mar 05, 2009
  • Shoaib Rais
    Shoaib Rais Mar 05, 2009
    Try going into Safe Mode. The desktop should work
    there. Go the Start line and type msconfig, open System Configuration.
    Go to the Startup tab and uncheck all the boxes. You should be able to
    reboot in normal mode. Go to System Configuration and recheck the boxes
    one at a time and restart until you find the cause of the problem.
    Uninstall and reinstall the program or what might work is to find the
    program's .exe file, right-click on it and select "Run as
    administrator".
My e525 laptop starts up, and after the big "e" logo the screen goes blank.* Whenever I press a key there's a loud beep. How do I fix this? *As far as I can tell the screen is blank, but it's...
Try this... 1. Remove the battery 2. Remove the memory for about 5 minutes 3. Re-insert the memory 4. Press ESC for about 3 minutes while putting the power adapter. 5. Then turn on without battery.
Mar 11, 2011 | Acer eMachines 520-2890 Notebook
Toshiba M300 screen turns white blank.
White screen means that your lamp (back light) is working absolutely fine, but you could have a loose connection for the data ribbon cable, which sends the images to the monitor.
Carefully open laptop to reach its lcd, there must be ribbon cable which looks like this: mrc-0069.gif
It is very sensitive so be very careful with that, very gently remove this from the chip and reconnect it.
Hope this helps, Please feel free to ask me any further.
Apr 10, 2010 | Toshiba Satellite Pro M300-S1002X Notebook
Dell vostro 1500 screen goes dark
Check the power options to verify that the screen is not powered down after to short a time. It is in the control panel under power options or in a Dell management utility
Sep 03, 2009 | Dell Inspiron 9400 Notebook
Display of My Dell Vostro 1500 goes 99% Blank/Dark After 1-5 min.
Try to repair your windows by using windows original CD. For best assistance you can watch this clip;
http://www.youtube.com/watch?v=KNOQ0sCYY8s
Please report back to the thread with results of your work.
Regards;
Hassan
Jul 22, 2009 | Dell Inspiron 9400 Notebook
Blank white screen in my Acer Travelmate 5730 Laptop
Hello Karthik,
This must surely be a problem with your monitor, because you say that you see the white screen while boot up. If this is a graphic driver issue, you may have the problem after booting up in windows. Since its been only a month old laptop, the product must be in warranty for sure. Take away any CDs in the drive, any USB drives and see if this white screen appears. Let us know.
Thank you!
Sabharish
Jun 26, 2009 | Acer LXA3706003 Notebook
Laptop LCD display problem
The backlight is the light bult that illuminates the screen. Before it finally goes out completely it will turn your screen a pink color on startup (and then usually become brighter and the pink fades). It is also possible that the backlight, also called a Cold Cathode Flourescent Light, CCFL, died an immediate death. But usually they take a while and signal with the "PINKNESS" first. If you found that your computer is working just fine connected to an external monitor (and you moved the base of your laptop around while connected to the monitor to be sure and left the computer on for a long time) then you have verified that the screen is the problem. It is usually two things: (1) the inverter, a circuit board that increases the voltage to supply the LCD which eats around 700 volts (yeah baby); or (2) the backlight itself. The first problem is a relatively easy and inexpensive fix. You can find how to replace an inverter by downloading the Hardware Maintenance Manual for the T40, T41, etc., from IBM/Lenovo's site. Replacing the backlight itself, a bulb that is like a strand of speghetti and even more delicate, is a tougher job. I would suggest purchasing a replacement screen in that event rather than replacing the backlight yourself. (The HMM probably does not show you how to replace the backlight/CCFL as it is a potentially dangerous job.) That suggestion assumes you can find a cost-effective replacement screen and do not mind opening the TP and putting the new screen in. At least look at the HMM to see what is involved. Good luck.
Apr 07, 2009 | IBM ThinkPad T42 Notebook
Phone does not turn on all shown on screen is a still hour
Pull the battery and reinsert, you didn't lose anything. ;)
Jan 19, 2009 | AT&T Blackberry Curve 8300 Smartphone
Blank Laptop Screen
unplug everything from your laptop unplug the power from the laptop close it and turn it over remover the battery open and hold the on button(battery is still removed) for a 10 count, replace the battery
turn on you can plug the power cord if needed the prob. should be fixed
Dec 26, 2008 | Gateway MX6956 Notebook
Acer Aspire 4720 Notebook Logo
349 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
