Question about Hoover U5025-900 Bagless Upright Vacuum
Need A manual for U5025-900 Hoover Sprint vacuum want to check if the filters are correct. Was given the vacuum, seems like there is very little suction for the hose. Any help would be appreciated
    President:
  • 1,901 Answers
Wasn't able to locate a manual, but you may be able to get the info you need from this page:
U5025900 Parts
If I find the manual I will post a link for it.
Posted on Mar 05, 2009
Hi, how do I check my hoover floormate deluxe spinscrub's filter and motor?
Hi Mike! To check the filter on the Floormate deluxe, remove the dirty water tank and pull up on tank lid to separate from the base. Check foam filter for debris, if filter has debris, rinse it with water. To prevent internal damage make sure you are using only the Hoover Floormate detergent. If the machine is still noisy and smells bad we recommend taking it in to a Hoover authorized service center. Follow the link to find the nearest service center to you. Hope this helps! Service Center Locator
Oct 20, 2014 | Hoover Vacuums
Hoover windtunnel powerdrive w/bag
its the gear.and the belt has to be fitted on the gears properly.
Aug 15, 2008 | Hoover U6311-930 Power Drive Bagged...
Hoover Platinum Cyclonic Bagless Upright Vacuum, UH70015 squealing sound
have you checked the belt for the brushbar it may av stretched and needs replaceing here is the manual on link below
http://hoover.com/file/556/
Feb 16, 2013 | Hoover U5780-900 Windtunnel Cyclonic...
Just not sucking like it did
the impella on the motor is clogged and needs to be scraped. dissasemble and its an easy fix from the bottom of the unit
Jan 23, 2009 | Hoover U5453-900 WindTunnel Supreme Bagged...
We need the OPERRATING MANUAL for Hoover Steamvac 6020-900
download the manual for hoover F5810 at hoover.com. it's the same for your model.
Jan 20, 2009 | Hoover F6020-900 SteamVac Upright Vacuum
Where do you put the filter
This is a motor filter.  It is usually located near the top or bottom of the front of the unit behind a little door.
Nov 28, 2008 | Hoover Vacuums
Hoover u 6401 bought v belt and drive belt the drive belt is to big, the roller will not turn, can someone help?
You will need to get another belt, it's common that the people pulling the parts are so busy, that they sometimes mistakenly pull the wrong part, or the wrong part number was given, even a misprint in the manual. Needless to say, it seems that you don't have the correct belt. There is no adjustment for belt tension, so it has to be the  wrong belt.
Nov 25, 2008 | Hoover Windtunnel Supreme U5280-900...
U5180-910 vacuum shuts off on own
I had same problem. Turned out to be the filter that sits above the waste cannister. Remove the waste cannister. There is a little orange lever that releases the filter. It was caked with dirt not allowing any air flow causing the motor to overheat.
This foam filter gets dirty pretty fast.
Nov 18, 2007 | Hoover U5180-900 Vacuum
Need instructions on how to replace the belt on a hoover dirt finder model u5321-930
You can download the manual from the link below: http://www.hoover.com/Media/ModelPDF/U5468900.pdf Please update the question & let us know if the information given was useful to you - Good Luck!
Aug 28, 2007 | Hoover 5416-900 WindTunnel Bagged Upright...
Hoover U5025-900 Bagless Upright Vacuum Logo
730 people viewed this question
Top Hoover Vacuums Experts
Gerry Harvey
Gerry Harvey
Are you a Hoover Vacuum Expert? Answer questions, earn points and help others
