Question about X2Gen MV32T8 32 in. LCD Television
WHERE TO FIND A POWER SUPPLY BOARD FOR 32 X2GEN
    Genius:
  • 1,550 Answers
You can get from the link below
Shopjimmy parts
You can find the parts for your tv .
Hope this helps .
Posted on Mar 05, 2009
I bought a used 42" X2GEN tv it shut it self off now it won't turn on at all the power light doesn't even come on
Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
Mar 07, 2016 | X2Gen Televison & Video
I have a X2Gen 42" LCD (MV42P) that has no picture
if there is no dispay in the screen atall then it has to be the screen or the unit controlling the screen which can be in the same unit as the screen sometimes also if you have replaced the power supply the main board and the controll board then there is either something wrong when fitting them or one of the units are faulty but i am thinking the screen mate i cant explain the sound it could be caused by the fact there is nothing to display meaning there is no picture being send and no sound,,,,
if you have any light atall in the screen when the tv is turned on this cant be the problem
it sounds like the input device is not inputing anything ie the hdmi or scart is not sending through and the tv and dtv are not sending this would explain why no screen and no sound because there is no sound or picture being send through and because the unit is broken there is not even any menus
Feb 24, 2011 | X2Gen HHE-MV42R 42 in. LCD HDTV
The monitor is going into sleep mode and not coming out easily or now at all. Yellow light is flashing and does not turn green. Started coming out of computer stand by with this issue a few weeks ago......
Sounds like the problem I'm having. Research uncovered a common problem with failed capacitirs on the power supply board. If you look at the tops of the electrolytic capacitors on the power supply board and any of them is bulging, you've found the problem. Check out http://lcdalternatives.auctivacommerce.com/Repair-Kit-X2gen-MW22U-DCAC0006-LCD-Monitor-Capacitor-P1799919.aspx for replacement capacitor set.
Nov 19, 2010 | X2Gen MW22U Monitor
Screen comes on for 2 seconds and goes black again - have tried unplugging all cables. All are secure.
There are two places to look for the problems, the backlight inverter board and the power supply. Look at the power supply first since it is easier to get to, look for burnt parts, bad capacitors, etc.
http://en.wikipedia.org/wiki/Capacitor_plague
Please post back what you find.
Nov 13, 2009 | X2Gen MG19MY 19" LCD Monitor
Screen goes black but power light stays on
Hello. I had the same problem with my X2gen 19" (model MW19R)monitor. In my case, the monitor would turn off after 20 seconds or so but the blue power light would stay on as well. I had to replace a high voltage capacitor located in the backlight power supply board. There are 4 blue capacitors on the board which are identical and they are marked as 27J 3KV. Fortunately, I only had to replace one of these capacitors ( it was turning a yellowish brownish color ). Hope this helps.
May 30, 2009 | X2Gen MG19VT 19" LCD Monitor
Front button sticking
use the remote to turn tv on and off
Jan 04, 2009 | X2Gen MV32T4 32 in. LCD Television
X2gen MW19R picture only stays on for one to fifteen seconds...
Dear Chris,
Visually check the component :
Try checking on the power board , may be ESR of capacitor is faulty and power resistor shorted and burnt.
Apr 11, 2008 | X2Gen MG19MY 19" LCD Monitor
X2Gen 19 inch LCD Monitor problem
Its the problem of the main display board. Not the SMPS. There will be another board inside. You have to replace the board or If some body may fix if you have spare parts of the board.
X2Gen MV32T8 32 in. LCD Television Logo
176 people viewed this question
Top X2Gen Televison & Video Experts
Computer Repairing
Computer Repairing
ray gallant
Are you a X2Gen Televison and Video Expert? Answer questions, earn points and help others
