Question about Konica Minolta Office Equipment & Supplies
We have two bizhub 920 setup with different IP addresses. When I added two printers, I can only send the print job to one but not the other. Any idea?
  • koomaster Mar 05, 2009
    Yes, I can only send I verified IP addresses and I can ping them and get the correct reply. It's working port but I will recheck it. Thanks
You mean you can only send to one of the BizHubs? Then you have obviously setup one of them wrong? Can you ping it? Ifd you can't then it certainly won't print. Are you sure about the IP address and configuration? Try another cable. The port may even be bad on your router. try swithing to the port that the working machine is plugged into.
Posted on Mar 05, 2009
Has a code 016-302 and will not work
This error is almost always caused by a corrupt print job or driver. If the machine was working fine it may be as simple as canceling the print job and restarting everything (computer and printer).
Before sending the job to print again, it would be worthwhile to print a test page. If you can, you know the issue is specific to whatever you're trying to print. If you cannot, you know it's a most likely a driver issue.
Other possibilities:
- a recent OS update/upgrade killed the driver. This happened to a fair number of Windows 8 users.
-You're attempting to print from MAC but don't have the printer/driver setup for postscript. Weird but true, even in 2015 PCs and MACS still use different protocols to print to laser printers. (Not an issue for ink jets)
If this is the issue, here are the directions to setup the printer and MAC to work on your network. Notice the printer (wireless or not) should be wired for config-
PRINTER SETUP:
(1) Connect printer to the ethernet port
(2) On the controler of the printer, select menu
(3) with the cursors (down) select Admin Menu, and press ok (the center key)
(4) the text "wired network" will appear. Press OK
(5) Move the coursor down to tcp/ip. Press ok
(6) "get IP address" will appear. Press ok
(7) select panel. Press ok
(8) press "menu" and repeat (1) to (5)
(9) "get IP address" will appear. Move the cursor down to "IP Address". Press OK
(10) with the coursor select write the IP address among the margins of your Router. The Gateway numbers shlould be the same as the ip number of your router. MAsK is always 255.255.255.0
(11) press menu and restart the printer
IN YOUR MAC
(1)Install the 3110cn modules version 2.1.3 Build 5 (usually in the CD, or in DELL site download area)
(2) Open Setup Print Utility and select "Add a printer"
(3) Select IP printer (any of the possibilities you are offered are ok), WRITE THE ADDRESS YOU WROTE IN YOUR PRINTER
(4)In printing using select Dell
You can move the printer to wireless, just keep the IP address the same.
Hope this helps!
Feb 04, 2015 | Dell 3110cn Laser Printer
Konica Bizhub C350, need to setup ip address
Utility / Administrator settings (pass:12345678) / Network settings / TCP/IP settings. Select auto IP, or enter it manually. You can check IP address by printing Configuration Page: Utility / User Settings / Printer setting / Print Report / Configuration Page. Press start.
Dec 09, 2010 | Konica Minolta bizhub 350 All-In-One Laser...
When networking, I can see the printer on the network, but when I send a test page, the printer immediately says "cancelling". I cannot figure what the problem is. Any suggestions?
There must be IP address conflict.
Check the Dell printer IP address
Open Printers and Faxes Folder
Right click on printer icon ( dell )
Click on Properties
Under Ports Tab check the IP address with check mark
If the Ports IP address is Different as that in Dell Printer
Highlight the Port with IP address and click on Configure IP below
Change the IP address to the Printer and Click OK
Also check if there are print job stuck in the Queue ( like no. 1,2 )
The printer icon should show READY and 0
Or Else, Right click on the printer icon and Click Cancel Print job.
Restart your PC and Printer and try to print. It should work
If this does not work, let me know what is the Operating system of your PC
Try this Step if your Operating system is Windows 7
Left click on Troubleshoot
Continue with the Wizard and complete it
You are ready to print.
Nov 02, 2010 | Dell 3000cn Laser Printer
Printing to bizhub c252 from one computer a problem
s it a shared printer? if it is, install the driver as a local printer
May 27, 2010 | Konica Minolta bizhub C250 All-In-One...
Bizhub 250 All-In-One Laser Printer: My bizhub c250 is going through a hub to a router....
Type in the ip address of the copier in your web browser. You should be able to log on to the web image monitor and even print a test page. If so you are 90% of the way there. Now go back to the printer setup screen in windows and click on the "port" tab then on configure port. Make sure the port ip address is the same as the copier and make sure the port number is 9100. Keep in mind that the ip address of the copier needs to match the ip address of your network for the first 3 sets of numbers. So if your network ip is 192.168.50.50 the copier would need to have an ip address of 192.168.50.xx
Good Luck and Thank You for using Fixya
May 17, 2010 | Konica Minolta bizhub 250 All-In-One Laser...
Command sent to printer but printer is not printing the document
First of all make sure your network cable is connected properly and has not come loose.
Most likely though is that the IP address has changed .
Do you know your printers IP address? Have an old copy of the configuration to compare it to a new one?
That machine is notorious for changing the IP address and I really suspect that is the problem.
You can try turning it off and back on.
You can check the job status queue and be sure the machine is not holding a job . It could be " held for resources." What that means is a job was sent to the printer and the print driver and settings on the printer are different. I will not print if those settings are different.
By that I mean, on the print driver, it sends a job for 8 1/2 x 11 plain paper. The machine settings say it has 8 1/2 x 11 bond paper or visa versa. If the settings between your computer and printer are different it will hold the job until they match. Look on your printer screen and be sure the tray settings are correct.
Jan 07, 2010 | Xerox Phaser 8560DN Laser Printer
Printer not receiving information from computer
I guess you mean the c350 is not printing while Windows said the job has been sent? If so, it may have changed IP Address from the time you first install the Printer on Windows. Check the Ports setting of the c350 printer! e.g. d53b002.jpg
Network Pritners should have Static IP address or at least a reserved DHCP IP Address. Logon to your Router, check the MAC Address of the c350 and reserve/assign it a IP Address near the end of the DHCP range. Save the Router configuration and power cycle the c350. Confirm IP Address changed to the reserved IP.
Then you have to change all the PC's Printer Configuration of the c350's Port to update the reserved/assigned IP. Or remove the c350 from Printers and Faxes, then run the printer setup software again.
May 23, 2009 | Konica Minolta bizhub 350 All-In-One Laser...
BizHub won't send scans to Macs
first, int the mac must have the "share for windows" checked, in the network settings.
second, you'll have to create a folder name SCAN into the 'home' folder onto your mac. then , you ll have to have your user and password of your mac.
then, you ll have to enter in the bizhub:
- Ip of your mac
- gateway of your mac
- mask of your network
on the copier
- in the utiliy/counter // register 1 touch, book adress, SMB (don t remeber exactly the path .. but just not so far of these paths), :
IP server: Ip mac
path : SCAN
user: user'sMAC
password: password of the user's mac (CAN NOT BE EMPTY)
and ormally, that's all folks :-)
Dec 03, 2008 | Konica Minolta bizhub C351 All-In-One...
Problem in configuring IP address in Konica Minolta bizhub 210 Copier, Printer, Fax
Is there network card is installed in it, if yes then you can configure it with your network go to machine Manu in machine control panel and the in network settings here you can give the IP address and subnet mask after then reboot the machine.
If network card is no installed behind the machine then you can use its built-in USB or and parallel printer without NIC card.
Feb 01, 2008 | Konica Minolta bizhub 250 All-In-One Laser...
Scanning
NotAnExpert,
I believe that you will be able to change that setting by using the web interface for the Konica Minolta.
Open your browser and enter the following:
http://xxx.xxx.xxx.xxx
xxx.xxx.xxx.xxx represents the IP address of your Printer.
This should open your configuration interface. In the center of the page there should be a series of tabs: System, Job, File, Print, Scan.
Choose Scan and toward the bottom of your page you should see the destination folder that goes to your now defunct computer. Click on that folder and it should bring up the Job Type Page - yours should be set to File (Scan to PC). Select next and it should allow you to enter the name for the new folder and the IP address for the new computer.
I hope this helps.
Nov 08, 2007 | Konica Minolta bizhub 350 All-In-One Laser...
87 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
