Just setup this printer using a parallel connection to a new computer with Widowws XP Pro on it. I checked to HP web site for drivers and there are none, but they gave instruction about configuring the port - which I did. ( settings are use any interupt, ecp port setting and auto find). When I started the computer it went though the process of finding the printer and all went and looked as it should. Whe I send a page to the printer the printer makes a little noise but that is all. When I restart the computer it prints a page but the page only has one funny looking little circle in the upper left corner. Any idea as to what the problem is. Wish this printer had a USB port but it does not.
  • raymondh801 Mar 05, 2009
    HP Officejet R40xi. Sorry I was doing a search on this model and thought that information would be attached
  • raymondh801 Mar 15, 2009
    I wish there was a HP driver for this printer - it only uses a windows built in driver. It set that driver up on the install and shows it as the correct printer. The settings are correct as to lpt port number and ecp port. Everything looks correct but only prints a tiny circle on a page when doing a windows test page. Any other ideas?
    Thanks
    Ray
  • 19,396 Answers
If you follow the instructions here , and the printer still does not work, then test the printer on a different computer, the printer may be faulty.
Posted on Mar 15, 2009
    Scholar:
  • 164 Answers
Please double check in your Control Panel - Device manager that your Printer is currently installed hardware - and there are no conflicts.
Also, Make sure that your printer is set to print as "default" so the documents prints to the printer.
Update with the latest Drivers too, from HP.com site.
I hope these helps,
Thanks.
    Novelist:
  • 166 Answers
Please provide model number of your printer.
Posted on Mar 05, 2009
    Genius:
  • 1,550 Answers
What is your model ?
  • SAM ANDERSON Mar 05, 2009
    If you have not installed the driver file . You will not get properly printed document .
    There is driver file for this model . You can download from the link below
    Driver for HP Officejet R40xi
    Select the OS and download the driver file and install it .
    Hope this helps .
    For further help feel free to ask .
My new computer does not have a parallel printer port. My old 840C printer has both parallel and USB ports, though I only ever used it with a parallel cable, so I tried connecting with a USB cable. The...
Hello and welcome draepeacock !
The only solution is a workaround :
If you have the W XP install disc , you can install a virtual version of W XP on your machine from http://www.vmware.com/products/player/
If you still have the install disc , you can also partition your primary and install W XP on the new partition from http://download.cnet.com/Partition-Wizard-Home-Edition/3000-2094_4-10962200.html.Back up your data first.
Both are easy and safe , no specific knowledge required .
Regards .
Feb 14, 2011 | HP DeskJet 840c InkJet Printer
HP DESK TOP 840C PRINTER CONNECTION
They do make adater cables for such problems. Here is just one such example: Parallel to USB Cable
Make sure you get the correct 25 pin cable. They have this type also:
Parallel to USB Cable 2
You can search the web for more companies. Google parallel to usb printer cable.
After saying all that and checking your printer info, I see that the 840c has both a parallel and a USB cable port. See page 21 of the manual: HP 840c Manual
If you go that route, you will need a standard USB cable. The shorter the better, but no longer than a 6' cable. Make sure you follow the iinstallation instructions for the USB setup in the manual.
Thanks for using Fixya.
Apr 14, 2010 | HP DeskJet 840c InkJet Printer
Setup without disk
In most cases you can download the drivers from the manufacture's website.
Mar 26, 2010 | HP PSC 2355 All-In-One InkJet Printer
Problem with printing on HP 6L
Make sure the parallel port is enabled in 'setup' (bios) (make sure to exit and save even if no changes were made). If you are running 'Vista', you may need to update the driver from HP.
Aug 24, 2009 | HP LaserJet 6L Printer
Strange Printer Issue - HP Laserjet 2600n
The last time I checked, you cannot set up a local printer using a TCP/IP port. A local printer is physically connected to a computer via a parallel, serial (very old), or USB cable. If the printer is connected to a switch, hub, or router via an Ethernet cable, it is by definition a network printer and the driver install must reflect this. I don't understand why it is able to print out the test page after the install. If you open up Control Panel -> Printers and double-click on the HP Laserjet 2600n in there, it will bring up the local spooler for the printer. You may have a bunch of print jobs queued up in there that it cannot currently send to the printer. You may want to clear the queue first (cancel all print jobs). Let me know if you have problems clearing the queue & I can give you instructions on how to do that one too.
Apr 23, 2009 | HP Color LaserJet 2600n Printer
Print Job enter's queue, but doesn't actually print.
hi thanks for using fixya!
Do you have 32bit or 64bit system?
Mar 24, 2009 | HP LaserJet 4250n Printer
Cannot get scanner to work with Vista or XP
you will have to uninstall the scanner drivers from the computer in the control
panel>scanners..then uninstall the printer drivers from the orinter in the control
panel and then run the wireless setup wizard on the printer then try reinstalling the drivers and the s/w using the disc that came with
the printer......see if works
Feb 24, 2009 | HP Photosmart C7280 Laser Printer
HP4500 Color laser and setup using USB
just try to change the LPT1 port to usb port..
Oct 28, 2008 | HP Color LaserJet 4500n Printer
Driver Needed
Here is the general driver download page for your printer
regards
Feb 22, 2008 | HP OfficeJet Pro 1170c InkJet Printer
Hp laser jet 5si
Can you be more specific in the problem?
Also, please specify "how" you are connecting to the printer (parallel, LAN, etc)
Nov 30, 2007 | HP LaserJet 5si Printer
jasbo
jasbo
