Question about Kenmore Dryers
Will not dry clothes fully. the machine heats fine but it takes two or more cycles to fully dry a little load. someone told me about a part that may need repaced around the lint trap.. Any ideas?
  • Kenmore Master
  • 3,361 Answers
Your lint exhaust is blocking the heat flow.
Remove the vent from the rear of the dryer and run a timed cycle load for 40 minutes.
If laundry is dry, repair the outside vent.
If not dry,open the dryer cabinet and clean the inside lint and heat vent.
Posted on Mar 05, 2009
We have to put only a half load of clothes in dryer and then run through at least 2 - 3 cycles before they will dry, sometimes more. Someone told me it sounds like a sensor might be bad, and that there are...
A simple fix may be to just reset the circuit breaker. Sometimes on a double pole circuit one breaker trips which still allows for the dryer to operate with little or no heat. If that does not work, check the vent to insure good air flow and no blockage. If either of these do not resolve the situation you need to look at the thermostat or the heating element itself
Feb 27, 2011 | Dryers
Haier washer/dryer combo not drying clothes
Check things like the Filter / clear fluff...Make sure outlet hose if any is not kinked and passing air..Hope this helps..
Oct 02, 2009 | Haier 14.3 lb. Washer/Dryer Combo
Old dryer not drying clothes quick enough. takes two cycles of 70 minutes to fully dry one load
Either your heating element is going bad or your dryer vent is plugged with lint causing moisture not to escape.
Sep 23, 2009 | Dryers
Smeg wdf1 washer dryer not drying clothes. Wash cycle fine but no heat produced when drying- any idea where to find/check the fuses/elements?
Hi, Take the top cover off and click the little red button on the thermostat/overload (small black box). Then try again. Sometimes these trip out as a safety precaution.
Jun 13, 2009 | Smeg WDF16BAX Front Load Washer / Dryer
2 to 3 cycles to fully dry clothes
if the clothes are warm after the cycle then you need to make sure the vent to the outside of the house is not plugged if they are not warm then it is in the heating circuit of the dryer wether it be the element or a fuse will have to be tested. to dry clothes it takes heat and air flow if you dont have one of the two they will not dry correctly
May 18, 2009 | Kenmore Elite Oasis 6808 Electric Dryer
Dryer heats up, but won't dry clothes well
Also check your vents in the machine and the wall. Pull the machine away from the wall and feel how strong air is coming out. After cleaning the machine, run it one load disconnected from the wall, and one load connected. This will tell you if your wall vent is clogged.
May 09, 2009 | Dryers
Gas dryer heats fine but shuts down before the drying cycle is over taking longer to dry clothes. Lint trap and exhaust tube cleaned out.
You are going to most likely need a vent cleaning. The dryer is getting too hot and shutting off because it is not exhausting good.
Apr 29, 2009 | Kenmore 94702 Front Load Stacked Washer /...
Asko Washer/Dryer (WCAM 1812); Dryer not working.
Update: The dry cycle is now working! Apparently the automatic overload/shut off on the heating element got tripped. We had a technician out this morning. He unplugged the machine, removed the top of the unit, and simply pushed a little red/orange button that was on top of the heating element. When we plugged it back in the heating element worked again. The technician was able to troubleshoot this by checking the amps while running the dry cycle. But the proof was really when we did a load and the machine heated up (just like it used to) during the dry cycle. This was actually a relatively simply fix - though could be dangerous as you have to open up the electrical area. The reset button is rather inconspicuous and located on top of the heating element, which is long (runs front to back in the center part of the top of the machine - which you can get to by removing the lid/top outer housing) and silver - wrapped in insulation. It's pretty obvious. The button is in a little metal fixture on top of the heating element. The technician told us that the rest can get tripped when the unit overheats. (We think this happened when the laundry tub overfilled and the hose was totally submerged - the machine was working overtime to pump out the water.) The technician also warned that this can happen if the machine gets turned off suddenly mid-cycle - especially during the drying cycle. He said that the heating element gets so hot, it needs to have a gentle cool down period, which is marked on the dryer dial for the last 20 minutes of the cycle. I hope this helps others!
Mar 08, 2009 | Asko WCAM1812 Front Load Washer / Dryer
Forgot how to use
Doing a Load of Wash for Portable/ Kitchen Faucet
1) Make sure machine is set to Cold/Cold and never use Hot/Cold button (Hot/Cold is only for permanent hook-ups). Connect water hose to kitchen faucet. Turn on water to temperature of choice.
2) Load machine half to three-fourths full of clothes. (only half full is recommended if you intend to use the dry cycle right after the wash cycle. For half loads, push in the half-load button. )
3) Add detergent and fabric softener:
a. Liquid detergent into 2nd slot: only 1 tablespoon, 2 tablespoons maximum
b. Fabric softener into 3rd slot. this really helps in preventing wrinkles
(****NOTE: THE MOST COMMON AND MOST DAMAGING ERROR IN THE USE OF FRONT-LOADING MACHINES IS OVERSOAPING. oversoaping causes - pump failure, drain failure, etc. - none of
which are covered by the warranty. The only reason top
loaders use so much soap is because they use so much water and this dilutes the soap. Also, always use detergents that have an HE -- High Efficiency -- rating.)
4) Select Wash Cycle
Permanent Press is likely to be fine (32 minutes) as the USA has softer water than in Europe for which machine was originally designed. Hard water, as in Europe, means it requires more detergent and more washing motion than in the USA. Prewash and/or Superwash (53 minutes) might be preferred for dirtier clothes.
5) Select Spin Cycle
600 should be fine. A higher cycle means dryer clothes, perhaps more wrinkles, and certainly more noise. (Malber USA suggests 800-900 as the norm).
6) Make sure Spin cycle has cold water.
Faucet should be changed to cold water AFTER the initial fill even if you are not drying - all rinses should be in cold water for more complete removal of soap residue
If you use Dry Cycle
7) Select time for desired dry cycle. Make sure to change the faucet to cold water. If you do not want to use Dry cycle, select 0 minutes. Otherwise, use 120 minutes the first time until you can gauge what types of loads require how much drying time. Here's how the Dryer works: A heating element inside the washer heats up the load. During the dry cycle, as the cold water from the faucet circulates into the machine (in tubes, not mixed in with the load), it cools the steam and condenses it into liquid water which is pumped out.
After Wash & Dry
8) It takes approximately 90 seconds after the cycles are completely done before it allows you to open the door. Malber USA says it is due to safety requirement of UL. Who knows what UL security feature is for. Perhaps extra time to finish draining.
9) door slightly ajar to let the machine dry out. I have read postings that say the machine becomes smelly with mildew if you do not. Malber USA says this is true for all horizontal axis (front-loading) washers.
Most common complaints
1) Using too much detergent.
Front loader machines do not need so much water, and thus not so much detergent. Also USA water is softer than European water, for which the machine was originally designed, and that may explain why the detergent compartment is so big to hold more detergent. Soft water is easier to get suds. Damage is caused by suds. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element.
2) Dryer does not work, for several main reasons:
(thanks to Malber USA for points a and b)
a) the system may have overheated, tripping the safety thermal switch. This switch is located under the top of the machine and can be easily fixed by the consumer.
b) broken working thermostat. It is a relatively inexpensive repair to remove and replace this part and takes only about 10 minutes. It can be done by the consumer but it
is recommended that a qualified tech do the job.
c) Machine is too full and/or fabrics are too heavy.
Even though you can wash a maximum load of 11 lbs. of clothes, the manual suggests to dry no more than 7 lbs. of cotton clothes and 5 lbs. of heavy or extra large fabrics. Thats because the dryer works by heating up the clothes and then condensing the steam from the circulating air into liquid water which is pumped out. If the machine is filled too much or if the fabrics are too dense (e.g., jeans), the system cannot condense enough water and the clothes remain humid. Perhaps a second 2 hour dry cycle could work, but who wants to dry clothes for 4 hours.
d) Broken heating element
Seems that the heating element breaks after 2-3 years and needs to be replaced. And why is that? Most common reason for heating element failure is oversoaping. Suds migrate up the hot air duct during wash cycle and come to rest on the heating element. After repeated occurrences, suds (which are corrosive) will cause rusting and eventual failure of the heating element. But many people simply choose to not use the dryer rather than have it fixed.
Hope this works. Please be sure to rate me. thanks
Apr 17, 2008 | Malber WD1000 Front Load Washer/Dryer
Broken washer/dryer
This sounds like a motor control board is faulty. Please load a couple of towels in the machine run it. Watch the machine as it goes through its' cycles.
1. Do the towels tumble when the machine is washing ?
2. When it begins to spin, does it spin one way at a fast pace or does it spin one way and then the other ?
Answering these two questions will help in troubleshooting your problem.
Jan 07, 2008 | Kenmore Elite 45986 Front Load Washer
Dryers Logo
261 people viewed this question
Top Kenmore Dryers Experts
Dan Webster
Dan Webster
Sal De
Tim Whalen
Are you a Kenmore Dryer Expert? Answer questions, earn points and help others
