Question about Pioneer Audio Players & Recorders
Connecting home reciever,equalizer an spectrum analyzer.
I have a Pioneer VSX-505S reciever,a Reference 210EQ 20 band equalizer made by Quadraflex and an SX-100 Realtime Frequency Spectrum Analyzer made by BSR.
I'm trying to find out how to wire both these accessories on the reciever.along with the usual cassette,cd,vcr,dvd units
2 Suggested Answers
tvservice306
  • 458 Answers
SOURCE: Pioneer VSX-5300; sound cutting out
try open each speaker test may be speaker or wire short....if all ok check pcb solder side....
Posted on Dec 31, 2009
I just want to know if I can run a turntable through this unit
You can connect some turntables to the VSX-54TX. The turntable needs to have a built-in phono equalizer; then you can connect it to the Line In connection. See page 26 of the manual for the details. The manual is available on the Pioneer product page: http://www.pioneerelectronics.com/PUSA/Home/AV-Receivers/Elite+Receivers/VSX-54TX in the Manuals & Brochures section. The current direct link to the manual is http://www.pioneerelectronics.com/pio/pe/images/portal/cit_11221/128163968VSX-54TX%20OPERATING%20INSTRUCTIONS.pdf .
I hope this helps. If you post a comment with the model of the turntable, I may be able to help identify if it has the built-in equalizer.
Nov 17, 2015 | Pioneer VSX-54TX Receiver
Im having trouble hooking up my equalizer to my Pioneer audio/video multichannel receiver vsx-814
Looking at the back..bottom right corner is CDR/Tape in and out. Connect the in on the eq to the out of CDR/tape, connect the out of the eq to the in of CDR/tape.
You should then be able to use the CDR/tape monitor button to switch the equalizer in and out.
Sep 25, 2014 | Pioneer Audio Players & Recorders
I have a pioneer VSX D-308 RECIEVER and a electro-voiceevt 2210can it be hooked up together
The Tapco equalizer was a very popular line of equipment which was eventually bought up by Electro-Voice. Could not find any online manuals, however found online images of back panel. It appears to have Tape Ins & Outs.
Unfortunately the equalizer you have is not compatible with the receiver unless you have special cables that have built in transformers. This unit has T&R connectors (tip & ring) meant for professional sound equipment.
On a typical home stereo receiver you would hook up your equalizer with RCA connectors as follows.
1) You take the output of the equalizer and plug it into the input of the receiver.
2) You take the output of the Receiver and plug it into the input of the equalizer.
Start with lower volume and your tape switch on the receiver to the on position. Play with the various controls on your equalizer to
Apr 17, 2014 | Electro-Voice Tapco Graphic Equalizer,...
The reciever sounds like the speakers are shorted out. I can hear the audio at about 3/4 but it is distorted and not load at all. Is there an internal fuse that may be shorted out? Thanks for any help
Just disconnect the cables, use a fresh set and validate the connections from the receiver to the speakers... This happens when it's cross connected or you have the speakers connected to the Sub connection. Just validate the connections from the user / connection manual that you should have received with the set
Oct 16, 2013 | Pioneer VSX-505S Receiver
I cant seem to hook my pioneer gr 470 equalizer to my pioneer receiver ( vsx-403) what is the proper connection sequence?
tape out from reciever to line in on the eq --then line out from the eq to tape in on the reciever --whenever the tape monitor will be used on the reciever the sound will then be equalized
Sep 02, 2010 | Pioneer GR-470 Home Equalizer
Dec 31, 2009 | Audio Players & Recorders
Owners book / manual for Pioneer receiver VSX-605s
www.pioneerusa.com then support. I could not find your "Exact" model, and it could depend on where it was purchased. Look at units closely labeled to yours and chances are it will be the same with a different #. Hope this helps
Aug 16, 2009 | Pioneer VSX-505S Receiver
Receiver - manual service
Still need to solucção pioneer VSX-605s and-505s not VSX. I want to thank the provision of his plan. I am more in search of the manual services of receiver VSX-605s ....
Oct 14, 2008 | Pioneer VSX-505S Receiver
Pioneer VSX-505S Subwoofer Installation
That type of subwoofer is not used with this receiver. This receiver actually outputs no power for a subwoofer, therefore only needs a plain ol' rca signal wire. This is due to the fact that you need a powered sub... one that you plug in to the wall and it has its own built in amp. you simply run an rca from yyour 505s to that sub.
Feb 10, 2008 | Pioneer VSX-505S Receiver
171 people viewed this question
Top Pioneer Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Pioneer Audio Player and Recorder Expert? Answer questions, earn points and help others
