Question about Pentair Pool & Spa
Pentair Mini Max , no power to igniter. Heater would not ignite so I pulled cover and found broken igniter so I replaced it and still it will not glow when gas valve attempts to light. I can smell gas.i checked with volt meter and there is no power to igniter. What is my next step. Joe
  • bulldogsja Mar 17, 2009
    I found the ignition module to be bad. I replaced it and it works. Thank's for the input. Joe
  • 35 Answers
You may have to reset your board.turn all power off to the unit then turn it back on.if this doesn,t do it make sure you have a good complete circuit from board through element then back to ground.
Posted on Mar 17, 2009
My pentair 52018 controller also turns on a firebowl...it ignites fine but shuts off after 10 seconds...we just replaced it because it was doing something similar with the spa heat...
The Pentair should not be controlling the fire bowl ignition, only the power to the fire bowl. The ignition will be controlled by a separate system designed for the bowl. The spa heater is controled by the pentair via a water temp sensor and the heater has it own onboard ignition system. Have someone qualified look at the fire bowl, sounds like a flame sensing issue.
Dec 31, 2016 | Pentair Pool & Spa
Can Mini max ch 250 M be converted to LP
not advisable safety orfices nad gas valve and regulator to be changed then mark unit propane
Jun 15, 2012 | Pentair Minimax Ch 250,000 Btu Natural Gas...
When I turn my mini max plus 400 heater on it clicks then nothing happens, what's up with that
If it is clicking it is trying to fire (calling for heat). This indicates that the internal safety loop Tstat, and IID are working. It is either a bad gas valve, your ignition wire, or lack of gas. If the gas line had been open for servicing for any length of time it can take a while for all the air to get out. Best call out a tech to do the repair, you are literally playing with fire.
May 15, 2012 | Pentair Minimax NT Heater
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Mini max 100 pool heater. Propane tank full pilot won't light
hello. i can help. if you have propane but you can not get the pilot to light your thermocouple needs to be replaced. this is a common item available at any hardware store.
Jun 25, 2009 | Pentair MINIMAX NT TSI IGNITER
NT mini max not heating at all - won't fire
wow t pool service is just guessing i guess . weel let see do u have a pilot if yes do u hear a click if yes clean t burners if not check 24v at t brown wir e for t gas valve if v replace gas valve if not replace ignition control . do u have any code on t back or t front this help a little.
Jun 14, 2009 | Pentair Minimax NT Heater
Heater min max nt powers up but will not call for heat
I replace the ignition module . I did not recieve from your company i never got a reply to my problem. please notify me when my credit card payment has been reversed.
May 18, 2009 | Pentair MINIMAX NT TSI IGNITER
Pentair mini max will not ignite. I have no power to the igniter so the igniter will not glow. I have a volt meter and some experiance. the gas valve doe's release gas for a few seconds.What steps should I...
Does it attempt to start (meaning, does gas valve open and ignitor turn red hot, and heator starts and then turns off) Then repeats the cycle and then after 3 attempts gives you an error code..
Mar 05, 2009 | Pentair 1.0 Hp Whisperflo Pump
Gas will not stay ignited
could be dirty heater you have to clean the runners and the smole nozzles that are in the manifold below the gas valve it's like a 9/16 size you pull them off and check make sure they are clear through, sometimes little spiderwebs build up inside them. if it's all clean, then it could be you flame rectifier/ aka: flame sensing rod, that tells the htr that there is fire so it keeps running. Let me know what happened.
John
Dec 29, 2008 | Pentair MINIMAX NT TSI IGNITER
Pool & Spa Logo
1,020 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
