Question about HP Office Equipment & Supplies
HP Laser Jet 2420dn - printer I have got ''4C02 - Service Error'' message. What does it mean? Thanks for help.
  • 154 Answers
A single file, it could be that file. It could also be related to the individual software sending the print job, bad print commands or invalid. Although rare, a bad cable or connection can be to blame.
First step is to restart the printer, clear all jobs with the Stop button, restart printer again. Then try printing from another program, such as txt editor. If ok, then print a different file from original software, if ok, then print original file.
If failure is with final print, the file is corrupted for printing, recreate file.
If failure is with original software see if there is any updates.
If failure is there directly after restart, try updating printer driver (this is not be a bad idea anyways).
If none of this works, it may well be a formatter board issue, requiring technical service.
Posted on Mar 05, 2009
Error Code 49:4C02
this is a communication error, often caused by a `corrupt' print job, or printing things off the internet with complex non-standard languages.
If you unplug the USB or network cable and power cycle the printer, and the error goes away, that is usually the problem.
You can usually isolate it to a specific job, like printing an email.
The problem can also be the network card (if installed).
Apr 03, 2014 | HP LaserJet 2420dn - printer - B/W - laser...
49.460E service error in HP Laser Jet 2420dn printer
This issue comes when your data proper transfer from your computer.
1 check data cable (USB or Lan cable)
Oct 29, 2013 | HP LaserJet 2420 Printer
Hp laser jet 2420 printer 50. error
This is an error with your need another fuser...any 50.x error is related to that and they are something that needs replacing regularly(100-150k pages) the heat resister goes out or the film tears..ect....Try for a good deal on a used one...Used are normally just as good as new for a lot less and these guys guarantee their units, they have someone you can call on the phone, so I recommend them. Hope this helps you.
Oct 25, 2010 | HP LaserJet 2420dn Printer
49,4c02 error to continue turn off then on
I would try clearing your print que as it could be a corrupt print job and disconnecting your network cable and reboot the printer, make sure you have the latest firmware. hope this helps
Nov 24, 2009 | HP LaserJet 4700 Printer
Hp 5500 dn with 49 4C02 error
Replace the jet-direct card. don't forget to install the IP address on the new card.
Apr 14, 2009 | HP LaserJet 4350TN Printer
Service Code 49 4c02
Try to upgrade the firmware on the printer, if that error still occurs after the firmware upgrade, you should try and use PCL driver rather than PS driver.
Apr 10, 2009 | HP LaserJet 4700 Printer
Is HP Laser Jet 2420n
Duplex on this printer is manual, that means that you will have to re-insert the paper by yourself.
This if you have the 2420n, the 2420dn instead is the duplex model.
Here specifications, look where it says duplex, 2420n had only manual duplex (the printer wait for you to re-insert page).
Feb 17, 2009 | HP LaserJet 2420n Printer
49.4c02 service error coming in hp laser jet 2420dn printer
This is a firmware error, you can try turning the printer on and off a few times, reseating any memory and the formatter board. If these steps don't work Go to http:
support/lj2420, or
Click Download Drivers and
. Check for the
latest firmware image version
at the bottom of the page. If
this firmware image is newer
than the one installed on the
printer and the printer can
receive a firmware update,
download the newer firmware
upgrade. Not all printer
models can receive firmware
If still no joy replace the formatter (this is the normal coarse of action)
Aug 13, 2008 | HP LaserJet 2420dn Printer
LaserJet 2420dn Error
The error means -
A critical firmware error has
Recommended action
1. After performing the actions
listed in the preceding item, if
the message persists when
using different software
programs and attempting
specific print jobs, disconnect
all cables that connect the
printer to the network or a
2. Turn the printer off.
3. Remove all memory DIMMs
or third-party DIMMs from the
printer. (Do not remove the
firmware DIMM in slot J1.)
4. Remove all of the
EIO devices from the printer.
5. Turn the printer on.
6. If the error message
disappears, reinstall
each DIMM and EIO device
individually, making sure to
turn the printer off and then
on again as you install each
device. To replace a DIMM,
7. Replace the DIMM or
EIO device that caused the
error message.
8. Remember to reconnect all of
the cables that connect the
9. If this error message persists,
replace the firmware DIMM.
10. Replace the formatter
Jun 03, 2008 | HP LaserJet 2420dn Printer
Question on service error
this means you don't have enough printer memory installed - you need to add more memory to the printer - you need to have at the minimum 128 megs. - hope this helps you.
Apr 17, 2008 | HP LaserJet 2420dn Printer
109 people viewed this question
Ben Johnson
