When I plug in my Sansa it is not opening. if check the hardware installion it asks installaition cd. give hints on how I can find out or open my mp3 player in all PC
    Master:
  • 763 Answers
Open the control panel from the start icon then find the add hardware. follow the instructions their it should be recognizable after that. be sure to turn on your device.
thank you for using fixya
CHARCOIS
Posted on Mar 05, 2009
Does anyone know if mine, a SanDisk 1.0 GB is salvageable? The CD that came with it was destroyed when my helper cut into it opening the plastic...:( so it has never been used...is there away around this...
Definitely! You don't need the software at all. Just connect the player to your computer with the USB. It should open as a disk drive (if it asks you, choose 'open folder to view files') and then you can just copy music to it with drag and drop. Then use 'safely remove hardware' before you unplug it again, and you should be 'good to go'.
Mar 31, 2011 | SanDisk Sansa m240 MP3 Player
My computer can't recognize my sansa fuze player... plz help me..
The Fuzeplayer must NOT be connected to the computer before you install the software.
If this has happpened, you will need to remove the Fuse driver in Device Manager. (Inst for XP)
Go to My Computer->Right click and select Properties. In properties, select hardware and Device Manager.
With Device Manager open, plug in the Sansa Fuse player. Find the new driver that popped in.
(You can do and undo this several times until you are certain you have the right one.)
Right click the fuze driver and select 'Remove'.
Close all windows you opened.
Unplug the fuze player and do not connect it until the driver is reinstalled with the driver disk. When the software asks, plug it back in.
That should solve it.
Unsure? ask a knowledgable friend to help.
Mar 21, 2010 | SanDisk Sansa Fuze MP3 Player
My pc is not recognizing my sansa mp3 player clip model 1GB. Do I
Here is the manipulation to be done to remedy this.
To begin, open Windows Explorer and click the Tools /Folder Options /Display. Look in the list "Hidden files and folders" and check "Show hidden files and folders."
  • Right click on the icon "My Computer" from desktop and then click Properties. Then click on Hardware then Device Manager.
  • Right click on the line marked "Unknown Device" and click "Update Driver".
  • Then in the wizard to update the hardware choose "No, not this time."
  • Click "Next."
  • Select "Install from a list or specific location (Advanced)".
  • Click Next.
  • Then click on "Do not search I will choose the driver to install".
  • Choose from the list of hardware USB hub.
  • Click Next.
  • Click on "Disk".
  • A window opens. Then click "Browse", go to C: /windows/inf and select usbstor.inf and click Open.
  • The path of the selected driver will appear in the previous window. Click "OK". The driver will be installrd and you have a line called "Device USB Mass Storage".
  • Choose from the list of hardware "Storage Volume".
  • Click "Next."
  • Click on "Disk".
  • A window opens. Click "Browse", go to C: /windows/ inf and select volsnap.inf select and click "Open."
  • Then the path of the selected driver will appear in the previous window. Click "OK". The driver will be installed and you have a line called "Generic Volume".
Jan 11, 2010 | SanDisk Sansa Clip MP3 Player
Sansa E250 how do I put songs onto the mp3
Go to My Computer and then look for the Sansa 250 icon there. If it doesn't show up, unplug the USB cord and plug it in again. Once you have the icon visible in My Computer, click on it twice and open it up. To load content, go to wherever you have MP3 files or whatever and use Windows Explorer to copy the content from your computer to the Sansa. You can also manage it through Real Player or other MP3 players (Media Monkey).
Dec 24, 2008 | SanDisk Sansa e250 MP3 Player
My Sandisk Sansa c250 wont charge or turn on
Opening the player up was a bad idea. You probably could have run the Sansa Recovery Tool from Sandisk's website, but now you might have moved the hardware around - there is YouTube video that shows the inside of the Sansa player (several actually) that might give you some hints. But try the soft fixes first:
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Dec 16, 2008 | SanDisk Sansa c250 (2 GB) MP3 Player...
Lost my installation cd
if you have a fairly new computer,just copy and paste you music
Nov 11, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa
well, first u need 2 cut ur nails and second u need a key 2 unlock things. also, if u want some real help u need 2 go 2 the store and ask them or ask my dad or just by a new one!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
HINT leave the technology 2 the big kids. luv ya xoxo
Jun 23, 2008 | SanDisk Sansa View 8GB MP3 Player - Black
Ask about my sansa clip
does it come with anything else like a cd or usb clip with the software?
Apr 28, 2008 | SanDisk Sansa Clip MP3 Player
Widow vista doesnt reconise it
Get the latest firmware upgrade from the Sansa website - they should also have an updated version of the software on their website.
Feb 10, 2008 | SanDisk Sansa Clip MP3 Player
Why can't I transfer?
Open up windows media player to see if it recognizes your device...make sure you have the device connected...Click on the sync tab, and then your device should be listed on the right side under devices...if you device is listed there you need to unplug your device and open up my computer...then rename all removeable disk drive you have there...give them a different name instead of removeable disk...open up windows media player..click on tools...to find the tools button if its not there already right click between now playing and library...once find the tools go to options then privacy...you want to clear the history and the caches...then click ok...plug your device back in...windows should detect it..once detected you can just go under the sync tab and drag the songs you want under sync list...hope that helps..
Oct 22, 2007 | SanDisk Sansa c150 MP3 Player
Computers & Internet Logo
21 people viewed this question
David Payne
David Payne
