Question about Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater
Have sunstar corcho infrared heater, cleaned with compressed air, flame was blue and at angle, then flame went straight up, turned yellow then went out. Now get spark, but won't ignite. Did use plastic straw end of compressed air can to unplug pilot. Think I may have damaged pilot orifice valve????
2 Suggested Answers
  • 41 Answers
SOURCE: yellow pilot on heater
soleman13au
Rank:master_s.gif Master
Rating: 90%, 19 votes
Hi mitalee1
All it needs is a good blow out with compressed air. They tend to carbon up in the pilot light area. You will probably also find it is very dusty inside. Easiest way to clean the carbon out is to remove the hose at the heater and with compressed air blow through the fitting where you have removed the hose. Make sure you hold down the start button so the air can get through to the pilot light and jets. Don't connect the electricity for the fan when you do this. If you can get to the top of the pilot light it may help to give that a blow out too.
To clean it out internally you only need to remove the front panelling. Just follow the screw configurations *** you go. I asm not familiar with that type of heater so thats about the best I can do. Regards Bryan
Posted on May 07, 2008
Burner for corcho wall moont heater model number ck30t3lt
Search Results
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with ...
    www.efireplacestore.com > ... > SunStar Heating Products Space Heaters
    SunStar Corcho Vent-Free Natural Gas Infrared Heater with Manual Controls ... For added convenience, you can mount this heater on a wall or have it stand on ...
    Tech Video: Wall Heater Maintenance - YouTube
    ? 3:33
    https://www.youtube.com/watch?v=8eglHvyNV3U
    Oct 19, 2010 - Uploaded by FMIPRODUCTS
    How to clean the Vent-Free Wall Heater burner's & pilot. ... Fix Mr Heater Vent Free Pilot Problems - Part ...
    EMPIRE CORCHO UNVENTED GAS HEAT
Dec 14, 2015 | Heating & Cooling
The pilot on my sunstar corcho wall heater won't stay lit
Try cleaning the gas tube with a pipe cleaner and insure the flame is in contact with the thermo coupling.
Dec 09, 2013 | Desa International Heating & Cooling
Pilot light stays on but after a few minutes the heater shuts down, pilot as well. has plenty of oxygen. pilot flame has a yellow tip on the end of blue. empire brand
The pilot orifice and the Oxygen Depletion Sensor (ODS) need to be cleaned. You can accomplish this by using canned compressed air with a straw nozzle (like you clean your computer with).
Turn off the gas, allow the heater to cool and dismantle the front half potion of the heater. There are 6 to 8 sheet metal screws that hold the 2 halves together. You'll probably find a lot of dust & lint inside the heater. This will need to be cleaned out with a vacuum that has a hose and crevice tool attachment.
Once you have accomplished that, turn your attention to the pilot assembly. Using the canned compressed air withe straw nozzle, blow out the pilot tip with a qucik shot of air. Now, look down the pilot from the tip and about 2/3rds of the way down, you'll see a hole in the side of the pilot. That's the ODS sensor. Stick the straw nozzle just barely into this hole and give it a quick shot of air. You'll probably see debris fly out the other side.
Before you reassemble the heater, turn the gas back ON and light the pilot, but do not light the burner(s). Is the pilot lighting and holding. Is the pilot flame straight or is curling up? If it's curling up, turn the heater off and repeat the pilot cleaning procedure. If it's straight out, reassemble the cabinet and your ready to go.
Now, take a moment and pat yourself on the back. You just completed what's called "Annual Maintenance", which should be done at least once a year, usually in the Fall, before lighting the heater for the season.
Hope this helped you solve your gas heater problem. Please let me know.
Feb 27, 2011 | Empire BF-10 Mid-Size Heater
ON MY ATWOOD WATERHEATER IT LIGHTS BUT PRODUCES A LOT OF SOOT AND DOES NOT SEEM TO FIRE UP LIKE IT SHOULD
You need to start by cleaning burner tube and pilot intake , sounds like spiders have probably spun a web in there. If flame is yellowish, it's not getting enough air. You can buy a barbecue burner brush, long and flexible, and run it through burner tube to clean out web, and if pilot is yellow as well, there is a small hole in side of fitting where it attaches up near burner that needs to be cleaned out with paper clip or even better, compressed air. After cleaning burner, adjust air shutter to get nice blue flame, with just a hint of yellow at tip. The idea there is to get blue flame, but not a roaring flame that is jumping off the burner. A spider web in there will usually allow propane through, but restricts air mixture, thus causing yellow flame (rich mixture) and soot to build up.
Nov 11, 2010 | RTO Atwood Water Heater - 6 Gal LP
My patio mushroom heater lights up ok but keeps going out by itself after about 5 to 10 minutes and then can be started again inatantainiously by starting pilot light and away you go until it goes out...
Here's a few things to check. When you light the pilot, is it a strong blue pilot flame, a weak blue flame or a lazy yellow flame? Is it heating the thermocouple enough to make it red hot after a few minutes? If the pilot is small blue or lazy yellow flame, it may be dirty and need cleaned. When the burner lights, the weak pilot flame may diminish causing the thermocouple to cool off enough to shut down the main burner. Clean the dirty pilot orifice by using a can of compressed air with attached straw. (The same canned air you use to clean computer keyboards) Blow it into the pilot assembly where the pilot flame burns out from and blow thru the air holes on the side, if applicable. You might also check the thermocouple itself to make sure the tip is not partially burn't off. It should be a smooth, rounded tip. Replace the thermocouple if cleaning the pilot orifice doesn't solve the problem. Douglas
Aug 05, 2010 | Coleman (5040B750) Patio Heater
Problem lighting natural gas roomheater sunstar corcho 18,000 btu
sounds like the thermocuple is bad, it is a small copper line coiled up with a larger end that sits in the pilots flame. it tells the control valve that there is a flame and it is ok to open the gas valve. You can replace them very easily you just have to match it up to the right one. they are conected by a tube fiting on the control valve and a screw or sometimes just a clip near the pilot flame. True value stores carry them
Oct 17, 2009 | Dishwashers
Corcho Model CH30t-2 panels won't stay lit
HI it sounds like the fire cement between them needs replacing you can buy this at home hardware or heating supplier this should stop the flame down the middle , it stops air getting in and it will burn better , hope this helps you ?
Jan 10, 2009 | Heating & Cooling
Can not get the bricks to light on my empire corcho
I have the same htr in Mich. & have worked on gas htrs.for many years.
Does the flame go out when you let go of the button to lite it?
If it does, then the thermocouple is bad.
If the flame stays on, but goes out when you turn the dial,
the gas regulator is bad.
Probably a little more expensive to buy new then to fix it.
Michael.
Nov 20, 2008 | Reddy Heater RLP100 Portable Forced Air...
Yellow pilot on heater
soleman13au
Hi mitalee1
Apr 15, 2008 | Vanguard International Blue Flame - Medium...
Vent free infared heater
What you are experiencing is common if the plaques are either out of alignment or the burner is dirty. I know you said you cleaned it with low pressure air, but you need at least 120 PS. of air to clean the burner and plaques as per the owners manual.
Nov 12, 2007 | Rinnai Desa Vent-Free Infrared Gas Heater:...
Vanguard International Infra Red - Medium Infra-Red Mid-Size Heater Logo
163 people viewed this question
Top Vanguard Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Are you a Vanguard Heating and Cooling Expert? Answer questions, earn points and help others
