Sir i want a simple program using module
I want a simple example program using module
  • EinsteinKid
    EinsteinKid May 11, 2010
    Hi!
    Can you elaborate your question.
    I can try to help you!
    Thanks!
    Problem Solver:
  • 10 Answers
GO TO
http://www.sourcecodeonline.com/list?q=postnuke_module_sample_code
Posted on Mar 12, 2009
Show syllables in words
Perl is a great language for this type of problem.
I recommend using Perl, and installing the Lingua::Phonology::Syllable module. Here is a working example:
use Lingua::Phonology;
use Lingua::Phonology::Syllable;
my $phono = Lingua::Phonology->new();
$phono->features->loadfile;
$phono->symbols->loadfile;
# Create a new Syllable object
my $syll = new Lingua::Phonology::Syllable;
# Create an input word
my @word = $phono->symbols->segment('s','h','e','p','h','e','r','d');
# Allow onset clusters and simple codas
$syll->set_complex_onset;
$syll->set_coda;
# Syllabify the word
$syll->syllabify(@word);
my $count = $syll->count_syll;
print "Count: $count\n"; # prints "Count: 2"
# @word now has features set to indicate a syllabification of
# <shep><herd>
Aug 27, 2014 | Computers & Internet
How syllable check
$syll->set_coda;
# <shep><herd>
Aug 26, 2014 | Computers & Internet
Gm codesB1001
#PIC5913: Diagnostic Tip - B1001 With SIR MIL And/Or SVS MIL And/Or Locked Radio - (Sep 19, 2013)
Subject: Diagnostic Tip - B1001 With SIR MIL And/Or SVS MIL And/Or Locked Radio Models: 1998-02 Chevrolet Astro, Venture, S10, Blazer, Trailblazer, Camaro, Cavalier, Corvette, Impala, Monte Carlo, Lumina, Malibu, Metro, Prizm, Express 1998-02 GMC Safari, Savana 1998-02 Pontiac Bonneville 1998-02 Pontiac Firebird Models, Sunfire, Grand Am, Grand Prix, Montana 2001-02 Pontiac Aztek 1998-99 Buick Riviera 1998-02 Buick LeSabre, Park Avenue, Century, Regal 2002 Buick Rendezvous 1998-99 Oldsmobile Cutlass 1998-02 Oldsmobile Bravada, Aurora, Intrigue, Alero 1998-02 Cadillac DeVille, SeVille, Eldorado, STS, SLS, Catera, Escalade Models The following diagnosis might be helpful if the vehicle exhibits the symptom(s) described in this PI.
Condition/Concern Some vehicles may exhibit a B1001 DTC with an SIR lamp, SVS lamp on and/or radio locked, possibly after module replacement (i.e. BCM, SDM, etc.). This information is presented to clarify the failure modes that will set this DTC, as well as offer a diagnostic direction to help repair them.
DTC B1001, by definition, is a "configuration mismatch" between vehicle modules that communicate with each other over a data line. Modern vehicle systems depend upon each module storing certain vehicle information, as well as information about other modules in order to work properly together. Common causes of B1001 are:
  1. An incorrect or non-existent VIN number in modules that require them.
  2. A module that has been replaced but not programmed per currently published service information.
  3. SDM replacement where the new SDM is a different (newer) part number than the original.
Recommendation/Instructions A common diagnostic approach that will address most concerns with B1001 is as follows:
  1. Ask the technician if a module has recently been replaced which led to the B1001 DTC. If so, determine if the service information procedure for replacing the affected module has been followed. For example, some callers mistakenly believe that a new BCM simply requires "theft deterrent relearn" to operate properly. However, many modules require a "new module setup/RPO configuration" procedure to operate properly. The process for setting up a new module varies, consult currently published service information for the correct procedure for your application.
  2. If an SDM has recently been replaced, the BCM requires the last 4 digits of the SDM part number to be stored in a portion of the BCM to prevent DTC B1001. If the SDM's service part number is different than the original module, a special procedure is required to erase and re-learn this "restraints ID" code in the BCM. While the procedure varies from vehicle to vehicle, there are two standard methods as follows:
    1. On some vehicles the Tech 2 has a function available in the BCM or SIR "Special Functions" menu. Common terminology is "setup SDM part number in BCM" or similar nomenclature. Follow on-screen instructions to complete procedure.
    2. Some vehicles require an "SPS" method of programming the restraints ID. Perform the "Request Info" step at the vehicle and confirm the VIN number stored, then take the Tech 2 back to the terminal and down-load the appropriate file from the TIS2WEB "available modules" menu.
  3. If neither of the above are successful in clearing B1001, check the following modules with the appropriate Tech 2 data list under "VIN" or "module information" to determine if the correct VIN number is stored.
PCM: If the PCM does not have a VIN stored, or the incorrect VIN is stored, it will be necessary to program the PCM using the current SPS method. If the PCM already has the latest calibration software installed, it will be necessary to contact Techline Customer Support Center (TCSC: 1-800-828-6860 English or 1-800-503-3222 French) and request a VCI number to allow reprogramming with the same calibration.
BCM: If the BCM does not have a VIN stored, or the incorrect VIN is stored, it will be necessary to install the correct VIN using the appropriate line under the BCM's "special functions" menu. Follow on-screen prompts to complete programming.
Radio: If the Radio does not have a VIN stored, or the incorrect VIN is stored, it will be necessary to install the correct VIN using the appropriate line under the radio's "special functions" menu. Follow on-screen prompts to complete programming.
Please follow this diagnostic or repair process thoroughly and complete each step. If the condition exhibited is resolved without completing every step, the remaining steps do not need to be performed.
Jun 02, 2014 | 2000 Chevrolet Malibu
Configure.csv
CSV means:
A comma-separated values or character-separated values (CSV) file is a simple text format for a database table. Each record in the table is one line of the text file. Each field value of a record is separated from the next by a character (typically a comma, but some European countries use a semi-colon as a value separator instead). Implementations of CSV can often handle field values with embedded line breaks or separator characters by using quotation marks or escape sequences. CSV is a simple file format that is widely supported, so it is often used to move tabular data between different computer programs that support the format. For example, a CSV file might be used to transfer information from a database program to a spreadsheet.
Dec 27, 2010 | Acer TravelMate 2300 Notebook
Sir m working on online library management system & m using java platform.can u tell me the different modules for this project.
different modules could be-
1)Admin module
2)login page
3)subject section with there books
4)issue section with names of person having those books.
5)exit section
Oct 24, 2010 | Computers & Internet
Source code of " hello world" program using visual basic 5.0
Here's one way...... Imports System Public Module modmain Sub Main() Console.WriteLine ("Hello World!") End Sub End Module
Jun 07, 2009 | Gentoo Linux Operatimg System
Do while
a very simple example scriptlet:
#include <iostream>
int main()
using namespace std;
int i=1;
do
cout << "value of i:" << i << endl;
} while (i<=10);
return 0;
Thanks.
Mar 17, 2009 | Microsoft Visual Basic 6.0 for PC
I want to have an example of a simple computer program system. anyone can help me?
Buckle down and search the Internet for "VB6 Code Examples." If you are after a specific example, add that to your search string.
Mar 06, 2009 | Microsoft Visual Basic Professional...
Computers & Internet Logo
42 people viewed this question
David Payne
David Payne
