Question about Lexmark X2500 All-In-One Printer
My printer will not completely roll paper through the printer
My printer keeps getting jammed. the paper will not feed past the ink. i looked for james i can not find any. help the printer is a lexmark x2500
  • 109 Answers
Maybe the cartridges are in slightly crooked. Take them out and put them back in. Make sure there is no paper or any other obstruction around there and try again. :)
Posted on Mar 05, 2009
Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Riso V800
Riso's are famous for this, i will scrub the rubber timing roll with rubber rejuvenator and clean the steel roll with alcohol.The riso paper feed clutches are weak compared to what they were in this series you may have to replace the clutch. Bud, after doing some research you need to clean the oneway bearings on the pickup and feed rolls, adjust feed table hieght and lastly check/adjust timing in drive and feed roller-you will need a manual for this.
Hope this may help;
Regards,
VOTIT
Jul 25, 2008 | Riso RZ220 Duplicator
Ink ribbon was chewed up in my son snap lab and resulted in paper jam. I cleared the jam and repaired the ink ribbon and it still is reading that error. How can I fix this?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
You must open up the front where the roll goes. Lay the printer back, and look up top where the paper ejects. you should see some of the paper in the feed. Pull that out with a tweezers.
Beware. I sent my printer to Sony and they tried to get me for a new cutter and thermal head. Close to $500. I then realized the problem because it happened on another unit I own. I told them to ship it back unrepaired and I fixed it myself.
Hope this helps
Jan 14, 2011 | Sony SnapLab UP-CR10L Digital Photo...
Printer is saying paper jam and I have cleared out all paper and clippings that were stuck how can I get it to stop saying paper jam?
Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the inside top paper feed. Clear that out, and all is good.. Change the paper every time u change the ink. Even if its not finished. They give you extra. And clear out all the paper from the cutter traay before you move the printer.
Hope this helps
Oct 19, 2010 | Sony SnapLab UP-CR10L Digital Photo...
Completely paper jam
To clear the paper jam, please turn off the printer and it will attempt to clear the jam by itself. You might see an error code on the printer too which will help you identify the issue.
To remove the paper jam manually, turn off the printer and then remove the paper tray.
Check for paper that is trapped in the same. Also try to access other printer areas where paper travels in the course of printing.
You could remove the toner or ink cartridge go gain access to hidden areas in the printer.
Ty to roll the gears and rotate the paper feed mechanism to free up the jam.
If you locate a piece of paper hold it with both hands and attempt to get as large a grip as possible, then slowly pull.
The objective is to not to cause a tear in the paper and pull it out in one smooth motion.
Put the toner and paper tray back in it's place.
Switch on the printer and check by printing a test page.
This should resolve the issue.
Sep 06, 2010 | HP Photosmart C3180 All-In-One InkJet...
My roller dont take in the paper
MP160 PIXMA paper feed jam E3 error. I completely solved this on my Canon MP160 printer but it is a common problem and the fix may work for others such as MP130 MP140 MP145 MP150 MP170 or MP180. With the problem I had, the printer would make the usual motor whirring noises but would not feed the paper. The usual c-clunk sound that indicated the feed roller has been engaged was not there. The screen warning said to remove jammed paper and the printer showed an E3 error. The problem was caused by the ink cartridge carrier becoming stcky on its track and not fully returning to the rest position on the right side (as viewed from the front). The fix involved taking the printer apart and lubricating the cartridge carrier track and the ramps that lift the cradle that rises to cover the printheads. Unfortunately you have to dismantle the printer and separate the scanner unit to get to the lubrication points. Its not a quick fix. When you have the printer apart you will see a prominent white lever held by a coiled spring just behind the rest position of the ink cartridge carrier. The lever is actuated by the ink cartridge carrier when it moves to the right. If the lever is not actuated, the motor drive will never engage the large grey feed roller and the paper in the hopper cannot be fed into the printer. Make sure to also put some lube onto the lever at the point where it is struck by the ink cartridge carrier.
Jun 07, 2009 | Canon PIXMA MP160 All-In-One InkJet...
241.10 paper jam
Um I don't know what the other guy is saying since your paper jam has nothing to do with where he is telling to look...
From the service manual:
Error 241 subcode 10:
Page was not properly picked from tray 1.
Possible Causes:
Failure to feed possible causes include:
• Edge locking
• Worn or contaminated pick tires
• Overfilling of tray past the fill line.
Action:
Fan media.
Turn media over.
Reduce amount of media loaded in tray 1.
Replace pick tires.*
To replace pick tires:
Integrated tray autocompensator pick roll assembly removal
1. Remove the integrated tray, and look underneath the printer for the autocompensator arm. Pull the arm
down.
2. Press on the end of the tab (A) and pull the pick roll off the arm. Repeat this step for the pick roll on the other side. Next, gently release the autocompensator arm. Discard the used pick rolls.
Installation
1. Remove the new pick rolls from their packaging.
2. Pull the autocompensator arm down. Locate the recessed area on the pick roll, and align it with the tab on the arm. There are two arrows on each pick roll. Make sure the bottom arrow faces you as you align the recessed area with the tab.
3. Push the pick roll onto the arm with the tab aligned. Repeat this step on the other side to install the other pick roll.
4. Gently release the autocompensator arm. Insert, integrated tray.
Thanks and please take a moment to rate this solution as fixya.
Feb 04, 2009 | Lexmark T640 Laser Printer
Printer will not work. Error E3
What may have happened is that the Paper sensor is locked down and tells the printer that there is paper in the path (although there isn't any). The paper sensor is a toggle switch and there is a paddle that pushes it down as the paper goes in/out. Look on the right side of the unit ,under the roller assembly. Sorry, but I do not have a service manual for this unit.
Error list :
E2-2 = No paper (ASF)
E3-3 = Paper jam
E4 = No ink
E5-5 = The ink cartridges are not installed or a non-supported ink cartridge is installed, or the ink cartridges are not installed properly
E8 = Waste ink absorber full, or platen waste ink absorber full
E9 = The connected digital camera / video camera does not support Camera Direct Printing
E14 = The Ink cartridges whose destination are wrong
E15 = Ink cartridge is not installed E16 - Ink remaining is unknown
E16 -E19 = Failed to scan head alignment sheet
E22 = Carriage error
E23 = Paper feed error
E24 = Purge unit error
E25 = ASF(cam) sensor error
E26 = Internal temperature rise error
E27 = Waste ink absorber full or platen waste ink absorber full
E28 = Ink cartridge temperature rise error -
E29 = EEPROM error
E33 = Paper feed position error
E35 15 = USB Host VBUD overcurrent error - USB
E37 17 = Abnormal motor driver error
E40 20 = Other hardware error
E42 22 = Scanner error
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
Nov 12, 2008 | Canon PIXMA MP160 All-In-One InkJet...
Paper will not feed
What you need to do is remove the tray, and look for the feed rollers and clean them with either alcohol or a soapy cleaner like Fantastic.
Clean them a few times, make sure they are dry then try again.
That may solve it completely, or your rollers may be slick and need replaced.
When those rolls get dirty, it's like trying to drive on ice. You just slip. Also, if those rolls are needing replaced, I wouldn't be upset with the refurb work. Sometimes those rolls fake you out. They appear and to touch feel perfectly fine, but try and feed a piece of paper, and it just won't.
If you can, look into the paper tray with a flash light, and see if they are turning. If they are, then dirt or slick rolls is the only problem you have.
Mar 01, 2008 | Samsung CLX 3160fn All-In-One Printer
Lexmark X2500 All-In-One Printer Logo
321 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Don  Farrell
Don Farrell
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
