Question about HP 0950-2700 - 145W Power Supply (09502700) Power Supply
After print not come to standby
1. where is avalable HP 2700 Printer Drivers 2. After printing my printer not go to standby mode.
3. power on the printer few minutes worming after one page printing not come to stand by mode.
please solve my printer problam.
Thanking you sir,
Yours truely.
O.V.SURESH.
    Sergeant:
    Champion:
  • 315 Answers
1. www.hp.com
2.does it -have- such a mode?
3.what?
Posted on Mar 05, 2009
HP F4200 printer won't print
may be 1) the printer does not has colors or
2) the power supply problem or
3) the printer does not detect or
4)the printer drivers not available
check once, and mention your printer the problem clearly.
Dec 24, 2015 | HP DeskJet Office Equipment & Supplies
Disable power saving mode
Sorry, but you will NOT be able to DISABLE the power saver mode on this printer. The printer will still go into "power saver mode", but it takes longer to do so, if you set diffrent as default time delay [ Two power saver modes: (1) print to standby mode 35 Watt, user-definable 1-30 minutes, default 3 minutes ; (2) print to powersaver mode 4 Watt, user-definable 5-60 minutes, default 10 minutes ].
See also:
Dell 1250C problems with sleep mode
Oct 01, 2014 | Dell 1320c Laser Printer
My printer is CANON IP 2700 when i try to print Error 5100 appears in the screen and the printer blinks orange ligth
1. hold RESUME then press & hold POWER
2. release RESUME, then press it twice, the light should go amber then green again.
3. you're now in service mode (you can release POWER now)
I think waste tank reset is 4 presses of the RESUME button. To confirm, press POWER once.
May 24, 2011 | Office Equipment & Supplies
Check printing
Open HP Solution Center, Click Settings ---> Print Settings.
Click Features tab, select the Paper Type as Plain Paper.
Select appropriate Paper Size under Size. Click Ok.
Now Print Cheques from Quicken.
If the issue still persists, Navigate to Printers folder, right click on the printer icon and click Properties. click Advanced tab, enable Print directly to printer. Click Apply.
This should now Print the Cheques.
If the issue still persists, install alternate drivers in Vista.
Here are the steps:
Click Windows logo ---> Control Panel ---> Printers.
1) Click Add Printer
2) Select local printer
3) Choose Port as LPT1
4) Choose HP and then select HP Deskjet 6500
After the driver is installed, perform below steps:
1) Right click on HP Deskjet 6500 printer icon in Printers folder
2) Click on Properties
3) Click on Ports tab
4) Choose USB001
5) Click Apply and click Ok
Now try to print.
Mar 19, 2008 | HP Officejet Pro L7580 All-In-One InkJet...
HP Laserjet 1320 Printer
Hello
Please note: Instructions only applicable to the network printer which supports telnet protocol.
HP Mono and Color LaserJet Network Printers - Sleep Mode Problem
Issue
Network printers may not print when a job is sent to the printer while in sleep mode.
Solution
Please follow the steps below-
1. Connect the printer to telnet- Using command prompt.
2. Type telnet > IP address press then enter.
3. Type menu and press enter.
Following screen will appear-
4. Choose option 2 TCP/IP menu and press enter,
5. Choose option 5 TCP/IP other settings and press enter.
6. Type y in front of cursor and carry on pressing enter until you reach “SLP keep alive”. By default this value may be 0.
7. Change this value to 1.
8. Exit and save settings.
- Nikhil
Mar 04, 2008 | HP LaserJet 1320 Printer
Must Reinstall to Print
Most USB printers need to have the printer driver installed before you connect the printer to the computer, did you install the printer this way?
Also, check and see if it is the default printer.
If those do not work:
1) Turn off the Terminate and Stay Resident programs MSCONFIG in VISTA.
2) Disable HP device discovery service.
3) Uninstall the All-In-One software.
4) Turn off firewall and antivirus.
5) Reinstall the latest software for the All-In-One.
Hope this helps.
Please let me know how this works for you.
Jan 30, 2008 | HP DeskJet F380 All-In-One Printer
Print Stripes
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpa00226&lc=en&cc=us&dlc=en&product=304445&rule=42852&lang=en HP has indications that the lubricant on the printer carriage assembly tabs and the flex circuit contacts on the print cartridge can collect debris (fibers and dust), which may cause poor output. The lubricant is used to ensure that the interaction between the pen and the carriage assembly does not cause tears in the flex circuit. Refer to the following instructions to solve this issue. Cleaning the Inkjet cartridges can improve the quality of printing. If the printed page is missing lines or dots, or if it contains ink streaks, perform Procedure 1 in this section. If problems persist after performing Procedure 1, perform Procedure 2. NOTE: Use plain paper for these maintenance activities rather than more expensive specialty papers. Procedure 1: Cleaning the cartridge electrical contacts 1. Turn on the printer. 2. Open the top cover. The cartridges should move to the center of the printer. 3. Unplug the printer?s power cord from the power outlet. WARNING: Keep new and used cartridges out of the reach of children. 4. Remove the color cartridge. 5. Clean the electrical contacts (see Figure 1). Figure 1: Cleaning the cartridge electrical contacts A- Use a clean, soft, dry, lint-free cloth. B- Locate the copper-colored circuitry strip on the back of the cartridge. C- Wipe the coppers strip with the dry cloth. Use an upward motion, from the nozzle end to the top of the cartridge. CAUTION: Do not wipe the nozzle plate on the bottom of the cartridge. Wiping the nozzle plate can damage the cartridge (Figure 2). Figure 2: Do not wipe the nozzle plate 6. Remove the black cartridge. With a clean part of the cloth, repeat Step 5 with the black ink cartridge. Cleaning the electrical contacts inside the carriage assembly 1. Look for fibers or other contaminants on the electrical contacts inside the carriage assembly. The contacts in the printer can be damaged if too much pressure is applied during the wiping process. If necessary, the contacts may be cleaned by wiping them very gently with a dry, lint-free cloth (see Figure 3). Try to gently remove any visible debris within the carriage. WARNING: Make sure the printer power is turned off before cleaning inside of the printer. Figure 3: Cleaning the contacts inside the printer 2. Reinsert both cartridges. On models with cradle latches, close the cradle latch over the top of the cartridges. 3. Close the top cover. 4. Plug the power cord into the power outlet. 5. Print a test page. If the problem persists, go to Procedure 2. Procedure 2: Aligning and cleaning the cartridges Use the HP Deskjet Toolbox or Printer Assistant utility on the desktop (the utility name will depend on which HP Deskjet model is installed on the computer). NOTE: HP Deskjet Toolbox or Printer Assistant is for Windows users. HP Deskjet Toolbox: To align the cartridges from the HP Deskjet toolbox: 1. Open the HP Deskjet toolbox. The toolbox is located on your desktop in Microsoft ®) Windows XP, Me, 2000, 98, 95, and NT 4.0. In Windows 3.1x, the toolbox is located in the program group for the printer. 2. Select the Printer Services tab in the toolbox. 3. Select Cartridge Alignment and follow the steps on the screen. 4. After the alignment process is completed, perform a Cartridge Cleaning from the toolbox. 1. Double-click the HP Deskjet Toolbox shortcut (or icon) on the desktop. 2. Click the Printer Services tab. 3. Click Clean the Print Cartridges. Follow the instructions that appear on the screen HP Printer Assistant: To align the cartridges from the Printer Assistant: 1. Launch the Printer Assistant by clicking the Printer Assistant icon located on the desktop 2. Select tools and updates. 3. Go to printer maintenance. 4. Select calibrate printer. 5. Click calibrate and follow the onscreen instructions. Further instructions on calibrating the printer cartridges using the Printer Assistant can be found on document npd09616 - HP DJ 3320,3325 and 3420 series printers - how to calibrate the print cartridges After the alignment process is completed, perform a Cartridge Cleaning from Printer Assistant. 1. Select tools and updates. 2. Go to printer maintenance 3. Select clean cartridges. 4. Click clean and follow the onscreen instructions. If the problem persists, the cartridge should be replaced. If the cartridge still exhibits banding even after cleaning and priming actions in the HP Deskjet Toolbox are complete, the cartridge may need to be replaced. Verify the end for warranty date on the supply before returning it to the reseller. Typically, banding problems are most pronounced in images produced on plain paper in Normal mode. In many cases, simply changing to Best mode will alleviate the problem and produce satisfactory output. If switching modes does not result in acceptable performance, try using the cleaning steps described above. Internal test from the printer Running an internal test from the printer can perform a clean test. See document titled HP Deskjet Printers - How To Print Internal Tests for instructions on how to run internal tests. If the problem persists, replace the cartridge. Let me know if that helps. Good Luck, Tim
Mar 15, 2007 | HP DeskJet 5650 InkJet Printer
Computers & Internet Logo
420 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
