Question about Datel Gaming Headset for PlayStation 3
I got a datel headset that is supposed to be compatible with the PS3. it has the usual headset with a cord but it plugs into this thing that looks like a thumb drive but it isnt a USB plug. it almost looks like it should fit into one of the memory card slots but it doesnt and i cant find anywhere else to plug it in.
  • 3 Answers
I have one too...
It is very cheap. Cheap quality. Too expensive.
Anyway, it IS a USB plug, it just doesn't have the metal protecting thing like on regular USBs. It should fit in the bottom half of one of your USB ports near the bottom of you PS3. Make sure the side with the 4 bronze lines is facing up. Plug it in, follow the rest of the instructions, and then you're good to go.
Posted on Apr 07, 2009
Cant sync with ps3
your 360 headset doesn't work with a ps3? which is to say Microsoft doesn't like sony i'd say thats sounds about right
Jan 15, 2011 | Datel Xbox 360 Game Talk Wireless Headset
I lost my pass key for datel headsey for a ps3 and its not four 0000 soo any help?
If it is not '0000', try either '1234' or '8888'.
Hope one of these codes might work for you.
Regards, Carlos
Sep 19, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
Lost charger who can I call?
The nice thing about the ps3 is it can charge the bluetooth from the charge cord for the controllers. Just plug the bluetooth into the charging wire from the ps3 and the bluetooth will charge.
Jan 27, 2010 | Mad Catz PS3 Bluetooth® Headset Wireless...
We have a Datel wireless bluetooth headset for the xbox360, but no instructions. Can you please help?
Looks like for some reason Datel does not publish the user manual for this device on its website. They have the manual for the wired headset.
http://www.datelcustomerservice.com//product_pdf/XBOX360%20-%20Communicator%20Headset.pdf
The only one I can find is the bluetooth headset for PS3. Not sure if this helps but I am guessing the instructions should be similar.
http://www.datelcustomerservice.com/product_pdf/PS3%20-%20Bluetooth%20Wireless%20Headset.pdf
I can see that Microsoft make it for xbox360. Not sure if that helps.
http://download.microsoft.com/download/b/c/e/bce76f3f-db51-4c98-b79d-b3d21e90ccc1/WirelessHeadset_NA_0701.pdf
I will keep looking. Please do not close this query as yet.
Jan 23, 2010 | Video Game Consoles & Games
Bluetooth passweord for datel headset please.....
dan_4ley
I do not know if you need the PS3 manual so I included the link below. How the code is "0000".
Let me know if you have any more problems or questions.
Issken
Dec 25, 2009 | Datel Radio Communications
HOW DO I HOOK UP A DATEL GAMING HEADSET TO MY PS3
by pairing it to your ps3 in the accessory settings.
Apr 29, 2009 | Sony Playstation 3 (PS3) Console
Am having problems with setting up my bluetooth headset for ps3
the problem of it is compatibility here's the step1. CompatibilityThe PS3 supports only one headset at a time. Multiple players on the same console will have to share.
Bluetooth:
  • The PS3 uses Bluetooth version 2.0, and is compatible with all earlier versions.
  • All makes and brands of Bluetooth headset should work with the PS3.
USB:
USB (wired) Headsets can also be used with the PS3.
  • Any of the PS2 compatible USB headsets should work with PS3 games.
  • USB headsets are required for PS2 software used on the PS3.
Not Compatible with Bluetooth Stereo Headphones:
  • The Bluetooth audio signal for PS3 only carries voice chat. The game sounds and music are played through your TV or stereo receiver only.
  • If you want to listen to the gameplay with headphones then they will have to be compatible with your TV or stereo receiver.
2. Setup
A Bluetooth headset has to be registered, or "paired", with your PS3 before it can be used.
  • Make sure your Bluetooth headset is fully charged before you begin.
  • Check your headset instructions for entering "pairing mode". Activate your headsets' "pairing mode" so it can be recognized by the PS3.
  • On the Cross Media Bar (or XMB) of the PS3 go to the "Settings" tab, then down into "Accessory Settings", then down into "Manage Bluetooth Devices".
  • With your headset in pairing mode, follow the onscreen instructions and let the PS3 scan for your headset. When your headset is found, follow the prompts and enter a pass key (if necessary- the default is usually 0000 for all brands). The pairing should now be complete.
If you're using a USB (wired) headset, just plug it into one of the ports on the front of the PS3 (the system should auto-detect the USB headset).
Mic Test and Volume Setting
After pairing a Bluetooth headset, or after plugging in a USB (wired) headset, return to the XMB. Go to "Accessory Settings" and choose "Audio Device Settings". You can test your headset here.
  • Your headset should appear as the audio input/output device. If not, just use the D-pad to highlight the Input line, then scroll until you see yours. Any microphone you have used with your PS3 will be listed, but only the current one will be available to select.
  • Set the "Microphone Level" to 4. You can change the level any time if needed.
  • Speak into the headset, and the level bar at the top of the screen should move at the sound of your voice.
You can also view a list of Bluetooth accessories you have registered in the "Manage Bluetooth Devices" tab under "Settings".
If your mic doesn't appear there then try pairing it again.
There are more ways to configure the audio input and output that can be useful:
  • Set the input to (your mic) and leave the output on (default)- one person can chat with the other players, and the replys will play over your TV speakers rather than into your mic. Great when sharing one console because everyone can hear the team talk.
  • Set the input and output to (default)- you will hear the game sound and voice chat through your TV speakers but won't be able to talk back. Great if you don't have a headset, or if you want the room to hear the team chat.
  • Set the output to (default) to use stereo headphones with your TV or receiver. Then set the input to (your mic) and you can chat while wearing stereo headphones. Keeping the mic close to your face could be a problem since both ears are already taken! You could try a USB desktop mic and see if that works. I will add info on that as it comes in.
In Game XMB:
  • All of the functions in Audio Device Settings are available when using the XMB via the PS button during a game. You can set the input/output, mic level, and device. You can test your mic, and pair a new BT headset while in game.
For more help you can try these links:
3. Troubleshooting
General:
If you are having trouble with a headset after it is paired with the PS3, there are a few things to check first:
  • Make sure your headset battery is charged and working. Be aware that some brands/models will need to be paired again after each recharge. It's not a problem, it's just the way those models work.
  • Make sure your controller is charged. Lots of strange things happen when the controllers don't have enough power, like dropouts and headset interference.
  • The headset should be set as the input/output device from the XMB.
  • For Bluetooth users, make sure there are no other Bluetooth devices in use near your PS3. Also try to eliminate any other radio frequency interference if possible.
  • For USB users, make sure the connection is secure and there are no wire breaks.
  • Update your console to the current available firmware.
Nov 13, 2008 | Video Game Consoles & Games
Instruction manual for the datel bluetooth headset for Sony ps3
Here is a link for Sony with detailed instructions for pairing the bluetooth device to the PS3.
http://tinyurl.com/53tg8k
When it propts you for a code, use 0000.
Good luck to you and your son!! Happy gaming!!
Aug 21, 2008 | Microsoft 20GB Hard Drive for Xbox 360
Datel Gaming headset
*According To Other Gamers, They Believe That People Shouldn't Use Datel Headsets, So Im Off To Buy A New One.
Jun 28, 2008 | Video Game Consoles & Games
Datel Gaming Headset  for PlayStation 3 Logo
496 people viewed this question
Top Datel Video Game Consoles & Games Experts
Michael Galve
Michael Galve
Martin Murray
Are you a Datel Video Game Console and Game Expert? Answer questions, earn points and help others
