Question about Husqvarna Chain Saw 20" Bar
Engine cuts out
My Husqvana 357xp starts ok but cuts out afer 30 seconds or so whether idling or revving .
  • rodhalley Mar 09, 2009
    Yes thank you, I have found the leak and am replacing the line.
  • 42 Answers
You probably have a fuel line that is cracked or has a hole in it of some sort. You should be able to take off the top cover and inspect these lines. If this is the problem, replace with new line & should work just fine. Let me know how it goes.
Posted on Mar 07, 2009
Engine starts, no revs, engine cuts out!!!
ur battery is dead,please check battery orreplace with anew one
Feb 07, 2014 | 2003 Volkswagen Golf
I have a 4x4 89 s-10 4.3 v6 fuel injection. When I start my truck it idles high. After 30 to 50 seconds the idle goes back to normal. If I put in in reverse or drive when idle is high my back tires spin...
Sounds like the rear pads are worn out, your front brakes are keeping the truck from rolling. You need to have the high rpm checked for that 30-50 seconds as it is called the "cold start routine" and is meant to rev the engine for that time period. There may be an adjustment to keep it from over revving, check the specs for the rpm.
Even if you fix the rear brakes, the stress on the U-joints and differential or transmission is needless and can be fixed by limiting the high rpm in the "cold start cycle".
Jan 13, 2013 | Cars & Trucks
Revving up and down
Faulty idle air control valve.After you replace it you will need to reset the computer by disconnecting the ground cable on the battery for 30 seconds then re-install it and start it up it should run fine.
Aug 01, 2012 | 1993 Oldsmobile Cutlass Ciera
Bike cuts out when revved
low and hi speed jets need 2 be cleened . bad gas dude use stable when not in use tdays gas has a 30 day shelf life
Apr 28, 2012 | Motorcycles
357xp 359 After 15 to 30 min. of cutting engine gets extremly hot and cuts off. Checked spark plug,air filter, and made sure all cooling system components are cleaned. I was told it may be the...
The ignition coil is attached to the spark plug cable.Also check the spark plug number for the chain model.As the chain get older you can put a cooler spark plug and try before change the coil.
Nov 08, 2010 | Husqvarna Chain Saw Maintenance Kit 357xp ...
I have a 1996 volvo 850 station wagon and up until two days ago it worked perfectly for the past year. Now, however, when i start the engine it cuts out by itself after only a few seconds, and only won't...
Yes, it sounds like it is a fuel problem, whether it be the fuel pump, or more probably the catalytic converter. That check engine light can be checked by a mechanic where they can hook up to the engine and get the true error code to know why the light came on. Most often, it is an indicator that there is a problem with the catalytic converter. When that light goes on, the engine usually will run itself at reduced power. This could be why you are stalling when it is idle. Another thought is clogged fuel injectors, can't be sure, bring it to a mechanic for sure.
Good luck!! EJ Kudelka
Oct 18, 2010 | 1996 Volvo 850
Husqvana 65 chain saw will rev fully when idle but dies when introduced to timber
Sounds like the saw is running lean. Check the fuel filter, air cleaner and muffler for plugging. Check the condition of the fuel lines and that the fasteners on the carburetor are tight. If all ok, turn the 'L' and 'H' jet needles on the carburetor CW to stops (lightly), then back out each 1-1/2 turns CCW. This is a basic setting and the engine should start and run. Allow the engine to warm up, pull the throttle full on, and adjust H CW until the engine starts to speed up, but continues to 4-stroke. Proper adjustment is when the engine 4-strokes, but immediately 2-strokes when cutting. This produces the most power and least heat. Allow to idle and adjust L CW until the engine runs fairly well, yet will allow it to 'follow the throttle'. Set the idle speed screw til the chain stops moving, but keeps the engine running. Hope this helps!
May 12, 2010 | Garden
1986 Nova: engine stops while standing and at low RPM. OK before I got rear ended. Next start up: would not idle without revving. Next startup: OK but died while driving home; kick started without any...
Is the choke opening up all the way after it warms completly up ? and have you checked the fuel lines to the gas tank they might have got pinched in wreck.
Jan 02, 2010 | 1986 Chevrolet Nova
Check Engine Light Flashing Briefly and Throttle revving
go to a shop and see if there is a code stored in memory. anything else would just be a blind guess. If you are near an Autozone that do a scan for free
Dec 10, 2009 | 2001 Volkswagen Passat
Husqvarna 357 XP Hard starting when warm.
I work for warcks county council, the husky 357xp is our main saw. We've experienced the same problem with many of our new 357's. after many hours of trying to solve the problem (including swapping carbs from old broken saws etc) i stumbled upon, by fluke i'm afraid, a problem with the ngk bpmr7a spark plugs. They seem to work fine for a short period of time (even new out of the box) then leak compression from the cylinder. We are running a esser rated bosh spark plug which seems to have eliminated the problem, (can't remember the number, sorry). We have now ordered champion plugs to replace the stock. Probably worth a try. Hope this is of some help.
Kieran Tursner
Mar 04, 2009 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
182 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
