Question about Omnifi DMS1 Home MP3 Player
Omni mp3 player will not charge. I am connecting
Omni mp3 player will not charge. ( Omni MF4400P) I am connecting to PC via USB cable supplied, red indicator light stays on for 2 seconds and turns off. Will not play at all. Any advice at all?? Thanks so much
  • 3 Answers
Your USB cable may be broken?
Posted on Dec 02, 2009
Charging
MP3 players are charged via the supplied USB cable when it is connected to a computer. It can also be charged by a mains USB adapter charger.
Mar 15, 2012 | Asono Audio Players & Recorders
Lost charger for samsung yp-k3 2gb mp3
The MP3 player is charged by connecting the supplied USB cable to the MP3 player and then plugging the other end of the USB cable into the USB port of a working computer.
You can also purchase a 5 volt mains USB adapter. Connect the MP3 player and USB cable to this 5 volt mains USB adapter to charge the MP3 player.
Dec 28, 2011 | Audio Players & Recorders
I just got the mp3 player. ive been charging it but when i disconnect it from my computer it shuts off and wont turn back on. HELP!
Some older computers that have USB ports that limit the output to 5V @ .5 amp current. Depending on your MP3 player, it may not be sufficient to charge the player. This was the spec back then. Since then, new USB specs call for 5V @ 1.0 amp current - a two fold increase in current.
You may have better luck connecting to a powered USB hub instead. If you're only looking to charge the MP3 player, you don't even need to connect it to the computer. The powered hub gets powered by connecting the ac adapter / power supply to a wall outlet - instead from of the computer's power supply via mother board.
The above assumes there is a good, rechargeable battery; a functioning charger & USB port in the MP3 player and of course, a working USB cable. If any of the above is faulty, you'll never get the MP3 Player to accept a charge. You should try different computers, cables and ports if possible.
Sep 07, 2011 | Computers & Internet
How do i charge the Go Gear Vibe MP3 player?
You can charge it either by connecting it to your PC via a USB cable supplied in the box, or get a universal USB charger to charge it directly form an AC outlet.
Feb 23, 2011 | Philips GoGear ViBE Digital Media Player
How do i charge it
Refer to page 12 of your User Manual.
http://download.p4c.philips.com/files/s/sa3346_37/sa3346_37_dfu_aen.pdf
Connect to your PC with the supplied USB cable and it will charge via the PC USB port.
Dec 29, 2010 | Philips GoGear Flash MP3 Player
Hae bought 2gb Veg MP4 players. Can add music files to players when connectd to computer. But have tried to charge on numerous computers and they won't charge. Anybdy got any ideas or know how to fix? ...
Try to charge it via a battery charger. Change a USB cable to connect PC to make sure the USB cable is good. And change PC to charge the mp4 player. Compare the results, you will know where the problem is.
Jan 09, 2010 | Umax Vega108 MP3 Player
My sony walkman mp3 will not play on a dock
I had the same problem! Went on Sony trouble shooter found this -
Cause:
Battery is 100% discharged. Therefore, PC's USB with 5V/500mA set up has not enough power to start up the charging process because loading current is greater than the set up, therefore USB is disabled immediately due to sudden current load.
Remedy:
  1. Battery must not be discharged 100%
  2. If it happens then the supplied AC adaptor must be used firstly because it is providing 5V/800mA power. After a couple of minutes the unit can be connected to PC without problem then it can continue the charging during file transfer, etc.
Basically when the battery is totally flat the computer power is not strong enough to charge the battery and run the mp3 player! I bought a usb adapter charger and charged it up and now it works!
HOPE IT WORKS FOR YOU!
Mar 29, 2009 | Sony Network Walkman NW-E005 MP3 Player
My sansa fuze wont charge
Some USB ports cannot supply enough power to charge the Fuze. I had the same problem. I worked around it by getting a wall charger from RadioShack.
Mar 15, 2009 | SanDisk Sansa Fuze MP3 Player
My mp3 player
The user guide (p 7) mentions pressing the Power On/Off/Stop button (presumably only once, but see below) to charge the battery if the charging does not start automatically when the uncharged player is connected via USB.
The following is from Memorex online FAQs. Hope it might be helpful:
Connect the player with the supplied USB cable. After the cable is connected, press the power button twice. The battery icon in the upper right corner will start filling with bars as it charges.
Jul 29, 2008 | Memorex MMP8565 MP3 Player
Omni MP3 Player
I had the same problem! Later found that my USB cable was broken! Try another USB cable.
May 31, 2008 | Omnifi DMS1 Home MP3 Player
128 people viewed this question
Top Omnifi Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you an Omnifi Audio Player and Recorder Expert? Answer questions, earn points and help others
