Question about Whirlpool RBD305PD Electric Double Oven
My oven beeped and then the display went blank, light nworks when you open door and when push a button it beeps
  • 1 more comment
  • Anonymous Mar 10, 2009
    Same issue
  • bbullotta Mar 13, 2009
    I have the same problem. Just a bunch of beeps.
  • bbullotta May 11, 2010
    my concern is that something systematic in what relates to the day-to-day ventilation in/around the keypad will make this a recurring issue. The Whirlpool tech that came out was worse than brain-dead. Did no basic troubleshooting, commented none on the electrical wiring, nor ventilation/cavity size, read the same dang code that we saw off the display (it was dim at the time) and told use the same thing we Googled. Literally did not even open the oven, or even re-cycle power.
    Oh wait, yeah, he had the nerve to charge us $85 for the visit and quote over double cost for repair parts on our 14-month old $1600 oven. Cool. Thanks Whirlpool.
The power is going out to the control panel. It is easy to replace the whole controller. Be careful of the key pad cable. it will break easily. The part is $225 for the controller and $172 for the key pad. There are 4 resisters that heat up and a zen diode that fails DZ1. U1 also may fail. My RBD306PDB10 works great now. Do pay attention to the cavity size after re-installing the board.
Posted on Apr 01, 2009
Have a Whirlpool Gold Accubake Double Oven. After a power outage, the display is dark and ovens are not responding to keypad. Lights work both from doors and keypad. Directions?
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty.
GBD RBD Whirlpool Oven Problems Causes and Solutions
Feb 20, 2017 | Whirlpool Ovens
Why is display blank?
You may need new capacitors on your display board, if it is expensive you can have it rebuilt
Feb 29, 2016 | Whirlpool GBD307PR Electric Double Oven
My whirlpool double oven accubake GBD307PDS09 display went blank!!!! HELP!
Hello!
This blank display is a common control board problem. If the buttons beep when pressed, then the control board is getting adequate power. If the buttons beep.. and your oven light still turns on when the oven door is open.. this a text book control board failure. We at Fixyourboard.com can solve this problem for you, and back the remanufacture with a two year warranty. GBD RBD Whirlpool Oven Problems Causes and Solutions
May 03, 2017 | Whirlpool GBD307PD Electric Double Oven
I was getting a small "0" error message on the display of my Miele dg 155 steam oven. Tried Descaling but the process didn't complete, stopped at 10 minutes (33 minutes total) and started...
GO TO SERVICE MODE. TURN OVEN OFF OPEN DOOR MOVE KNOWB COUNTER CLOCK WISE TO DEFROST PUSH TEMP BUTTON 3 TIMES PUSH + BUTTON TILL YOU REACH 67 CLOSE DOOR AND WAIT FIVE MINUTES VOILA......
Feb 26, 2011 | Miele DG155-1 Steam Oven Single
Our home has a Whirlpool Gold built-in convection oven. The home is @5 years old. We've lived here for one year. Today, the display had an error message (E6). After we cleared the error message, the...
Hello!
Apr 21, 2017 | Whirlpool GBD307PD Electric Double Oven
Oven display went blank. Has Power.
Hello, The first thing I'd look at is your owner's manual to insure the timer hasn't been set to "Sabbath" mode accidently. If that is the case you could experience a "no display" scenario. The manual will also explain how to enter/exit the "Sabbath" mode. In the event the timer itself is at fault ( i.e. the display transformer gone bad ) it will have to be replaced or (if an available option exist's for your timer) have your timer rebuilt. Hope that help's and please take a second and rate the info provided by me here at fixya. Thank you and good luck. macmarkus :)
Dec 07, 2009 | Whirlpool Ovens
Whirlpool Accubake System Mod.# RBD275PB10 front panel blank
Hello Edward!
May 13, 2017 | Whirlpool RBD305PD Electric Double Oven
Neither oven will come on
Hello kybattey
Welcome to Fixya.
You said, After coming on and preheating Saturday, the upper oven went off and the lower wouldn't work either. Control paned was blank, but interior lights were on and pushing control paned buttons resulted in beeps. Turned off breaker for 5 minutes to reset and upon retry, the fan came on for maybe 5 seconds and then went off. Nothing else changed. Any suggestions?
You say the ovens went on and then later cut off.
Does the clean mode work?
Try the clean mode and see if it goes on.
Assuming it will clean!
Since the Range will clean you have confirmation that the proper power is reaching the range. It also verifies that the elements are in working condition. You will need to check the high temperature limit switch and the door latch mechanism. If either of these is defective, the bake and broil function will not operate properly
Let me know how it goes.
Waiting your response.
Huuum
Please remember to leave a rating when done!
Oct 20, 2008 | Whirlpool RBD305PD Electric Double Oven
No display, No beeps, No heat
I was able to fix my problem by pushing the setup button and holding for about 10 sec.No where in the manual is this described. I call Jenn air and all they could suggest is that I checked the power supply!
Jul 15, 2008 | Jenn-Air JJW8530C Expressions Collection...
Whirlpool GBD307PDS Double oven stopped working.
The beeping sound is a fault code. Problem is it isn't listed. In either the top or bottom oven panel there should be a service sheet. The codes are located on this service sheet.
Jan 22, 2008 | Whirlpool GBD307PDS Electric Double Oven
Whirlpool RBD305PD Electric Double Oven Logo
338 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
