Question about Refrigerators
Freezer working fine but fridge is warm. there was an occassional clicking sound off and on for a few days that stopped when the fridge was turned off and back on. Then with no warning about a week ago the fridge stopped getting cold. Freezer still working and the fan in the freezer is operating normally. (Roper RT 188KXK000)
    Brigadier General:
  • 6,966 Answers
Hi and welcome to FixYa,
Almost always, your described condition indicates that the air from the freezer is not being drawn to the refrigerator area. Since as you posted, the fan works, try to determine if a draft of air could be felt where the fan blows down to the refrigerator section. If yes, then suspect the the freezer's temperature is not cold enough to extend to the refrigerator section. This may be brought about by a faulty thermostat. If no, then it would be likely that for some reason the air passage way is blocked and therefore the air from the freezer is prevented from going to the refrigerator section.
A way to test is to open the refrigerator door. Locate and press on the door switch. Inside light should turn off. Maintaining this position after a minute or so, the fan should kick in. Try to feel if their is a strong air flow, if none, then air path is block (or fan not working).
Hope that this be of initial help/idea. Pls post back should you need additional information or for any updates on developments.
Good luck and thank you for using FixYa.
Posted on Mar 05, 2009
    Sergeant:
    Champion:
  • 315 Answers
If you have already checked the thermostat setting inside the fridge to make sure its not set to the warmest setting, then there really isnt anything anyone here can do without actually looking at the fridge, checking the refrigerant, checking the compressor, the evaporator, etc.
A qualified refrigeration technician can certainly troubleshoot it for ya.
  • Roger Gantner Mar 05, 2009
    Shooting for the 6 bucks, are we?
We have a Bosh KIM29473GB for some time water has been collecting in the bottom tray of the fridge and only takes a few days to fill up, this weekend the freezer stopped working and now nothing works.
If you hear a click every few minutes and a buzz / click then nothing, it would sound as if your compressor is gone, the water problem is the defrost drain pipe is blocked
Oct 06, 2014 | Engel Freezer 22 Qt. Fridge/Freezer
Is it worth getting my fridge freezer fixed?
Check out the start cap/relay on compressor.
Apr 10, 2017 | Refrigerators
Fridge and freezer warm. Mildly cooler air is coming out but the settings are on 7 for both fridge and freezer which are the coldest. Hard to tell if its actually cooler air or just seems that way because...
Many times a freezer and/or refrigeratordo not work right because of a dirty condenser coil...there are also many otherthings that can go wrong. If you are hearing a clicking or buzzing thencheck out the last two tips.
If your refrigerator is running but warm, then...
Check out these tips that I wrote about that... it is a great place to starttrouble shooting your unit...and something that you can do rather then callinga repair person to do a simple thing for you...
Refrigerator Condenser Coil Cleaning Refrigerator Repair
Refrigerator Troubleshooting Refrigerator Compressor
Refrigerator Compressor Start Capacitor and Start Relay
Refrigerator or Freezer not Cooling or Getting Cold
heatman101
Jun 02, 2011 | Maytag MFD2560HES Bottom Freezer French...
The fridge will operate fine for about 2 or 3 days and then the inside will get warm and melt all the ice. I will unplug the unit for a few days plug it back in and it will operate fine for a few days and...
Sounds to me like you have a bad defrost timer. As the freezer is working correctly, it is building ice on the evaporator. It sounds like it does not go into defrost, thus freezing up the evap coil, and stopping the evap from cooling the surrounding air. Hope this helps
Jul 23, 2010 | Frigidaire Refrigerators
Kenmore refridge/freezer just stops working. I
. Cut everything off for a few minutes then turn it back on and listen for a click from the compressor relay as the compressor tries to start.
Is the compressor motor running.If no check starter/overload relay.
Check to see if the condenser fan at the back underneath near the compressor is running. If no check fan.
Are the condenser coils near there warm or room temp. should be warm
How to check stuff>
http://www.acmehowto.com/howto/appliance/refrigerator/refrigerator.php
Sep 20, 2009 | Refrigerators
KGU 34641 GB TOP REFRIGERATOR
Hi,I believe you may have a blockage in the intake from the freezer to the fridge as cold air is blown up from the freezer to make the fridge coldhope this helps,mike,
Aug 10, 2008 | Bosch KGU34641 Bottom Freezer Refrigerator
Fridge stops working when power goes out.
It sounds like maybe the freezer fan is coming back on ??? Do you hear it in freezer?? I would recommend having it looked at ----this definately doesnt sound normal.
Jan 16, 2008 | Kenmore Elite 21082
Refrigerators Logo
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
