Question about D-Link DI-634M Wireless Router (DI634M)
Connecting D-Link DI-634M to HughesNet HN9000
They are both 192.168.0.1. If I change the DI-634M to .0.2 and have it reboot, IE can't connect and I have to press the reset button (putting it back to 192.168.0.1). The HN9000 CAN'T be changed to .0.2 (according to the morons at HughesNet). All they would tell me was to disable DHCP on the wireless and to set the default gateway to 192.168.0.1 (which is the address for BOTH devices). Any ideas how to get the wireless to go through the HN9000 to the internet? When I was connected to WildBlue their router just WORKED when I plugged it into my DI-634M. I didn't have to change anything!
  • mailmanscott May 24, 2009
    I'm having the Same problem with the d-link DIR-625. I have the HN 9000 too. When I look at the IP list of the Hn 9000 it says last available ip address is 192.168.0.254. Would this make a difference? It would not let me connect to the internet though. I can see both computers on the network but niether pc will connect to the net. If I connect the desktop back to the hn9000 it works fine.
    Also where would I set the default GW on the router? If any one can walk me through this I would greatly appreciate it! I have been trying for almost a week!
    Scholar:
  • 82 Answers
I hate it when ISPs give you devices that dictate how your network has to be setup. They should just give you a modem which give a public IP to whatever connects to it.
For this to work you have to connect the cable from the hughes box to your router on one of the four regular jacks on the back NOT the internet/wan jack you would normally use.
Set the IP of the Dlink to 192.168.0.254
Subnet mask 255.255.255.0
default GW 192.168.0.1
This SHOULD allow the router to act like a switch. I have a linksys that has an option to make it function as an access point , which is what you need for this modem, but I dont see any option for the d link you have to do that.
Hughes have a knowledgebase which may be of some use to you.
Here
Posted on Mar 05, 2009
I have a dlink model no di-634m where i am unable to connect into net and wireless is not working .... can i get help urs to repair my dlink
Try RESETTING the D-Link back to the default settings.
Press and hold the RESET button at the back of the routerwith the power ON until the LEDs flash at the time the release the RESETbutton.
Connect a LAN cable from the D-Link to your laptop/computer's LAN port, openthe browser on your laptop/computer and enter the D-Link's configuration URL..
http://192.168.0.1
The default login = admin
The default PW = blank (just press Enter) You can now change the default password.
You can now configure the wireless settings. To secure your wireless network from unauthorized access,please click on this link and follow my instructions :- http://www.fixya.com/support/r3559128-wireless_router_security
Apr 22, 2011 | D-Link DI-634M Wireless Router (DI634M)
Can I use a D-Link DI-634M as a repeater? how?
Sorry, no, the DI-634M does not have the repeating function.
Mar 06, 2011 | D-Link DI-634M Wireless Router (DI634M)
How do u access ur wireless setup instructions for d-link routers on internet explorer?
Heres a link to the support site http://www.dlink.co.uk/cs/Satellite?c=TechSupport_C&childpagename=DLinkEurope-GB/DLTechProduct&cid=1197319378173&p=1197318962293&packedargs=locale%3D1195806691854&pagename=DLinkEurope-GB/DLWrapper
Quick setup from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_qig_100.pdf user manual from here ftp://ftp.dlink.co.uk/di_broadband_gateways/di-634m/di-634m_manual_100.pdf
Connect the PC to the router by cable then to log into the router using the default settings
  • Open the Web browser.
  • Type in the IP Address of the Router http://192.168.0.1).
  • Type admin in the User Name field.
  • Leave the Password blank.
  • Click OK.
now goto the wireless settings on the router to see the settings being used
  • If this solutions solves you problem, please do not forget to rate my solution.
  • If not, then please comment back so I can help some more
Apr 01, 2010 | D-Link DI-634M Wireless Router (DI634M)
My DI-634m Is not giving me an IP address
Are you trying to connect to the wireless network ?
If you are not getting the IP address then you might not be connected to the wireless network.
Make sure that you know all the correct wireless settings of the router.
If your network is secured then you have the correct network key.
If you are not sure about the wireless settings of the router then you will need to access the router set up.
Click Here for step by step solutions
Nov 13, 2009 | D-Link DI-634M Wireless Router (DI634M)
Both units can not have the same Gateway IP.
Do this:
Hook your PC to the HN9000. Do an ipconfig /all
Write the IP info down.
Then open up the D-links set up page and set it to a static IP using the info you gathered from the HN9000. Select an IP in the range that the PC picked up. I usually use .100. Also, when you set it statically in the D-Link, make sure that you type in the Primary and Secondary DNS.
Once you set the D-Link statically , you should be able to browse the Net through the D-Link.
If I could be of further assistance, let me know. If this helps or solves the issue, please rate it.
Thanks, Joe
May 24, 2009 | D-Link DIR-625 (790069292637) Wireless...
How to reset the d-link di-634m wireless router
go to this link to to reset your d-link 634m manually: http://www.retrevo.com/pdf/426bh043/6/Hardware+Overview#q=D-link+DI-634M
Apr 14, 2009 | D-Link DI-634M Wireless Router (DI634M)
What is the d-link part number for power adapter for D-link Di-634M router?
what is the d-link part number for power adapter for D-link Di-634M router? How can I get this?
Mar 28, 2009 | D-Link DI-634M Wireless Router (DI634M)
DLINK DI-634M WIRELESS ROUTER USED AS A REPEATER?
No. Here is the help guide:
http://support.dlink.com/Emulators/di634m/help_men.html
copy and paste the complete link into your browser.
Thanks, Joe
Nov 19, 2008 | D-Link DI-634M Wireless Router (DI634M)
Wireless network has disappeared !
If I understand your post/description:
1. You have both wired and wireless clients tied to the DLink DI-634M router;
2. The 1st PC is a desktop that uses Ethernet connections to the DLink and is currently working;
3. You have another (2nd) PC (a laptop?) that is connect by WiFi to the router. This is not working now;
I think that your issue may have to do with the Wireless networking of your 2nd PC, i.e. if you can access 192.168.0.1 (DLink DI-634M) from the 1st PC that is wired.
Should this be the case or the scenario is different, pls post back.
Hope this be of initial help/idea. Pls post back as requested or should you be in need of additional information.
Good luck and kind regards.
Jan 21, 2008 | Computers & Internet
D-Link DI-634M Wireless Router (DI634M) Logo
1,271 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
