Question about HP DeskJet 3940 InkJet Photo Printer
Printer goes shows offline, but it is not offline.
Power led blinks continually
  • 1 more comment
  • Elly Apr 30, 2009
    Iv been trying to print something that is 2 pages long. It prints out the 1st one fine, then the 2nd one comes out really bad, like the inks low, but I just refilled it maybe 2 weeks ago.. Theres no way its empty.
    The power LED light blinks continually, when I press it, nothing happens.
    When I turn off the printer and turn it back on, nothing changes!
    This has happened continually for the past week, but only when I try to print out something thats 2 pages or more.
    help?
  • Jay Selway
    Jay Selway May 11, 2010
    Does it also do it when the printer is not connected to the computer
  • Roger Gantner May 11, 2010
    it's HP's way of saying that it's time to buy a new printer.
    Problem Solver:
  • 17 Answers
Either one of the catridge is malfunction, try remove one of it and vice versa see if it not blink. if not, the catridge that you have removed require replacement..
Posted on Mar 06, 2009
Blinking power light,shows,offline,and will not print
Blinking power light can be either out of paper or out of ink. Have you checked Paper and Ink levels?
Mar 03, 2011 | HP DeskJet 3940 InkJet Photo Printer
Blinking lights, ''offline'' status - hp deskjet d2360
If it used to work, then try unplugging and reconnecting the AC power cable for USB scanners. No guarantees at all, but it may work. Unplugging and reconnecting the Firewire cable in XP also sometimes works. Give it a few seconds to be detected.
Jan 05, 2010 | Office Equipment & Supplies
It just started blinking and says the printer is offline
If it says printer is offline, it usually means your printer is not connected to the PC. Blinking printer light means there is a problem with the printer (usually paper jam) or with the ink. Check the ink cartridge. Take the cartridge out and put it back in. Make sure you also check the USB cable that goes from your printer to the PC, take it out and put it back in. Also, try to turn off the printer, take it out of the power outlet for 30 seconds and put it back in. If you have a power strip, don't use it, try plugging it directly to the power outlet on the wall and turn it back on.
Nov 09, 2009 | HP Deskjet D1430 InkJet Printer
Can I do something myself when this shows up? Error Number : 1700 The waste ink absorber is almost full. Press the printer's RESUME button to restart the printer. An error may occur if you continue to use...
Try to do this:
1) Close the print head cover, and turn off the printer. While pressing the Resume/Cancel button, press the Power button. (Do not release the buttons. The LED lights in green to indicate that a function is selectable.)
2) While holding the Power button, release the Resume/Cancel button. (Do not release the Power button.)
3) While holding the Power button, press the Resume/Cancel button three times, and then release the Power and Resume/Cancel buttons. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.) During initialization, the LED blinks in green.
4) When the LED stops blinking and lights in green, press the Resume/Cancel button the 4 times. (Each time the Resume/Cancel button is pressed, the LED lights alternately in either orange or green, starting with orange.)
5) Press the Power button. The LED lights in green, and the
selected function is performed. (When the operation completes, the printer returns to the menu selection mode automatically.)
6) Power off then back on and test.
Oct 07, 2009 | Canon i80 InkJet Printer
Printer's Offline
go to start and control panel, choose option for Printers and under that you will see the Printer listed. You just have to make a right click on the Printer and choose option "USE PRINTER ONLINE"
May 19, 2009 | HP Deskjet D2360 InkJet Printer
Brother Laser Printer HL 1440
tray this
The procedure for the factory inspection mode is as follows.
(1) Turn off the printer power switch, open the front cover, and remove the drum unit.
(2) Turn on the printer power switch while holding down the control panel button. The Drum
LED comes ON.
(3) Lightly press the panel button again.
(4) Check that all the LEDs except the Ready LED are OFF.
✒ If the toner sensor is ON, the Drum LED stays ON (error).
✒ If the front registration sensor is ON, the Alarm LED stays ON (error).
✒ If the upper paper cassette sensor is ON, the Data LED stays ON. (error) (HL-1250
only)
NOTE:
The lower paper cassette solenoid is turned ON/OFF even if the panel button is not pressed.
(5) Check the rear registration sensor.
✒ If the rear registration sensor is stuck backwards, the Ready LED stays OFF. (error)
✒ If the rear registration sensor is moved back and forth, the Ready LED comes ON at
any time. (error)
(6) Check that only the Data LED comes ON while pressing the panel button.
✒ If the paper eject sensor is ON, the Drum LED stays ON. (error)
✒ If the lower paper cassette registration sensor is ON, the Ready LED stays ON. (error)
If the registration sensor is ON, the lower paper cassette solenoid is turned ON, and
the Ready LED also stays ON. (HL-1250 only)
NOTE:
(7) Install the drum unit.
✒ Check that the Drum LED goes ON and the Ready LED goes OFF.
(8) Close the front cover.
(9) Continue to press the control panel button.
✒ Check that the Data LED stays OFF.
(10) Release the panel button.
(11) If all the sensors except the toner sensor are correct, the printer goes back to the Ready
status.
If any error is detected, the printer stays in the inspection mode.
Apr 01, 2008 | Brother HL 1440 Laser Printer
Printer light keeps blinking and status stays offline even it is READY
UNINSTALL AND REINSTALL THE DRIVER SOFTWARE BRO...................
IT MAY LEAD U 2 A SOLUTION.........
TRY IT
Nov 14, 2007 | HP Deskjet D2360 InkJet Printer
HP DeskJet 3940 InkJet Photo Printer Logo
303 people viewed this question
Seeker5211
Seeker5211
