Question about HP ScanJet 3670 Flatbed Scanner
Scanner belt stuck how i can solve this problem
Scanner belt stuck.bad noice from the scanner by this belt stuck. how i can solve this problem
  • Anonymous Mar 11, 2009
    scanner belt stuck how,when we scanning it makes very bad noise i can solve this problem
You must remove u r scaner outer cover and again fix outer cover
Posted on Mar 05, 2009
On my IPS600 D6. Have intermittent chirping noice around belts near electromagnetic engaged supercharger?
chirping can be a bearing problem on one of the pulleys or components causing belt to slip --worn or bad belt --
Sep 02, 2016 | Cars & Trucks
Eror scaner in samsung laser printer cx 4300
  1. check scanner cable.
  2. check scanner home position sensor
  3. check belt
  4. replace scanner motor
  5. main board
Jul 25, 2015 | Samsung Office Equipment & Supplies
What is the whining noice 2007 mercedes c230 whining noise
in the engine could be worn out belt or loose, low power steering fluid, bad idler pulley alway related to the belts.
Oct 16, 2014 | 2007 Mercedes-Benz C230 Sedan
Drivebelt making noice
Possibilities are:
1) Loose or worn drive belt (look for slickness on underside of belt)
2) Bad bearing on water pump indicating it's due to fail
Apr 04, 2012 | Cars & Trucks
My automatic seatbelt doesnt work anymore. i have a 1990 accord lx 5-speed and it used to get stuck have way and know it wont recline at all. is it a bad fuse or the computer? i disconnected the seatbelt...
If both passengers and drivers side retractable belts have stopped moving, then it's likely the controller that's located under the passengers seat has gone bad. If only one side has stopped retracting and moving then that side motor has probably gone bad.
Sep 15, 2011 | 1990 Honda Accord
Error 52.00 Printer says cartridge installed. Looks all ready. Starts making a noice as if to print then stop within 1 second. Nothing shows on the print queue
52 error is a bad laser scanner. The scanner needs to be replaced. No other way to fix the problem. If you want an idea of cost call us at 262-993-1551.
Sep 02, 2010 | HP LaserJet 2300 Printer
Makes ratcheting noice when put into carpet
Cog belt is slipping, could be debris on the pulley or bad belt or cog wheel....
Feb 15, 2010 | Dyson DC14 Animal Bagless Upright Cyclonic...
Engine Belt
hi there it sounds to me that the bearings are going bad on your ac/c compressor
you can bypass it by getting a smaller belt
to get a size you can take a piece of string or rope and go around the remaining pulleys like alternator power steering and crank shaft then tie a know take it to napa and have them match as close as possible then install that belt this will solve your problem until you replace the compressor
the other way is go to a salvage yard look for you make and model without a/c there will be most likely a pulley and bracket in the place of the a/c compressor
take a picture of the set up and take the pulley off including the mount bolts and then remove th compressor on your car and install the pulley and you can use the same belt
don
Sep 12, 2008 | 1991 Oldsmobile Cutlass Ciera
Umax Astra 1200S Scanner Problem
Open ur scanner ,s back body(its very easy)remove belt.. just clean scanner, s belt and dust from scanner with soft cloth..put it belt again..
Mir
Jul 05, 2008 | Umax Astra 1200S Flatbed Scanner
HP ScanJet 3670 Flatbed Scanner Logo
1,176 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
