Question about Panasonic PanaFax UF-8000 Laser Fax
Panasonic UF 8000 Black Streaks
I am getting black streaks on multipage copy/fax receptions
  • rs1adv Mar 06, 2009
    Tried imaging unit in another UF8000 and it works perfect.
    Genius:
  • 2,120 Answers
Replace the imaging unit. (drum)
Posted on Mar 06, 2009
THERE ARE LARGE STREAKS OF INK ON ALL COPIES AND
The green roller is the drum which has a cleaning blade to remove excess toner, when the drum gets older it becomes clogged and will dump toner back out onto the drum. Just some info on it. Best fix is replace the drum, you could take it apart and attempt to dump and clean it but it's rarely worth doing that.
Jan 04, 2010 | Brother IntelliFAX 4100 Laser Fax
Copier, Printer black streaks on copy or all black page
Hello sir; Either drum cleaning blade or drum cartridge needto replace.
Aug 20, 2009 | Brother Office Equipment & Supplies
Panasonic UF-490 - Two streaks down page
Either the glass is scratched or the sensor has gone bad that is used to scan the image.  Are you using a document feeder or laying it flat on the glass?  If you are laying it flat on the glass then it is most likely a sensor going bad.  If you are feeding it through the document feeder it could be that the feeder itself needs to be cleaned, or the paper path through the feeder.
If it is the sensor you will need to send it out for repair.  There may be an option to re-calibrate the scanner in the software, that may help if the sensor has just degraded and not failed.
I hope that helps.
May 02, 2009 | Panasonic PanaFax UF-490 All-In-One Laser...
Getting big black streaks though copies
OK I am guessing this is a Laser Fax or an Inkjet Fax- If it's a Laser Fax,chances are you may have a "BAD" drum and if this is a Ink jet most likely and "Leaky" cartridge.
May 01, 2009 | Office Equipment & Supplies
The fax streaks
Open the lower part of the number panel by pulling up 1 inch. and clean the small scanner glass.....hard to see.
Mar 02, 2009 | Panasonic Panafax UF-790 Plain Paper Laser...
Black vertical streaks on faxes & copies
On top of the toner/drum cartridge there should be a blue slider, move back and forth 10 times.
If no fix, you need a new toner cartridge.
Dec 30, 2008 | Brother IntelliFAX 2600 Fax
Dirty copies.
Does this streaking problem occur when printing (not copying)? If it does then you are probably looking at a consumable issue. Alot of times black streaking is caused by a defective or spent drum. Is your drum new? There is also a blue piece on the drum unit used to clean the corona wire that cleans the drum. Have you tried moving it back and forth several times?
If the problem only happens when copying and the streaks are as bad as you make them out to be then you problem have a bad CIS unit (scans your originals for faxing or copying)
Inkworks
866-381-0541
Nov 21, 2008 | Brother IntelliFAX 4100 Laser Fax
Blank Streaks
streaks are caused either by the toner, drum, lamp or fuser.
If you make a copy and it does not show a streak then it was done by the person sending the fax. BUT, check this,
open door and take out toner cartridge. look for a thin glass that is on the bottom of the machine and wipe it. Toner spills will cause a black streak.
Nov 15, 2007 | Brother IntelliFAX 2800 Laser Fax
Panasonic PanaFax UF-8000 Laser Fax Logo
122 people viewed this question
Top Panasonic Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Mitch S
Mitch S
Level 1 Expert
HEMANT GROVER
Are you a Panasonic Office Equipment and Supply Expert? Answer questions, earn points and help others
