Question about Panasonic Viera TH-46PZ85U Plasma TV
Viera TH-46PZ85U. gray box where picture should be
My TV was working fine today until I tried to watch cable after playing a video game. All this entails is unplugging the av cables for the console (completely separate ports than the cable connection), and change inputs on the tv. I did this, got sound and the guide and menus but in place of the picture there's a gray box.
I've tried changing inputs, plugging and unplugging connections... I have no idea what's wrong. I assume it has to be  TV setting since the cable info (guide, channel bar, menus) all show up.
  • 2 more comments
  • alyson_wrigh Mar 05, 2009
    it's normal. i guess i shouldn't really call it a box it's just like in place of the picture, in between the black bars that change with aspect.
    and i have the cable box hooked to 2 tvs, the image appears fine on the other tv.
    Thankee!! I'll try that :)
  • Jay Selway
    Jay Selway May 11, 2010
    What happens if you switch back to your game? Does the gray box still appear, or is everything normal?
  • 93 Answers
If it was a setting on the television, then the cable info would also be affected. Try a reset on your cable box, as the cable info is generated within the box from the data stream, whereas the picture is streamed from the provider.
If the reset doesn't work, it's time to call the cable company - it's not a fault with your telly.
Posted on Mar 05, 2009
I have a Panasonic th-46pz85u. It's been working fine, but now all the hdmi ports have quit working, but the component inputs work fine.
Contact the authorized service center for Panasonic. Please do not make any experiments. The fault is simple now; do not make it irreparable. Surely you can't repair this fault.
Gopakumar Gopalan Google
Jun 29, 2015 | Panasonic Viera TH-46PZ85U Plasma TV
10 blinks code
I don't know what to do with 10 blinking of my Panasonic TH-46PZ85U.
I bought It in summer it already kaput ? I'm not sure any more to want to make repair my tv set. I wonder how much could it cost ? Bye-bye plazma.
Aug 18, 2012 | Panasonic Viera TH-46PZ85U Plasma TV
There are 6" wide gray bars on each side ot the TV
The grey bars signal that the source image is originally in 4:3 format - if you are using a box of some kind get in its menu and change the format from there to 16:9. The black bars appear when a 16:9 image is sent to a 4:3 format in Letterbox mode - leave it like that or the Pan and Scan mode will chop the sides.
Jul 20, 2011 | Panasonic Viera TH-42PX80U Plasma TV
I have a Panasonic TH-46PZ85U Plasma TV with a two blinking light code, no picture. How do I fix. I Have removed the back panel and looked for damaged caps but I do not see any.
hi; the blinking light code means that you have a fault in the power supply unit, unplug the tv from the power source, check all transistors you will find some of there shorted, just replace them; if you need a help about repairing i'll help you
Nov 06, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic plasma viera tv will not auto tune, can not pick up any signals at all. All cables are plugged in correctly. Model number TH-P46G10A
Reboot all cables,satalites,and telicoms boxes.Like unplug,replug the box an hour later.Let the boxes up grade software,go to ur tv menu setup rescan all channels again well get them back.Ur signal not there after that, than ur Tuner Signal board is dead.Need it replaced.
Mar 13, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Panasonic TH-46PZ85U Plasma TV All 3 HDMI was working fine with cable box, PS3, XBOX360. I used to connect my pc to the tv with a dvi-hdmi cable, but recently unplugged it. So I tried to plug in the same...
TV shuts off unless all the input (phono and HDMI) cables are disconnected. The
symptom may be intermittent.
There is an abnormal AC voltage entering the TV from one of the input cables or AC
Follow the Testing procedure to determine if there is a problem external to the product.
Constant symptom
If the TV no longer shuts off when all input cables are disconnected, then one of the
input cables is introducing abnormal voltages into the TV. Panasonic Plasma TV sets
have 3 wire AC plugs.
As a result, abnormal voltages introduced into this TV will cause the TV to shut off for
Intermittent symptom
If the abnormal input voltage is borderline (marginal), the TV shut off symptom may be
intermittent. However the cause may still be detectable with a voltmeter.
Protection Proof:
Release the protect mode - the TV has to be unplugged to reset this protection circuit.
Threats from the HDMI input:
Excessive voltage from an HDMI cable connected product will activate the Plasma TV’s
protection circuitry. Placing an isolating / buffering connector (sometimes called a voltage
conditioner) between the TV and the HDMI input cable often solves the problem.
Testing -
Unplug all the HDMI inputs from the TV. Turn on the TV. Plug in the HDMI inputs one at a
time. The cable that causes the TV to enter the protection state is connected to the product
that has the excessive voltage (and signal). Avoid connecting this product until an isolating
connector is found.
Jan 27, 2010 | Panasonic Viera TH-46PZ85U Plasma TV
Blue ray disc player is working fine, but the tv is not showing any channels. We are just installing our new tv. What did we do wrong?
I just bought a samsung BD-P4600 and I tried to connect with a Philips Plasma TV. What channel do I need to put it on for it to show?
Sep 07, 2009 | Panasonic Viera TH-42PX80U Plasma TV
Color Adjustment Problems - Reception in Black and White
satelliteand cable TV is only comes in black and white.
this a HTML type plug or a coaxial
select menu and source
very weird... should default to colour
if no luck try plugging in a desk top digital box tune using that
TH-42PX20 TH-50PX20 Operating Instructions High Definition Plasma ...
Apr 24, 2017 | Panasonic VIERA TH-65PV500 65 in. Plasma...
Picture turns Blue-Gray after 30 min
cheak cables what cables uusing ? thx nick
Feb 07, 2008 | JVC TH-M65 System
Panasonic Viera TH-46PZ85U Plasma TV Logo
275 people viewed this question
Top Panasonic Televison & Video Experts
Are you a Panasonic Televison and Video Expert? Answer questions, earn points and help others
