Approx 70's Rinnai Gas Heater broken fan
Hi i have an old gas heater that i suspect is the fan that has gone. AIt was just working last winter i cleaned and oiled it but now after an extra month or two it died. Just as it was getting warmer. (Thank God)
I would like to know the price of replacing the fan please. Is it worth my while. I rang one repair place and they told me parts and labour up to $400.00 I don't want to pay this as i think the heater would be better replaced but that is also alot of money.
Please help me.
Thanks
Maribel
Masport mower Xts60 keeps cutting out hard to keep it iddeling, if i pump the bubble on the air filter it will keep going for a short time.
not sure how the carburetor works
Posted on Nov 28, 2009
E:01 fault on a rinnai energysaver 403FT
Rinnai 403FT sounds like a fairly old heater (probably about 15 years old???).
There is no E:01 in the instruction manual but a E:07 which is overheating. Could it be this number instead? If so it could be caused by too much dust inside (or the fan not working anymore, if that's the case... sorry but good luck to find the part...)
With gas heaters, the other basic question you should ask yourself is "when was the last time I serviced my heater??". It is recommended to get them serviced every 1 or 2 years.
It consist in having a licensed gas fitter to open it and clean/test everything inside the heater (yes, like your car).
9 out of 10 problems with a gas heater are solved with a simple service, I would suggest you get a gas fitter to check it out!
Apr 20, 2013 | Heating & Cooling
We have a Rinnai REH-15F-2A natural gas heater (approx 15 yrs old). it has just started going out, it doesn't leak gas. is this something repairable or beyond repair? thanks tameka
Tameka, what you described sounds like the Thermocouple or Thermopile is failing. If your heater is a Flue-less heater, the Oxygen Depletion Sensor (ODS) which is part of the Pilot assembly, may simply need cleaning. Any of the causes I listed are repairable and would require a service technician to do it.
Hope this helped you. Please let me know.
Jul 06, 2011 | Rinnai Heating & Cooling
We get a horrible smell occasionally with our Rinnai Avenger 25 nat.gas heater when alight. The filters are clean & was serivced last winter. It was making the smell at times even after the service. It...
From what you have described, it sounds like a case of delayed ignition or as the Owner's Manual calls it a "Combustion Control Fault"or "Incomplete Combustion". This can be caused by several things: A change in the gas pressure; dirty or clogged burner, electronic fault in the combustion controls.
Despite having it cleaned an services last Winter, 12 months have elapsed, with the unit just sitting and collecting dust and spiders. Portable Heating units should be serviced annually. Usually in the early Fall, before firing it up for the heating season.
Hope this helped you ... Cheers.
Jul 06, 2011 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
I have a Rinnai Avenger 25 gas heater. We turned power and gas off after last winter, now we cannot get it to light. It will light for roughly 10 secs and then goes out. There are no numbers set in timer.
Since the gas has been OFF since last Winter, I suspect that there is air in the gas line that needs to be purged. In addition, if it has not been cleaned and serviced annually, the pilot and the burners need to be cleaned. Spiders & other insects love to build nest in them while they are off. Not to mention, accumulated dust. Unplug the unit before attempting any service work.
Purging and cleaning should solve your problem.
Apr 12, 2011 | Heating & Cooling
I have bought a house with a Rinnai heater which is approx 20years old. In the 5 weeks I have been here it has gone every day first try. Tonight after constant starts it just will not ignite. The spark...
The obvious question is are you sure you have not run out of gas or has an isolation tap been turned off by mistake. Do you have anything else on gas that is still working ok. Check this one first and I am willing to keep an eye out if you re-post the fault.
Aug 04, 2010 | Rinnai Heating & Cooling
I have a trouble code 11 on my Rinnai model 2532 water heater which indicates no ignition. I checked for gas supply by turning the furnace on which is approx. 1 ft. away, it works. The water heater is...
11 is a ignition failure code. Could be alot of things, I suggest calling a tech who has repaired these before. Pull the front cover off and have a helper turn on a hot water faucet. Look thru the viewing window to see if the unit is firing then going out. If not, clean out the water filter on the inlet side of the plumbing. You will need to turn off the water supply prior to cleaning it. If the unit fires but shuts off seconds after ignition, you may have a dirty or bad sensor. Call a proffessional at this point. Sorry
Oct 18, 2009 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Rinnai Tankless Water Heater
Question, is there any other equipment that uses propane? You indicate that the problem started after a delivery of propane after running out. If so, I suspect a blockage in either the gas train or the rinnai itself. If tou have the temperature control that regulates the water temperature, you can recall error codes to pinpoint the issue. They are optional equipment so if you can wire one in or ask your propane gas supplier if their service department has one, it will aide in the diagnosis.
Nov 22, 2007 | Heating & Cooling
Rinnai RHFE 1001FA
i have a rinnai rhfe 1001fa heater and when its real cold sometimes it will shut down all the lights go out and i have to shut it off then turn it back on and sometimes it still wont start and i will leave it of for a day or two then try it and it will work it seems to act up more when its colder i am running it this fall so far no problems this unit is around a 1994 or so and has not given any trouble till this started last winter
Mar 11, 2007 | Rinnai RHFE-1004FA 38,400 BTU Energy Saver...
Heating & Cooling Logo
152 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
