Question about Pentair 1.0 Hp Whisperflo Pump
Pentair mini max will not ignite. I have no power to the igniter so the igniter will not glow. I have a volt meter and some experiance. the gas valve doe's release gas for a few seconds.What steps should I take. Joe
  • bulldogsja Mar 11, 2009
    IT ATTEMPTS TO START, THE GAS VALVE OPENS BUT IGNITOR WILL NOT TURN RED HOT. IT WILL ATTEMPT 3 TIMES THEN LOCKOUT CODE. I HAVE 24 V TO THE IGNITION MODULE SO I PULLED IT OUT AND FOUND THE BOARD IS FRIED. WHAT I DID NOT SAY IS THAT AT FIRST I FOUND THAT THE IGNITER WAS BROKE SO I CHANGED IT THEN I STILL HAD NO GLOW AT IGNITER. I THINK WHEN THE IGNITER BROKE IT FRIED THE BOARD IN THE MODULE.I FOUND A REBUILT MODULE I AM GOING TO TRY IT AND I WILL POST RESULTS. JOE
    Problem Solver:
  • 10 Answers
Does it attempt to start (meaning, does gas valve open and ignitor turn red hot, and heator starts and then turns off) Then repeats the cycle and then after 3 attempts gives you an error code..
Posted on Mar 11, 2009
Pentair mastertemp 250 NA. heater will not fire, no error codes. starts fine, gas flows, igniter heating but still will not fire. It has a new valve, gas pressure entering valve from new regulator is 8.35...
All appearances - No fuel to ignite!
evrything else looks good, proper gas pressure, proper volts at igniter, etc - it should ignite! If fuel present, heater should Fire!
make sure all valves are open.
Gas valve is ON
AND purge any air from gas line.
IMPORTANT ****. If you bled gas line, don't try to ignite for a few minutes. Allow gas to dissipate first, use a fan to help.
Mar 05, 2015 | Pentair Mastertemp 250 Natural Gas Pool...
Oven starts and stops
The oven safety valve
(also called the gas valve) is the part that ensures that gas is not released until the igniter has reached the correct temperature needed to ignite the gas. While this part can fail, it is uncommon. If the hot surface igniter does not glow you should first verify that you have voltage to the circuit. This is a live voltage check and should be performed by a qualified person. If voltage is lost at the valve terminals then you should verify the continuity of the bi-metal in the valve using a multi-meter.
The oven burner igniter
commonly known as the hot surface igniter is used in modern gas oven burners to open the gas valve and to ignite the gas. As the igniter draws electric current it will heat to a high temperature and glow, as well as cause the bi-metal in the oven safety valve to warp and open the valve releasing the gas to be ignited. This sequence normally takes about a minute. Igniters come in both flat and round styles and are very fragile. If the burner does not light then you should check the igniter first. If the igniter does not glow at all, then check for power to the circuit. This is a live voltage check and should be performed by a qualified person. If power is present then the igniter may be open circuit and can be checked for continuity with a multi-meter. If the igniter is glowing, but the burner is not lighting, the igniter may be weak and still be at fault because it requires a certain amount of current draw to open the valve. This check requires the use of an amp meter and should be performed by a qualified person. If the igniter is defective then it must be replaced.
Apr 02, 2014 | Kenmore Ovens
If oven igniter is not getting power what is the cause. Oven is plugged in. Broiler igniter works.
Feb 04, 2014 | Kenmore Ovens
Tappan series 110 the igniter is glowing but it wont lite the oven
Is the gas turned on at the stop valve behind the range? Assuming the gas is on, the igniter can glow but not actually be working properly such that the control valve does not open or the valve may be failed. There are electrical measurements for the valve and igniter and related circuit that can be made if you have a clamp on amp meter and a volt meter.
Nov 18, 2013 | KitchenAid KGSA906PSS Gas Kitchen Range
Glow igniter shuts down when dryer calls for gas
The very noisy part is a little bit odd...
Usually the igniter glows, the flame sensor detects the glow and sends power to the valve coils, which open the gas valve. There are some differences in that setup depending on the brand, but that is basically it.
It could be that the igniter isn't glowing hot enough (doubtful) or that the flame sensor (the rectangle thing on the side of the burner tube) isn't working (also unlikely, but still possible) or that the gas coils aren't working. Gas coils are the most common problem to go wrong on gas dryers, but when they go, they usually work at first, and then start to fail.
Do you have a volt/ohm meter?
Nov 14, 2009 | Whirlpool LGR4634J Gas Dryer
Flame will come on at first start then will run for a few mins then turn off then ignition will come on but gas will not turn on
cool you recognize the fact that the igniter is turning on you are obvisouly tech savy so I will dispense with the usual amenities and give you a technicians answere.. igniter gets power and when it reaches max current opens gas valve as time goes on igniter still glows red but doesn,t generate enough current to open gas valve change the igniter first (cheap) if it doesent work check your gas pressure ( need a guy with a special meter) if pressure is too high ( not very common) valve has trouble over comming pressure to open if pressure is ok then time to change out main gas valve Good Luck
Oct 26, 2009 | Dryers
Jet size differnce from natural gas to bottled
You will need more then new orifices to convert from natural gas to propane. The gas valve will also need to be replaced. Not a good idea converting heater.
Jul 12, 2009 | Pentair Minimax Ch 250,000 Btu Natural Gas...
Pentair Mini Max , no power to igniter. Heater would not ignite so I pulled cover and found broken igniter so I replaced it and still it will not glow when gas valve attempts to light. I can smell gas.i...
you may have to reset your board.turn all power off to the unit then turn it back on.if this doesn,t do it make sure you have a good complete circuit from board through element then back to ground.
Mar 05, 2009 | Pentair Pool & Spa
Gas will not stay ignited
could be dirty heater you have to clean the runners and the smole nozzles that are in the manifold below the gas valve it's like a 9/16 size you pull them off and check make sure they are clear through, sometimes little spiderwebs build up inside them. if it's all clean, then it could be you flame rectifier/ aka: flame sensing rod, that tells the htr that there is fire so it keeps running. Let me know what happened.
John
Dec 29, 2008 | Pentair MINIMAX NT TSI IGNITER
Pentair 1.0 Hp Whisperflo Pump Logo
88 people viewed this question
Top Pentair Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pentair Pool and Spa Expert? Answer questions, earn points and help others
