Question about Sony Xplod XM-554ZR Car Audio Amplifier
On the sony xplod do we hook up the monster cable to the 12v or the rem? Thank you
    Scholar:
  • 156 Answers
The REM wire is usually a thin blue wire. Not big at all, so without looking at the wire if it looks like it could be the size of someones finger you got the 12v wire in your hand.
Posted on Mar 05, 2009
Where connect rem connection
rem goes to the back of the headunit to a cable (blue or blue/white) that should say, either rem out or power continuous (PO CON) and needs to connect to the amplifier where it sais rem power(12v)
hope this helps
...andy...
Jan 05, 2014 | Car Audio & Video
How do you hook up a bt39u radio
get a wiring harness from an auto store they usually have one for every car manufacturer and for sony decks they need to be converted from they're own pins to the standard audio deck wiring harness and if not most cars have little tags on the wires telling you what they are, red = 12v constant yellow= 12v switched green = earth black = earth and all the other colours are usually speakers and blue will be remote switched hope that helps
Apr 04, 2013 | Sony Xplod Mex-bt39uw Blue Tooth Auto...
I have my amp hooked up perfectly, but why won't it work? is there a re-set or somthing? i checked fuses and everything
Unlike the stereo unit, amps doesn't have a reset button.
Check the fuse in your hood.
Check all wiring, especially the ground to chassis.
Check for voltages, remote turn on should have 12V to ground and power cable should have around 12 to 14 volts.
Sep 19, 2010 | Sony Xplod Car Audio Amplifier XM-DS1300P5...
I have 1000 watt sony XPLOD amp and i just installed it today. with new monster cable&ground. the green light turns on& thumping goes for a little. i try to raise up just a little bit& after 2...
it isnt getting enough power and its tripping the internal switch on the amp and putting it in safe mode. either your wire isnt a high enough gauge. you might need a capacitor or you need bigger wire.
Jun 13, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Green light, No Power
Disconnect the remote wire and make a jumper at the amp from the 12v + to the remote input and see if you get the same results. If yes, then you probably have a bad ground point. It might not be able to handle the transfer load it's receiveing. If no, then you have an issue with your remote wire or power wire. Check for any kinks or pinches in the wire.
Jan 25, 2009 | Sony Xplod XM-1652Z Car Audio Amplifier
Powers isnt turning on but everythings hooked up?
Check the fuses. If the fuse is bad the amp's power supply is burnt. If the red light stays red and never goes green then your amp is in protect mode and the output section is burnt.To test for rem. problem just use a jumper wire (paper clip... or whatever)to jump from +12v power to rem. If rem. wire has no voltage when your radio is turned on that will make your amp come on. then look for the fuse in the rem. line. Good luck !
barneyluc
Oct 03, 2008 | Car Audio & Video
Sony xm
internal heat capacitor or even a bad connection indside amp is bad giving you a hi output load wich the amp has an auto matic sensor to send it into this offset you speak of so it does not burn up
Sep 22, 2008 | Sony XM-1502SX Car Audio Amplifier
Car amps
important is to hav correct wires and groud cable...
Dec 29, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Xplod amp
You have 3 power connection, +12v goes directly to your vechile's battery (make sure this is fused) REM connects to your head unit which tells the amp when to turn on and off (usually very thin wire, comnpared to the gnd and +12) Te gnd you already know where it goes. Then connect your sub to + and - speaker out put. If you run this bridged it will increase your output, must be 2 channel to bridge to 1 channel or a 4 channel bridged to 2 channels. Hope this helps.
Sep 13, 2007 | Sony Xplod XM-554ZR Car Audio Amplifier
Sony Xplod XM-554ZR Car Audio Amplifier Logo
88 people viewed this question
Top Sony Car Audio & Video Experts
xxxxxx xxx
Larry Stiles
Larry Stiles
Philip Rowney
Philip Rowney
Are you a Sony Car Audio and Video Expert? Answer questions, earn points and help others
