Question about Sanyo Audio Players & Recorders
How to fix the Sanyo M W200 boombox tuner string? The string is loose. cannot select radio stations.
3 Suggested Answers
SOURCE: How to preset a radio station on Sony CFD-S200 Cassette/CD boombox
You will need to use the Forward and Reverse buttons on the CD player. Set the station by holding the button you want to set it to until it blinks and shows the station number.
To set more that 10 stations. Press the (>10) button and then enter 11 or 12 or so on and set the stations the same as above.
Posted on Jun 12, 2008
  • 136 Answers
SOURCE: bosch pb10-cd radio/cd boombox
too many problems with this. if you can get your money back. contact the company for support and see if it has been recalled or even contact your local tv station for their consumer help. tell them about this problem and other from here
Posted on Apr 01, 2009
  • 561 Answers
SOURCE: how do I preset radio stations?
PRESET RADIO STATIONS
1 press RADIO BAND. AUTO PRESET to select the band.
2 Hold down RADIO BAND > AUTO PRESET for 2 seconds until "AUTO"flashes in the display
3 Press DSPL/ENT/MEM. The stations are stored in the memory from the lower frequencies to the higher ones.
if a station can not be preset automatically.
you need to preset a station manually.
2 tune int he station you want.
3 hold down DSPL/ENT/MEM. for 2 seconds until the preset number flashes in the display.
4 press PRESET + or - until the preset number you watn for the station flashes in the display.
5 press DSPL/ENT/MEM. The new station replaces any old one.
TIP the preset radio stations remain in memory even when all power is disconnected.
manual available at sony
http://www.docs.sony.com/release/CFDF10.pdf
Posted on Jan 01, 2010
NO TUNER ON PANASONIC RXDT75 BOOMBOX
Please press the [TUNER/BAND] button on the remote control to access the radio function of the stereo.
Apr 01, 2014 | Panasonic Audio Players & Recorders
Radio wont work but every thing else does
can you be more specific about the problem?
from what i understand, the radio tuner doesn't work... try installing the antenna..
if you don't have one, you can put some string that its made out of metal, it could be copper or lead.. and if they touch the ground, most of the times you get good reception...
Dec 13, 2007 | Bosch PB10-CD Radio/CD Boombox
Tuning knob turns but does not move tuner bar nor change station. all else works fine.
The linkage between the tuning knob and tuner bar (string?) has failed. Disassembly will be required to repair.
May 19, 2013 | Eton FR300 AM/FM/Weather/TV Radio
How do I preset radio stations?
Jan 01, 2010 | Sony CFD-F10 Radio/Cassette/CD Boombox
DC - F170U Sanyo Stero can not use radio tuner will not go to any stations how do I correct this
Does anyone have a user manual for a Sanyo Mini Hi Fi cassette / CD player, model DC-F170U. If you can help please reply to email, brandy.cherry@yahoo.com.au Thanks Cherry.
Aug 13, 2009 | Sanyo Audio Players & Recorders
Program radio tuner
I entered the wrong product code for my boombox. It isn't this one.
Thanks
Aug 01, 2009 | Panasonic RX-FS470A Cassette Boombox
No sound
it may just be the speakers
Jul 16, 2008 | Sony CFD-G500 Radio/Cassette/CD Boombox
Radio reception
If antenna optimization didn't work you'll probably have to move.
Aug 08, 2007 | Bosch PB10-CD Radio/CD Boombox
The tuner not working
First thing to try would be to take out all of the batteries, including the clock battery if there is one. Wait 12 to 24 hours and reinstall the batteries. If that does not work, then there is a problem between the microprocessor and the varactor tuner inside this radio, and unless its less then one year old ,for warranty repair, it most like would not be worth the diagnosis charge or repair charge. Good Luck PS please do not forget to rate this thread
Oct 20, 2006 | Sony CFD-E75 Cassette/CD Boombox
183 people viewed this question
Top Sanyo Audio Players & Recorders Experts
Iron
Iron
 Grubhead
Grubhead
Electro Med Services...
Are you a Sanyo Audio Player and Recorder Expert? Answer questions, earn points and help others
