Question about Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series
Need SATA hardisk driver for DOS
Dear Guys,
I need to download SATA hardisk driver for DOS.
That's it and thank you.
Regards,
yuspri@yahoo.com
  • Chinmay patil
    Chinmay patil May 11, 2010
    are you trying to install windows xp on windows vista system ?
  • 1,602 Answers
GO ON LINE AND TYPE THE FOLLOWING INFORMATION:
SATA HARD DISK DRIVERS FOR DOS
OR
DOS HDD DRIVERS FOR SATA
OR
DOS DRIVERS
OR
DIRECT OPERATIONAL SOFTWARE
ROD
Posted on Mar 05, 2009
SATA Hardisk canot read into bios.. the sata cable is brandnew and SATA hardisk is also new
You will need a RAID driver for your motherboard. Contact your motherboard manufacturer for assistance.
May 23, 2011 | Computers & Internet
Pls give some instructions on how to easily create driver for sata. my motherboard is p5rd1. my hardisk is 250gb.
Hi, maybe you need the driver for the chipset.
Download here:
http://www.asus.com/Motherboards/Intel_Socket_775/P5RD1VM/#download
Remember to select the windows version you are running.
The drivers you download needs to be unziped
before installation.
Check also your bios for the sata settings.
Hope this will help you.
Apr 11, 2011 | ASUS P5RD1-VM Motherboard
I need to do a low level format for my hard disk. Bad sector problem. Do you guys have any application for that particular kind of formatting?
Bad sector on hardisk there two kinds of that is software and physical. physical badsector caused from plate of hardisk damage is caused by dirt, fallen down, collided, to be incised, etc. While software badsector can be caused when hardisk busy sudden die, cause of usually broken electrics current.
For the bad sector damage of physical of hardisk, we require a really of expert to repair the hardisk. While damage of software we can repair xself use software or tool. One of the software which can be used to repair bad sector on hardisk that is HDD Low Level Format Tool.
Using this software hardisk can be low level format. Require to be paid attention that using low level format on a hardisk, causing all data in hardisk will lose and cannot be recovery again. But this way will be more effective eliminate sector bad.
HDD Low Level Format Tool Support Hardisk SATA, ATA or SCSI, can is also used on removable media like flashcard, flasdisk and etc. To run this software is very easy, that is :
  • Download HDD Low Level Format Tool from the link above and install it till finish.
  • Run HDD Low Level Format tools
  • Select a hardisk which will repair then click continue.
Select LOW-LEVEL-FORMAT tab", if you sure To format the hardisk click "format this device" button and await till finish. ad for hardisk repaired hence required time will longer.
HDD LOW format level can be download from following link,
http://hddguru.com
note : If on hardisk have detected badsector, before doing above steps, first step to backup all existing important datases
Premium experts are not paid for free questions so require your appreciation in form of a 4 thumbs rating
THANKS
Oct 03, 2010 | Computers & Internet
Did not see second sata harddisk
To know if your Hardisk is detected follow this steps:
In Windows XP
1. Open Control Panel
2. Go to Administrative Tools
3. Open Computer Management
4. Double Click Storage
5. Open Disk Management
All the list of Hardisk is here, your hardisk is not formatted that's why, so you have to proceed to format just right click that unformatted hardisk and choose format, specify the label for your hardisk or simply leave it blank.
Jan 11, 2010 | HP dc7600 Small Form Factor P4 640...
I cannot install software
Hi..
This happen due to 3 reasons,
The Hard drive is bad.
The BIOS Setting have to be put to SATA.
During the the installation the have to press the F6 option to install the SATA drive drivers.
Let me know
Thanks
Smith
Aug 09, 2009 | ASUS P5LD2-VM Motherboard
I have a new 8ogb sataII Exelstor hardisk which i
Windows XP does -not- have native SATA support and therefore will not recognize a SATA drive without first installing 3rd party drivers.
To go around this problem without installing drivers check your BIOS. There might be something in there where the bios will emulate an IDE controller.
If not, you'll need a floppy and the sata drivers. A flash drive will also do if the motherboard bios supports legacy USB. To find the drivers, simply go to the motherboards manufacturers website.
Mar 03, 2009 | EPoX EP-8KRAI-X Motherboard
I have a problem on the hard disk which could not give power.
Hallow Dear,
____To understand the situation ____
Explain me how did you try to format your Drivers
(Most Common Error)
If you try to format & reinstall with winXP bootable CD (Witch is not injected SATA Drivers manually) Simply it will not identified your SATA Hard disk until you download & install manually SATA Drivers (pressing F 2 during installation to install Sata Drivers)
Use link below & select your System type and Model to Download SATA & other Drivers as necessary
http://support.acer-euro.com/drivers/downloads.html
Thank you & Best Regards
Dinu….
Dec 20, 2008 | Acer Aspire 5610-4648 Notebook
Vista Install Issue
This link has at the bottom of the page a bootable cd .iso to download.Burn this iso on cd and boot from it. or download GParted bootable ISO download and burn on cd and boot from there. Its like running FDISK on steroids.
You should configure sata in the bios boot options etc.
Mar 21, 2008 | Intel Motherboard
How to install xp on hp 530
Press F10 to enter BIOS setup...
find and disable the SATA native support
Now save and exit then when you reboot and attempt to install XP you will have no problem.
Download the drivers you need from here
http://h20000.www2.hp.com/bizsupport/TechSupport/SoftwareIndex.jsp?lang=en&cc=us&prodNameId=3375995&prodTypeId=321957&prodSeriesId=3375953&swEnvOID=1093&taskId=135&swLang=8
Mar 11, 2008 | HP Pavilion dv6000z Notebook
External Segate 200 GB SATA Hardisk (USB 2.0 connection to PC)
I appears the volume may have been corrupted. YOu should run data recovery on the drive if you need any of the content. If not reformatting the drive, should restore it. If the contents are not important, or you have it backed up, go ahead and connect it to the MACINTOSH and format it for MS-DOS.
Unless it is physically damaged ( clicking, beeping, knocking ) it shoud be usable.
Hope this helps.
Oct 19, 2007 | Seagate Barracuda 7200.7 200 GB Hard Drive
Toshiba Laptop Keyboard for Satellite L10, L15, L20, L25, Tecra L2 Series Logo
799 people viewed this question
Top Toshiba Computers & Internet Experts
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
