Question about Sony Alpha DSLR-A100 Digital Camera
I have a sony dslr a100 and when I hook up the camera to my usb port my computer won't detect the camera,my card reader does'nt support CF cards.
  • juxtapose777 Mar 08, 2009
    I tried w/ the camera on and off.I feel sure that I need a driver but have not been able to find the drivers online through sony.I just keep getting led to DRIVER DETECTIVE which I have no use for.
    Thanks for your help-
  • 423 Answers
Was your camera off when you connected it to the pc? It has to be off in order to work. Also, Does your camera require drivers? You might have to have the driver installed in your pc order to work.
Also, did you plug in your camera to your pc and go to my computer to see if it's listed there as a drive?
Rob
Posted on Mar 05, 2009
  • Rob
    Rob Mar 08, 2009
    I found your drivers through Sony. (you just gotta know what where to look...and which arm to break. LOL).
    Just go here:
    http://esupport.sony.com/US/perl/select-...
    Under Type it, choose canada, then pick your camera, and on the next page (down alittle ways) pick your operating system. Give it a sec, then scroll down for what you need. Let me know if you need more help. And you can re-rate my solution if you think it deserves. Thanks.
    Rob
Sony DSLR-A100 eroor 0x58
Well, the good news is that there's probably no fault with the camera itself. It could be something as simple as the CF card being pushed in the wrong way. A look through the user manual will likely help you get to the bottom of your issue:
Sony Alpha DSLR A100 manual
Aug 13, 2014 | Sony Alpha DSLR-A100 Digital Camera
Sony dslr a100 won't switch on. battery ok
the problem is with the CF card nit the camera
get a new card and your good to go
Apr 19, 2014 | Sony Alpha DSLR-A100 Digital Camera
Camera is asking me to format c/f card. i press format and e error mesage comes on screen.
If it won't format and says card unusable, then there is probably a bent pin in the CF card slot. I had this problem and my husband took a big safety pin and filed the point and bent it into a tiny flat hook. Then he filed a flat edge on the point of another safety pin. He hooked the bent pin with the former and carefully, a little at a time, coaxed the pin into a straight vertical position with the latter. He then took a tiny drill bit and hand twirled it once slightly into the matching hole in the card itself to bevel the edges of the hole so when I inserted the card it gently lined up nicely. The camera now works but I don't dare take the CF card out again but instead use only the usb cord to load photos onto my computer. Down the road some day when I am ready to buy a new camera, I might try taking the card out of the slot. Hope this helps.
Jul 26, 2011 | Sony Alpha DSLR-A100 Digital Camera
I lost amual for my SONY a10... can't remember exactly how
Click Sony Support and download required instruction manual of Sony DSLR-A100
Mar 20, 2009 | Sony Alpha DSLR-A100 Digital Camera
MY MEMORY CARDS NO LONGER WORK IN MY SONY DSLR A100 CAMERA?
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.
Best regards - Michael
Jan 12, 2009 | Sony Alpha DSLR-A100 Digital Camera
Sony Alpha 100 gives error message when attempting to take pic.
Hi! I just had the same problem with my Sony A100, when I tried two different CF cards. I was getting the same error message as reported above: "Unable to use card" then "Format?" then that format fails. Thinking the camera is broken, I checked online camera repair sites and also called Sony directly. Sony's flat rate, and that of PrecisionCamera is $228 to fix CF card failure. Then my daughter said, "the CF card in my room works fine in the camera" - and lo and behold - it does. The CF card that works is brand PQI and is marked Hi-Speed 60 2Gb. The cards that do NOT work are marked SanDisk Ultra II 1.0Gb and SanDisk 128 Mb. So my advice is, before you give up on the camera as broken, try a number of different CF cards first.
The second cause of CF failure is if someone has pushed a CF card in the wrong way. That can bend one or more of the tiny metal contact pins in the CF socket in the camera. Look carefully to see that all the pins are straight up. [I don't know how one can straighten these pins, or if the whole socket would need to be replaced...but at least you can determine the cause of the CF failure.]
Jan 07, 2009 | Sony Alpha DSLR-A100 Digital Camera
My sony a100 is plugged in the computer to upload my pictures but
You will find a usb card reader will work much better. Do you have the sony software installed? The ARW files can not be read by any other software except something like Photoshop PS3 or later. I am a pro photographer and the A100 is my favorite camera.
Nov 21, 2008 | Sony Alpha DSLR-A100 Digital Camera
Cf card reader sony a 100 dslr
Buy a camera that does not use CF. Time to upgrade.
Nov 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
USB Connection issues
Try your camera on another computer. This will illiminate any issues with the camera's USB port, or its set-up.
I would think you tried other USB ports on the computer.
Another thing to look at is in the set-up of the camera, that the USB port from the camera is set to work as a vertual drive if this is what you want.
If you are using the camera with its own computer software utility and using it as an intergal operation with its software, there may be a set-up issue with the software, or there may be some corruption in the software installation. This can also be a corrupted driver.
An easy way to get the photos out of any camera is to invest in a USB card reader that is compatible to the memory card in the camera. You can remove the card from the camera and put it in to the reader to download the pictures to the computer. The card would appear as a vertual disk on the computer.
Jerry G.
Apr 12, 2008 | Sony Alpha DSLR-A100 Digital Camera
My CompactFlash card is no longer recognized by my computer (Sony Vaio notebook w/Windows XP home edition)
It isn't clear from your description, but are you inserting the reader into your USB port, and *then* inserting the CF into the reader? If so, try reversing this -- insert the CF into the reader, then insert the reader (with the CF) into a USB port. It is possible that your PC is only looking at the reader once (when it is inserted) and not finding a CF, then ignoring the CF once you insert it. If your camera can read and write to the CF, then it is unlikely that the CF is damaged. Since you have determined that the reader is ok, and since your PC recognises the reader, it is unlikely that it is a USB driver problem. Similarly, it is unlikely that it is a physical problem with the USB port, or the pins in the reader or the CF card.
Mar 03, 2007 | Canon PowerShot A50 Digital Camera
Sony Alpha DSLR-A100 Digital Camera Logo
215 people viewed this question
Top Sony Cameras Experts
Larry Spears
Larry Spears
Are you a Sony Camera Expert? Answer questions, earn points and help others
