I have a panasonic television that is very dark, the other colors are okay but when it goes to nights scenes, its very dark can this be repaired, the model number is ct-25G6E
    Scholar:
  • 93 Answers
It sounds like the master contrast has slipped. If you are confident with electronics, there is a little knob on the main board which allows you to set the master contrast. This is only applicable if the picture looks like it has too much brightness (like a white haze over the picture in dark scenes). Gently adjust the knob to set the correct contrast and you should be up and running. If that doesn't work, then your tube is on the way out.
Posted on Mar 05, 2009
Color is grate on my Sharp 26" TV. However night scenes have become almost too dark to see. I have tried to adjust the settings but no improvement. Is this a fixable problem? Using Comcast Cable a
Check 'brightness' and 'contrast' settings in (usually) 'picture' menu. Use a recording (DVD etc.) of a dark scene to adjust the picture. My TV (not Sharp) has several pre-programmed picture settings. If yours has that, maybe one of them will be good. Otherwise, use manual settings.
Oct 18, 2014 | Sharp Televison & Video
I have a vizio Vt470m....the picture has always been perfect. All of a sudden when picture shows scenes with very little light (dark scenes like at night, space, low light) the black color almost look
Either the TCON board or the LCD panel has failed. Start by replacing the TCON board. If the problem persists, the panel is bad and the cost to replace it would be too high.
Mar 22, 2014 | Vizio Televison & Video
I have a Mitsubishi DLP WD-57831 and the dark colors are hazy/milky on the screen, and the lighter colors look normal. There's a 'ghosting' effect which makes it difficult to watch night time/dark scenes. ...
This tv require projection colors lens R,G,B clean and it coolant chemical replacement.Should check for it prices by a tv shop or shops for best prices for it services.
Feb 01, 2011 | Mitsubishi WD57831 Television
Picture is too dark
Have you tried adjusting the brightness, contrast and color controls?
Jan 02, 2010 | Panasonic Televison & Video
Nights seens are WAY to DARK
do you know what a g2/focus splitter looks like?
if so and you can get to it, adjust the g2 controls ever so slightly.
Sep 08, 2009 | Panasonic PT-51HX42 51" Rear Projection...
Hitachi model 57SWX20B which has a dark screen
loss of brightness could need the mirror and lens cleaned and also the screen.if the tv is over 8 years old then the crts are getting weak.
Jul 28, 2009 | Hitachi 57SWX20B 57" Rear Projection...
Picture has become progressively dark 27'' TV JVC AV-27320
disgaussing will not help this problem..i am scared your picture tube problem or try to change the crt socket first it is not cost much
Jul 01, 2009 | Televison & Video
Panasonic PT-61G63W Too much Black Serial No: MY83430025
The mirror should also be cleaned. but there is more adjustments that can bring up brightnes ie G2 on the flyback transformers but that is some thing a tech should do. Because you have to ad enough of each color to get a gray scale. if you are off the picture will be tinted and your color will be way off.
Dec 26, 2007 | Panasonic PT-61G54 61" Rear Projection...
Televison & Video Logo
125 people viewed this question
Top Televison & Video Experts
