Question about Epson RX595 Photo All-In-One Printer
Ink cartridge I took out used old black in cartr. Went to store to get new one. Installed new cartr. Machine will not notice that a new one has been installed. It contd to say Replace ink cartr.I read the directions , then I realized . Cartrages are to be replaced immediately. I think black cartridge ink, dried up. Machine would'nt notice replacement installed.Need so advice. The screen is stuck on replace ink cartr.When I turn on machine again to get to maintance , it will not allow me to get to SETUP. I up plug / trun on numerous times , the machine .It keeps telling me to replace cartridge.MAKE MY DAY!Can I take it somewhere to get it fixed. Really it my fault for NOT completely reading the directions. Thanks, Nelson.
  • 93 Answers
Using some switch cleaner solvent, gently clean the contacts on the cartridge carriage, and also if you have any, use some inkjet cleaner to clean the nozzle where the cartridge sits, this should clean the mechanism sufficiently to allow the printer to detect the cartridge.
Posted on Mar 05, 2009
Why does my Officejet Pro 8600 have lines across colour printing which do not appear to be removed when I clean the printheads. Any advice?
I've noticed this on my all-in-one HP Office Jet. And though I had a little black ink left, I went ahead and installed a new black ink cartridge. Cleared up the problem. You would think what does black ink have to so with color issues but black is used in the color process. Maybe someone with more knowledge on color balancing may be able to answer that. Also, sometimes it may take several cleanings of the heads to clear them. It also depends on how old the printer is and how often it's used. So these are educated guesses but as I originally indicated my issue was due to black ink that either was old to begin with or had been in long enough to start causing issues.
I hope this helps.
Jul 29, 2014 | HP Officejet Pro 8600
How do I install the printer cartrige? I do not have the booklet...
  1. Turn on your printer.
  2. Open the front cover.
The ink cartridge carrier moves and stops at the loading position unless the printer is busy.
  1. Press the tabs on the cartridge lids, then lift the lids.
  1. Remove the old ink cartridges.
  1. Store the cartridges in an air-tight container or dispose of them properly.
  2. If you are installing new ink cartridges, remove the sticker and transparent tape from the back and bottom of each ink cartridge.
NOTE: You can use your printer with one cartridge (color or black) at a time. To extend the life of your color cartridge and improve printing speed, install both a color cartridge and a black cartridge at the same time.
  1. Insert the new ink cartridges. Make sure the color ink cartridge is secure in the left ink cartridge carrier and the black ink cartridge is secure in the right ink cartridge carrier.
  1. Snap each lid closed.
  1. Close the front cover. The front cover must be closed to start a print job.
  1. Open the Dell Printer Solution Center by clicking Start® Programs or All Programs® Dell Printers® Dell Photo Printer 720® Dell Printer Solution Center.
  2. Click the Maintenance tab.
  3. Click Install a new print cartridge.
  4. Click Next.
  5. Select the type of cartridge you installed.
NOTE: Specify whether the cartridge is a new cartridge or an old cartridge (one that has been used before). If an old cartridge is incorrectly identified as New Cartridge in the Dell Printer Solution Center, ink levels may be incorrect.
  1. Click Next.
Dec 17, 2010 | Dell Inkjet 720 Printer
Color has gone a little crazy. Printing in green etc. How to fix?
Take the ink cartridge out and clean it with little alcohol and cotton, and make sure the cartridge is reseated properly.
Let me know.
Aug 20, 2009 | Brother Office Equipment & Supplies
I have a Samsung fax machine, model SF-3100. It is about 9 years old and has always worked very well for me. Now all of a sudden the print quality has got very poor, very quickly. The first I noticed was...
Try cleaning the print heads with rubbing alcohol to remove any dry ink, also clean the rollers too.
If the unit has a reset button or option i suggest you try that.
Good luck.
Aug 06, 2009 | Office Equipment & Supplies
No cartridge the printer say. i put new cartridge in
It mean that the black cartridge is not recognised. It the black cart is original or compatible? Some printer won't recognise cartridge, if the black and colour is not same type. Try to install the black only. Is it recognised?
May 30, 2009 | Brother MFC-3360C All-In-One InkJet...
Canon ip 1880 - colour cartridge problem
no if ur filling the catridge more times the printer going to damage
May 27, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Apparently, if you hold the "resume button" (the one next to the power button) for about five seconds after you get the message saying to replace the color ink cartridge the machine starts printing. I did this after I went to "maintenance" under "preferences" and changed ink to "black only." At first that alone did not work, but after trying the resume button for 5 secs it worked okay.
Sep 13, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Not printing
The remaining levels of the following ink cannot be correctly detected.
The following ink is running low.
Black [830]
Prepare a new ink cartridge.
The resulting print quality may not be satisfactory, if printing is continued under this condition.
If either black or color ink cartridge has run out, you can set the printer to continue printing with the other cartridge from the Ink Cartridge Settings on the Maintenance tab of the printer driver.
----how to resolve it
email me:
Feb 24, 2008 | Canon PIXMA iP1800 InkJet Photo Printer
Lexmark Z517 wont print black ink
I have a z600 that i use. If not used for about a month the ink does clog the print nozzles and eventually ink cartridge does dry out. To avoid this even if i dont have to print anything I run a diagnostics test that prints out a nozzle aligment test every two weeks.The great thing about this is that it uses very little ink.You can find this test in your software that was provided by Lexmark. This will keep your nozzles cleaned and you will notice this helps extend the life of your cartridge.
Sep 21, 2007 | Lexmark Inkjet Z517 Photo Printer
Aligning the cartridge has nothing to do with the problem of the u150 error that two of the same ink tank cartridges are installed. It's a defective chip in the ink cartridge, as soon as I placed a new cartridge in it worked like a charm. HOLD ON TO YOUR INK CARTRIDGE RECEIPTS, because if this happens to you and the cartridge is obviously new....the store of purchase should provide you with a replacement (+ if you don't want to make a 2nd trip, some stores have the mp830 on display and you can have them toss the cartridge in and check to make sure the chip is working properly). IF THE STORE WON'T REPLACE THE DEFECTIVE CARTRIDGE, contact CANON (USA 1-800-828-4040)and explain the problem & hopefully the will stand behind their product and replace the defective cartridge.
Sep 11, 2007 | Canon PIXMA MP830 All-In-One InkJet...
Epson RX595 Photo All-In-One Printer Logo
132 people viewed this question
Top Epson Office Equipment & Supplies Experts
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
