Question about Panasonic CQ-C1100U CD Player
When i put the radio on mute i hear bass sometimes and i bought new jack wires but they were not very expensive ones
  • 15,935 Answers
If you unplug the RCA's (Jack wires) and the noise goes away - your problem is induced noise. Eminating from a Engine Computer, bad amplifier or radio grounding point or close proximity to power wires in the vehicle. The only fix is to re-route the RCA wire.
If the problem persists when disconnecting the RCA's the problem is the ground loop filter (or lack thereof) in the amplifier or a bad grounding point.
Make sure your grounding point for the amplifier is bare metal (sanded off paint) and on the vehicle chassis - not a interior support bracket.
Troubleshooting noise in an audio system can be tedious.
Thanks for using FixYa - a FixYa rating is appreciated for answering your FREE question.
Posted on Mar 05, 2009
On my Accustic B30 bass amp the input jack is not working. Can this be easily fixed?
Have you checked the battery? Put a brand new one, if that's not the problem, take it to a reputable tech.
Jul 22, 2017 | Bass Music
No Sound from Jensen VM9725BT
Jimmie Monica Hey, Its not a problem with the unit. You have the blue or Blue/White wire hooked up wrong. Disconnect both the blue wire and the blue and white wire and I guarantee the sound starts working on everything. If you have one of those two wires hooked up for a power antenna or remote amp turn on, then switch which one you are using and that will fix the problem permanently. Disconnecting them both will get it to work though. I guarantee it. Please post back and let me know if it works for you. Thanks
Sep 06, 2013
Feb 22, 2013 | Jensen VM9725BT Navigation receiver
Why is there four plugs on the back of speakers?
With four plug you will have a jumper from on plug to the other. (e.g. Positive to positive and negative to negative.) This is for single connection (two wires.) If you use two connections (four wires) you take out the jumpers. the bottom pair is normally for the bass and the top for treble. This is to make the speakers clearer, and sound better. As for louder,? I don't know some people think it does some don't. With better clarity of sound, you do get the feeling of it being louder.
Apr 27, 2012 | Audio Players & Recorders
I just bousght a martin ash home thearer ..how can i conect the bass??
I bought one last night i think its a fake.... doesn't even have instructions. If u figure this out let me know. But i just look up the site called the white van scam... i bought it from some guys in a white truck. And it sounds just like wat they sold me with the same canvas
Apr 18, 2012 | Audio Players & Recorders
My double pick up Dean edge quit working while playing. I checked the wiring and all looks good, but three is s a black wire coming from hole to center of body attached to nothing. Looks like it never was....
Make sure you have two wires soldered to the output jack on the bass. having a wire lose is not purposely put like that, for no sound from the bass then that wire is either from the pickups and connects to the pots on the bass or on the output jack. I would suggest taking it to an authorized dean dealer to inspect the wiring.
Jul 13, 2011 | Dean Edge 4 Bass Guitar
Bought radio at Hamfest. Hooked it up worked flawless. Great ability to fine tune signals. Let a tech talk me into installing echo board. He tried two new boards. They wouldn't work. Told him never mind ,...
The guy who was really not a tech probably didn't hook the mic wires back to the mic jack correctly. that will cause the radio not to TX or RX.
Next time make sure the tech knows what he is doing, and check on line for cb radio shop blacklists to make sure that one isn't on the list.
This guy owes you either a new radio, or pay to have that radio repaired.
If both echo boards didn't work, he doesn't know what he is doing, because he put them in wrong.
Oct 17, 2010 | Ranger Communications RCI-6900F-25 CB...
Bare wire sub to single RCA jack receiver
Yes you can modify RCA cables to make bare wire tails.
If the unit has a sub o/p then you just connect up your sub bass unit to whatever the amp needs.
An RCA cable is 2 wire which is all you would normally need for sub bass speaker level signal.
It may be a good idea to eventually upgrade the wire size if you want really good sub bass as lower frequencies draw more current and so require more copper.
Please let me know if this any help, thanks for using FixYa.
Sep 20, 2009 | JVC RX-554V Receiver
Fender bass guitar shorting out
Inspect the wires leading to the 1/4" jack on the bass. Try moving them to see if you can figure out which wire is the culprit. Check for any bad solder joints on the pots inside the guitar.
Chances are the jack has been twisted and damaged a wire and/or a solder joint.
Jun 16, 2009 | Fender Music
Bass sounds only
That is tricky one. Did you try adjusting the EQ on both the stereo and the amp? Is the Mute turned on because it will act like that? Is both rca jacks plugged in on stereo and amp?
Aug 20, 2008 | Alpine CDA-9856 CD Player
BOOM BOOM BOOM
The Bose engineers in their "infinite" wisdom developed a $300 radio with no, that is NO, tone control. This means the only way to tune bass response is to reposition the Wave radio itself. If you put it in a corner of a room, it will produce the most bass. If it is only against one wall, not so much bass. To reduce bass response to a minimum, you would have to suspend the device from a wire in the middle of the room. Good luck. I would never buy a radio without a tone control; I literally inherited by Bose Wave Radio and use external speakers which do have tone controls.
Jun 10, 2008 | Bose Wave Radio
Panasonic CQ-C1100U CD Player Logo
48 people viewed this question
Top Panasonic Car Audio & Video Experts
xxxxxx xxx
Are you a Panasonic Car Audio and Video Expert? Answer questions, earn points and help others
