Re: We can only see the top half of the words that scroll...
You need to main menu go to feature then format set to 4.3 or just play withit and you will see the whole words set one way and half set the other way.
struts are good for 10 years or 100,000 miles at best. your car went past that long ago. i have had 4 saturns and i used half that age/mileage. you can buy a pair on ebay for less than 80 bucks, but spend another 50 and get "quick struts" which have new springs and mounts already installed as a unit, and they are much easier to change. if you bring your own parts, someone who knows what they are doing can do it for a hundred dollars labor, but you will need an alignment too.
I had mine for 2 years and the main board went out. Cost 650 dollars to fix. Its been less than a yr and a half and it went out again. Selling it on ebay for parts...
1. Goto COntrol Panel > Mouse properties
2. Then goto wheel tab - exception
3. Then add the programs that arent working.
4. Click apply then ok.
If you don't have the exception area in the mouse properties. Then goto add/remove programs and remove the mouse manager that came with the mouse.
One of these solutions should fix your problem.
Sounds terminal. Companies build things with "planned obsolescence" in mind. In other words. You buy a TV today, and the warranty says it's good for 4 years. 4 years and 3 months later, it dies.
This is most likely a convergence amplifier problem. The repair shop will charge you hundreds of dollars to fix it. If you're up to the challenge you can fix it for less than $50. If you search this site for "convergence" you will find lots of posts. Here's one I posted for another person with this problem and I offered a couple of links that should be a good deal of help:
If you have more questions please ask. This repair is not impossible, but if you've never soldered electrical components before it may be a bit challenging.
Lastly, I would like you to know that I don't get paid for this, I just like trying to help. If you find this information helpful I hope you'll rate the solution positively. Thanks and good luck.
B board = Part # A-1302-209-A fix by substitution......
check price and availibility..............B is a sister board mounted
to the A board (signal)........................................T.
