Question about Panasonic Lands Phones
No tones, just a click when dialing
I have a Panasonic KX-T3170. When the handset is in the cradle and I'm using the speakerphone, I can hear the varying tones as I press each number.
But when I pick up the handset to dial, all I hear is a single click for each number that is enter, no tones.
The phone is set to tone dial, not pulse dial.
  • barb333 Mar 07, 2009
    Tried it, no change.
    New Friend:
  • 168 Answers
Try setting it on pulse, then hear it click when you push the number, if it works switch it back and try agian
Posted on Mar 05, 2009
There is a function key "fwd/dnd" is keep flashing on My Panasonic kx-t7030x phone. How should I cancel for it?thanks!!!
The slow flashing indicates that your phone is currently set for Call Forwarding.
To cancel from this phone, pick up the handset (or use speakerphone), then press this key sequence: [FWD/DND], [0], [#].
The light should turn off, and you should hear a confirmation tone. Once you hear the dial tone again, hang up using the handset or speakerphone button.
Source: page 3-19 (79) of http://www.google.com/url?sa=t&rct=j&q=panasonic%20kx-t7030x&source=web&cd=2&ved=0CFoQFjAB&url=http%3A%2F%2Fpdf.textfiles.com%2Fmanuals%2FTELECOM-F-R%2FPanasonic%2520KX-TA624%2520Users%25203.pdf&ei=ycQCUdf0O5To9gTK_YDQAg&usg=AFQjCNEt0-JdZEhH0WCSSp6Sl7VOmARFbA&bvm=bv.41524429,d.eWU
Nov 04, 2012 | Lands Phones
I was cleaning my phone and I pressed on something and now there is music playing that i can not stop,I don't know how to stop the music,my phone is panasonic KX-T7730
Here are two methods to turn off background music, one of these should work depending on which Panasonic phone system your phone is connected to.
1) With phone idle, press the 1 key on the dial pad (turns off background music when it is on and turns on background music when it is off).
2) With phone idle, press intercom button then dial *751 on the dial pad followed by 0 on the dial pad to turn off background music(confirmation tone will be heard) and end by lifting handset and replacing in cradle. To turn background music on, press intercom button then dial *751 on the dial pad followed by 1 or 2 on the dial pad to select the background music source(confirmation tone will be heard) and end by lifting handset and replacing in cradle.
Feb 05, 2011 | Panasonic KX-T7730 Corded Phone
Display screen shows "Will return soon" Would like
You need to cancel absent message on your phone. The method depends on which Panasonic phone system your phone is connected to. Following are the methods for three different Panasonic phone systems. Once you cancel absent message, your screen should return to date and time, if not then press * until it does.
KX-TA624 Phone System
Press intercom button, dial 750#, lift handset then return handset to cradle to end.
KX-TA1232 Phone System
Press intercom button, dial 7500, lift hanset then return hansdset to cradle to end.
KX-TDA100 or KX-TDA200 Phone Systems
Press intercom button, dial *7500, lift handset then return handset to cradle to end.
Jan 27, 2011 | Panasonic KX-T7633 Corded Phone
Cannot get a dial tone or hear caller on one of the handsets, but can hear it ring and the caller can hear me. The other handset is fine.
try unpluggjng base unit from power supply and then let handset unit reset to relocate the base unit.
Feb 11, 2010 | Panasonic KX-TG5632 Phone
I have a Plantronic headset. I have moved to another location (and phone jack) in my office. The Plantronic headset plugged into the Panasonic KX-T7633 does not get a dial tone. When I go back to my...
If you are using this phone on a Panasonic KX-TDA 30/100/200/600 system. With the handset on the cradle/hook press Program 61 and ENTER. Press SEL or AUTO ANS / MUTE to change the setting to On. Press AUTO DIAL / STORE to save your changes. Lift the handset and put it down to exit program mode.
PLEASE rate/vote this answer if it was helpfull.
THANK YOU
Oct 29, 2009 | Panasonic KX-T7633 Corded Phone
Ring tones on KX-T7433
Wow, this is your lucky day :-)
From each phone, press PROGRAM 99 and the INTERCOM or CO buttons TWICE, then dial 1-8 and STORE. (default is 2). You can now make each line and intercom different, or each phone (up to 8) different. After you finish with each phone, just pick up and drop the handset back into the cradle to end programming.
The feature is called Ringing Tone Selection.
Carl
Apr 02, 2009 | Panasonic KX-T7453 Corded Phone
Phone won't work
Hi - I stumbled upon this fix after my KX-TGA8231B DECT6.0 phones lost dial tone: I simply removed the rechargeable AAA batteries from the backs of each handset and put them back in after a few moments. This restored dial tone and the ability to hear a call when the phone is answered. Good luck. ---Gerry
Nov 04, 2008 | Panasonic KX-TG8231B Phone
Panasonic cordless phone #KX-TGA931T
For the speakerphone switching phone off problem, substitute the 630 mAh Ni-MH battery that comes with the phone with a better Ni-Mh battery of higher mAh such as Duracell or better yet eneloop.
Oct 25, 2008 | Lands Phones
Panasonic kx-fpc141
Try Ths on the handset Be sure the TALK indicator is off.Press LOUD/RINGER button on the handset, the curreent ringerwill sound. To change the Volume press the LOUD/RINGERagain within 5 secs , and the new ringer will sound, you must press LOUD/RINGER within 5 secs or the volume will not change.
May 08, 2007 | Panasonic KX-FPC141 Plain Paper Thermal...
Lands Phones Logo
276 people viewed this question
Top Panasonic Lands Phones Experts
guyvstewart
john milligan
Are you a Panasonic Lands Phone Expert? Answer questions, earn points and help others
