Question about Ryobi Garden
Need a new pull start spool for this Ryobi line trimmer
Need a new pull start spool for this line trimmer ryobi PLT3043A the ratchet is plastic and has sheared the notches off.
Can you tell me where to get one in melbourne
please.
regards vena
  • Rogo1 Apr 14, 2009
SOURCE: Jammed line spool on Ryobi gas trimmer
On my Ryobi trimmer, all I have to do is unscrew the knob (the device that you "bump" to advance the line) at the bottom of the spool and the spool can be lifted out. I had to use a strap wrench the first time since it was on very tight. You don't have to line up any arrows to remove the reel.
Posted on Sep 24, 2008
evwood
  • 50 Answers
SOURCE: I believe my Ryobi 12 VoltBattery Line trimmer need a new battery
First, check to see if the charger is working properly. To do this, recharge the battery for about 15 minutes. Then check to see if it now runs the trimmer. If so, then you have a bad battery. You can go on the WEB and find a replacement. These batteries or sensitive to heat and cold. When storing, try to place it in a comfortable environment. Sorry for your loss. If it still under warranty, check with the Co.
Posted on Jan 03, 2009
SOURCE: how do I wind trimmer line on double spoools for ryobi
Okay, so the good news is that YOU are probably not stupid. If you have a Ryobi trimmer like I do, it might have taken you a while to figure out the "secret" on how to rewind the line. If you only had to learn the lesson once, you are smarter than I am. (I'm leaving myself a note for next time).
If you wind the line the wrong way, you go through line really fast until it clogs up inside the bump head and you are forced to try again. The trimmer has an arrow on the spool for the direction to re-wind the line. Think of it this way, TURN THE SPOOL IN THE DIRECTION OF THE ARROW! Don't do what I did and rewind the line in the direction of the arrow, that would be wrong.
Whether this is a "mistake", a way to sell more trimmers/parts/line, or simply bad tranlation from Japanese to Engrish, it really doesn't matter. You don't need to buy anything with the exception of new line.
Good Ruck,
Mark
Posted on Aug 18, 2009
rwvanlue
  • 486 Answers
SOURCE: I bought a second hand RYOBI PLT3043a line trimmer
Basics to check:
1) Spark plug - brown or dark brown - OK
a) is it carbon or fuel fouled
b) is there spark
2) Muffler remove for inspection
a) exhaust screen clean or plugged
b) inspect cylinder wall/piston as the flywheel is slowly rotated
3) Check cylinder compression
Fuel starvation - 'lean fuel' condition
Basic things to check:
1) spark plug
2) spark arrestor in muffler
3) fuel lines and tank filter
4) turn adjustment needles out (counterclockwise) 1/4 to 1/2 turn
Chain Saws:
5) check impulse tube and intake boot for cracks or leaks
*if all of the above are OK and/or do not improve performance then:
Remove Carburetor
6) replace gaskets/diaphragms
a) use a spray carb cleaner to clean jets, holes, and body of carb
b) fuel pump diaphragm goes against the carb body,
then the gasket towards the outside
c) metering gasket goes against the carb body,
and the diaphragm goes towards the outside
Posted on Nov 25, 2009
  • 7 Answers
SOURCE: ryobi trimmer plus won't start. No sound at all
if it pulls super easy and it doesnt sound like the engine is even rotating when you pull it it is your pull cord assembly . basically its a giant ratchet my advise is just get a used one of a blown up weedeater it would be cheaper
Posted on May 12, 2010
Ryobi line trimmer plt3043a starts idles but dies when i attempt to increase speed
May I suggest checking along the fuel line and its attachments for a very minor air leak. The minute it sucks air it will stop. Check any rubber washers or O rings too.
Feb 02, 2015 | Ryobi Garden
How to restring trimmr line of ryobi gas trimmer
What is the model of your Ryobi trimmer? If it is a bump an cut, you just turn the big plastic screw on the bottom CCW, and take the spool off.
Oct 09, 2014 | Garden
How do I get the old line trimmer spool off of my Ryobi 18 volt cordless trimer
When looking at the head, you will see to two gray rectangle pieces. Press them both at the same time between your thumb and forefinger and then pull. It should come unlatched and reveal the line spool on the inside
Jul 25, 2014 | Ryobi Lithium Ion 18 Volt 18v Cordless...
How to attatch trimmer line to RYOBI ELT400
Hello! Trimmer Line Installation; Place Trimmer On Workbench Or Floor, Grasp Trimmer Housing With Left Hand Turn Middle Nut With Right Hand,Left To Right Removing Center Peace,In Some Models Suchas Electric Models The Center Piece Just Snaps In.Remove Nut Remove Line&Spool,Bottom Caseing.If Spool&Inner Housing Is Dirty Cleam With Soap&Water.Pay Attention How Line Is Inserted Through Spool,You Will Need To Reinstall Same Way.You Will Need About Twenty Feet Of # 60 Or 65 Line.Buy Line At Any Home Improvement Center. Most Trimmers Are Double Lined.Find Middle Of Line,Thread Through Holes That Old Line Came Out Of.Wind Line Accordingly To Arrows On Spool Edge. Leave Enough Line TO Insert In Groves On Edge Of Spool.Reinstall Spool Put New Line Through Holes In Outer Housing Pull Line Untail Line Is Free.reinstall The Rest Of Parts In Reverse.Hope This Helps,any comments welcome,thank you, hdy
Jan 30, 2012 | Ryobi Garden
How to install replacement line for a Ryobi 18v weedeater
The long bolt coming down at the end shaft like place reel over bolt then turn back and forth slowly while pushing upward and it should lock in and take knob or bolt at end and tighten to the right.
Jul 05, 2010 | Ryobi Garden
Starter cord on Ryobi PLT3043A broke - is it simple to replace?
unless you are mechanically minded you can run into trouble it is best to get a quote from your local dealer
Jul 03, 2009 | Ryobi 15" Electric Factory Reconditioned...
Removing line feeder from a Ryobi, model 100
You just pull it off. It takes a lot of force. When re-installing the spool, be sure that the line is inserted in the exit hole and the line is wound in the right direction.
Dec 09, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi rlt30ces trimmer
Hi there, takes a bit of working out without a manual, but try this....take bottom half of trimmer line spool off, get piece of spool line approx 60 cm, long and thread through centre holes, ( bit fiddly but ) pull line through until you have equal length on both sides, dont try and wind it up onto the spool, just put ends of line through outside cover holes, then lock spool in place in other half. now simply wind the knob at the end and the line should retract into the spool., sounds complicated but really isnt, best regards and good luck, Philbee
Oct 24, 2008 | Ryobi 30 Cubic Centimeter Gas Brush Cutter
Ryobi ss30 (ry30544) pull string keeps jamming
I am having the same problem. I took it apart and the plastic cap piece for the pull string spool has a crack. This is the plastic piece that turns the engine when pulling. Because of the crack, the absorption spring under the cap slips out of its hole in the cap. This causes the pull string spool to jam after a strong pull that causes the crack to open up. Now I need to find a replacement part. Any ideas?
May 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Garden Logo
553 people viewed this question
Top Ryobi Garden Experts
Jim Parker
Jim Parker
Rexter1
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
